Question about Bush Televison & Video
Bush tv cycling through sources - Bush Televison & Video
Bought new Bush 32in HD ready LED TVs on Saturday. Tried DVD which worked fine on previous TVs but on new TV pictures are all green
Please verify the correct tv source is selected as i think the green screen is the no signal indicator.
If it is the correct source , perhaps the tv is not compatible with the output of the dvd player. It might be wide screen or wrong aspect ratio and gives you a green screen .
If neither of those help, be sure to try another cable.
Feb 13, 2018 | Bush Televison & Video
How do I set my Bush TV to switch on as a PC Monitor
you have to look the source menu button at the tv panel to select pc option.
Nov 14, 2012 | Bush Televison & Video
Bush TV
Try to download the service manual to your. There will be no free downloads to Bush TV. All of them are paid downloads, and will ask more than $20.
May 29, 2012 | Bush Televison & Video
No rem ot for the bush tv no 0845 can get sound but no picture do i go to tv or d t v on the source button ?
I'd say DTV. also u could check if TV mode is PAL, US system(NTSC) or Auto. default to AUTO if u don't know. hope this helps.
Aug 01, 2011 | Bush Televison & Video
My L319 LED bush tv keeps on channel flicking after a few minutes of turnig on. Many thanks Helen
Determine if there is a source of interference such as flourescent lights. Turn all electrical items off and switch them on, one at a time to see which is causing the problem. Also try covering the IR pickup window on the TV with some card to see if it is due to external interference or it is an internal problem.
Feb 28, 2011 | Bush 2871NTX 28" TV
Bush TV Model No 5693D
Try using the source button to switch through different inputs.
If that does not work try connecting a signal booster to the aerial, they cost about ten pounds at Argos.
Mar 06, 2009 | Bush 5693D 24" TV
How to tune my digital chanels in my bush lcd tv
i just saw a post which I believe will solve my problem (I connected to the wrong coax antenna plug). I haven't tried, but I'm pretty sure that is the problem.
Here's the post from akai_owner from 2007:
Look at the back of your TV. Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs. Wait one second between pushes. You want to stop just before the source that displays "AV" on TV screen. It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4. If you use no cable box, try changing channels on TV to find an active one. If no luck, make sure your cable service is active (subscription active). Cable companies disconnect it between residents of an apartment/house.
Dec 19, 2008 | Televison & Video
Tuning a tv!!
What is your source of signal?
May 30, 2008 | Bush 2871NTX 28" TV
Bush LCD26tv022HD
I have the same issue. If you click the source change button it will come back- (whilst on the wrong source) for a while. I think your getting inferior LCD panels. Try smelling at the top  of the tv, see if it smells a bit burny.
Jan 14, 2008 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
