Question about HP Photosmart 375 InkJet Printer
Will my hp photosmart 375 printer read an 8gb card?
Once I place the 8gb sd card, it says "card access error"
Inky
  • 691 Answers
SOURCE: HP photosmart D7300 series, will
Card format may be incompatible with reader or card may be too large for reader to manage. Try another card in the reader to see if it will read that one. If so you know the card is the problem not the reader.
Posted on Sep 19, 2008
leroyal
  • 2120 Answers
SOURCE: HP Photosmart 8450 won't read 4gb SD card.
Yes, you should have received a USB cable with your camera. If not, take the camera to Radio Shack for a match-up.
Posted on Jan 11, 2009
SOURCE: Memory card error
Memory cards larger than 2 GB are not supported with Photosmart printers
Posted on Feb 09, 2009
SOURCE: Error reading SDHC flash card in a HP Photosmart 8250 printer.
Purchase a SDHC to USB media converter (e.g. SanDisk
M/N SDDR-113-A10M), which allows you to plug that SDHC
memory card into the printer via the USB port.
Posted on Mar 14, 2009
FixinFax
  • 3085 Answers
SOURCE: HP Photosmart 8450 won't read 16gb SD card
maximum for your printer is a 2gb card.
Posted on Jun 30, 2009
Hi! The problem is that I want to place or send applications to the SD card of my android phone, 4.2.2 , and it does not work,how to do it?
Certain apps cannot be moved from the internal memory to the SD card
To check if app can be moved GOTO manage apps in settings and see if move to SD card is light up if not can't move it if light up you can move it
Out of the 12 apps on my android phone only 1 could be moved
May 24, 2015 | Lenovo S668T Unlocked Smartphone 8GB TF...
Photosmart 325 won't read SDHC 8 or 16?
I think your sd card not available more then GB supported. Or may be your photo master not supported SD Card. So contact customer care for better support provides.
Thanks,
Jun 23, 2014 | HP PhotoSmart 325 Compact Photo Printer
My SanDisk 8GB will not download in the printer - an error saying Memory Card Error shows on the screen
The D7160 works with SD cards. Your 8GB card is an SDHC card. While it fits into the slot, it is electronically incompatible and will not work with this printer. You need to use SD cards, 2GB or smaller.
Oct 09, 2013 | HP Photosmart D7160 InkJet Printer
I'm having a problem with the sd card 8gb. i get a check card error and it won't function.
The SV-AV30 works with SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Jul 27, 2012 | Cameras
My 2gb micro sd memory card as locked so iwant to passward
hello,
sad to hear that but i have a problem same as you before. i can't open and all my files is in there. all you need to is you go to the expert that doing repair of that staff like computer technician you have find in your place because they are only way to save your files. they have there computer to program about recovery.
Or another option
you might have a bad card.I got a good deal on 8gb micro sd card here http://www.ioffer.com/i/8GB-MICROSD-MICRO-SD-MICROSDHC-MEMORY-CARD-SD-ADAPTER-141239431
hope it can help...
Sep 02, 2011 | Computers & Internet
When trying to record video, within about 15 or 20 seconds, a message saying, "Too Slow Card," comes on the screen and the video quits
This camera can use SD or SDHC cards up to a maximum of 8GB (gigabytes). These cards come in different "class" ratings. A class 4 card will provide faster access than a class 2 card. Video cameras like faster access cards and some specify that the card should be class4 or class 8. The card will have a number printed on it, maybe inside a capital letter "C" if it is faster than a class 1.
The manual for this camera does not specify a minimum class rating for the card.
Jan 20, 2011 | Vivitar DVR 810HD Flash Media Camcorder
I accidentally used a damaged SD card on my Kodak P712, so it flashed that "error" message. but after that every SD card i used, whether my own or new, it always flash that "error"...
The problem is that your camera will only read SD cards, not SDHC cards. After you damaged the SD card that you've been using for years, you bought a replacement, not noticing that it was SDHC. The new cards don't work, not because they or the camera are broken, but because they're not compatible.
Cards up to 2Gb are generally SD. Cards over 8Gb have to be SDHC. 4Gb cards can be either SD or SDHC, but are almost always SDHC because they're cheaper. (I would avoid the rare, expensive, and problematic 4Gb SD cards.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it. (If it does, it probably means that they made a 4Gb card, but there were some error locations and so they disabled half of it and packaged it as a cheap-brand 2Gb.)
Jan 19, 2011 | Kodak EasyShare P712 Digital Camera
I just bought a new memory card (8gb) for my digital camera (Samsung NV10) and when I inserted the memory card, I kept getting "Card Error". It said I should format the new memory card and I tried to...
The largest SD card you can use in your Samsung NV10 is 2GB. thats why once you insert the 8GB sd card its shows card error or need to fromat.
FYI. for every digital camera there's a compatible memory card and you can see from the box or manual and Its writen SD or SDHC.
goodlukc and thank you
Aug 10, 2010 | Samsung NV10 Digital Camera
When I insert a SDHC memory card in printer,I get card access error message.How can I solve this problem?
Your printer was designed to use SD cards with a maximum 2GB capacity. It was not designed to be compatible with SDHC cards and cannot read them.
SDHC cards are a later development and will fit into the same slots, but are technically different. As the difference is due to hardware incompatibility, there is no way to update your printer to accept the later standard.
Jul 09, 2010 | HP Photosmart 375 InkJet Printer
HP Photosmart 375 InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
