Question about Dell E193FP 19" LCD Monitor
Screen is jumping and will not stop
The screen jump and will not stop no matter if you cut it off and unplug it when you turn it back on it continues to jump so fast that you can not make out what is on the screen
    Scholar:
  • 96 Answers
If this is an older type cathode ray monitor (CRT) there ahould be a control on the back for "vertical roll" that needs adjustment.
If it's a newer flat panel TFT screen take it to a shop or junk it.
Posted on Jan 03, 2009
How do i stop my Samsung S5 screen from jumping
Have you installed any apps recently? If so, try uninstalling the app, and see if it helps.
If that does not help, back up your info, and do a factory reset. If a factory reset does not help, you will need to send it in for repairs. It should still be under warranty.
Nov 26, 2014 | Cell Phones
What would cause temperature gauge bouncing ?
Sounds like the sending unit has an intermittent short to ground. Unhook the the wire from the sending unit, and see if the needle stops jumping around. If it quits jumping around, replace the sending unit. If it still jumps around, you have a bare spot somewhere on the wire and it is hitting ground which will cause the needle to jump. Cut out the bad part of the wire and splice in a new section. That should fix it.
Jul 20, 2014 | 1996 Buick Century
Jumping and rotating screen
You might have set wrong display settings and please put the refresh rate of the screen to the optimum frequency. This will surely help you.
Apr 16, 2010 | Acer Aspire One PC Notebook
Small refrigerator stopped working 75r
You have 2 wires. Unplug and put wires together. Plug unit back in and check to see if everything is running. Doesnt matter where the wires go with a 2 wire thermostat
Oct 09, 2009 | U-Line Uline Origins Series...
I went to start my car today (2002 pontiac aztek) and it did not start. My husband jump started it. It started. Let it ran for 10 min. and then went down the rode to a market. I kept my car running. On my...
Your problem is either the Alternator isent charging its 13.5 volts and the battery is flat or wont hold the charge SO do this.
Jump start engine again let it run for 2 minutes then turn on lights,, the head lights should go bright at 13.5 volts. it engine cuts out..and the lights dont go bright,, then the Alternator is not charging,,,, If they go bright and still cuts out the batterys NO GOOD.
Replace battery or get it checked outit must hold 12volts all the time Let me know how you get on.
Oct 06, 2009 | 2002 Pontiac Aztek
Bottom oven element sparked then quit working
The element sometimes will continue to arc inside after it burns out. It's 220 volts jumping across the break.
Mar 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Jumping Screen
I've had a couple of these. The panel control board is going bad, but there may be a way to make it last a bit longer. If you go into the MENU of the TV, and turn off all the color correction, all the whistles and bells that come inside the tv to "make the picture better," it usually helps. Any kind of motion correction, or any kind of noise reduction (picture noise reduction) should be turned off. If the picture has a cloud of green pixels that seems to pepper the screen, then after you turn off all the stuff in the menu, unplug the TV for 5 minutes, and then plug back in. It should help the picture some.
Hope this helps...
Jan 05, 2009 | Insignia IS-LCDTV32 32 in. Television
Dell E193FP 19" LCD Monitor Logo
410 people viewed this question
Alun Cox
