Question about GE SDVR-16 Video Recorder
Getting it to operate
Hi, I have only just purchased an sdvr and I have never used it (I bought it as faulty) and when I put power and a monitor to it (nothing else) I just get a constant beep from the unit, though the fan actually spins aswell, has anyboby got a clue? cheers Dave
0 characters
1 Points
29" LG Flatron TV bought in 2007. On starting TV,
That kind of prolem is commonly caused by dried electrolytic capacitor on the low voltage power supply. Leaky capacitor affect the performance of the B+ once sense by the processor it will automatically shuts down the unit.
I've advice you to send it to qualified service center to isolate the problem because oscillator is also going to check for normal operation. This is quite technical and not DIY.
Thanks for using fixya.
Please rate my help.
Jan 17, 2011 | LG TV Receivers & DVRs
Quick things to check on tv's and, monitors
remove power; remove the cover: with a multimeter on "ohms" check the fuses they will be identified on the circuit boards as: F-1, F-2 etc. look over the circuit board for burned resistors and, other components i.e. leaking "domed" capacitors, next: repower safely then: using component coolant from radioshack cool the i.c.'s as you stand behind the tv / monitor while watching the monitor using a mirror to see the monitor screen (do not touch the open monitor case.) if one i.c. suddenly makes the unit work: heat it with a hairdryer on "warm" to duplicate the failure before you replace the faulty component.
on Jul 18, 2010 | TV Receivers & DVRs
I bought a Tevion 28216ALD quite some time ago and I've now been trying to get it set up. I've set up the dish according to the angles appropriate to my postcode, such that I get a signal reading of 63%,...
Hi I have the same issue. As a test I unplugged the cable to the dish and it still read 63% So I'm assuming it's a duff box or my cable is wired badly and it's not getting anything from the dish. Did you get anywhere with this?
Jan 15, 2011 | TV Receivers & DVRs
Follow these instructions to reset the master password on the JPEG2000 and JPEG2000 H.264 Dual Codec series DVRs. Press the menu button on the DVR. When prompt for a password, press the follow buttons on the DVR in this order: STOP --> PLAY --> STOP--> SEARCH --> PTZ --> PIP -->1 --> 2 --> OK (or Enter). You will be logged into the DVR as the administrator. Select Configuration from the System Menu. Then, select password Setup from the confuration menu. The password setup screen will display your current password.
Nov 09, 2010 | GE SDVR-16 Video Recorder
Just purchased RCA HD Tv. What is the RCA code
We would be happy to help you with getting your DISH Network remote to control your RCA TV. We're going to start by pressing and holding the TV button located on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your RCA TV here are some of the codes we currently have: 503, 627, 633, 725, and 505. Press the pound (#) button. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your RCA TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Feb 11, 2010 | RCA DISH Network(r) 311 Satellite System
No sound through Iomega Pro HD on the TV, but works on laptop
I have a similar problem. When I first used it, it was OK but one day after a week or so, I've lost sound. When I put the volume of the TV to the maximum, I can hear it but it is still faint. Another problem/dissatisfaction I have is that the high resolution pictures are not displayed as good as my similar resolution PC monitor. I am dissapointed in that regard but I will still keep the device if I can fix the sound. I will call the tech support tomorrow.
May 25, 2009 | Iomega ScreenPlay
Cannot get dvd recorder drive to read dvd-rw
manual should tell you to use either dvd(+)rw or dvd(-)rw typ disks
Feb 07, 2009 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
Directv H20 Receiver won't power up
You have a faulty power supply in the receiver.It has to be repaired,it seems to be a common problem
Dec 22, 2008 | Philips DIRECTV H20 DTV Receiver
Video loss
you're right... it is indicating video loss. from my experience, at least 90% of the time it's because the cameras aren't getting power.
Jun 11, 2007 | GE SDVR-16 Video Recorder
Av 500 froze while updating firmware, power light on with adapter but doesnt not work.
Press the power off button and volume up button simultaneously for a couple of seconds. Rick
Sep 30, 2006 | Archos AV 500 400-Hours Video Recorder
GE SDVR-16 Video Recorder Logo
24 people viewed this question
Top GE TV Receivers & DVRs Experts
Jaime Hernandez
Are you a GE TV Receiver and DVR Expert? Answer questions, earn points and help others
