Question about Garden
19e412 fires but won't stay running
Fires up but won't stay running
  • 7,482 Answers
Hi Brian
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Oct 30, 2012
2 Suggested Answers
  • 293 Answers
SOURCE: Tractor won't stay running, back
It seems as if the tractor was out of its correct timing, also try replacing the spark plugs.
Thanks
Posted on Jun 03, 2011
My 1994 Jeep Grand Cherokee won't start. It turns over but won't ignite or stay running. It was running fine until I filled up with gas and was driving home. I've tried to reset the security system wi
The gas u put I'm the tank was high octain if it was it was making the engine fire to early replace the gas and it should wor properly
Feb 16, 2013 | Cars & Trucks
2003 Dodge Durango (5.9L V8) won't stay running unless you keep your foot on the gas.
Check temp sensor and TPS, throttle positioning sensor.The power control module,"pcm.is a possible thought.Just check all connections. It is always a good idea to spray WD 40 or equivalent in the connections.
Feb 11, 2013 | 2003 Dodge Durango
I have a 97 dodge stratus. It won't start. Tried
Make sure it's getting fuel. Try using some ether or starting fluid. If it rumbles to life but doesn't stay running then there's a problem with the fuel delivery system. i.e.... Fuel pump, clogged filter, pressure regulator.... If the ether doesn't change the results you are getting now then it's a fire or sensor problem. Ignition coil, relays, sensors not signaling, PCM... I wish you luck. Let us know how it turns out
Nov 05, 2012 | Cars & Trucks
Chainsaw won't stay running
You must have dirt in one or more of the carb jets. Remove the carb and clean it with carb cleaner spray and compressed air (compressed air is a must).
May 10, 2012 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Pw50 fires but won't stay running
Hi, Jj9871 and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
pw50 won start please help
My Son Has Yamaha Pw50 That Will Start But Won Stay Runn
https://books.google.com/books?id=ozV8-Aer4N8C&pg=PA84&dq=pw50+manual&hl=en&ei=TCS2TcbdJ4PW0QG0z9jmDw&sa=X&oi=book_result&ct=result&resnum=1&ved=0CGUQ6AEwAA#v=onepage&q=pw50%20manual&f=false
OEM parts for Yamaha
Yamaha PW50 Owner Manual
Apr 14, 2012 | 2004 Yamaha PW 50
I have a model 336 Husqvarna chainsaw and it won't start. Put fuel into open plug hole replug, then turn it over it fires until the fuel runs out & won't restart & has full tank, obviously...
There has to be a kink in your fuel line ,or some blockage. Dump the fuel out ,then disconnect the gas line and try to blow air through the line.
Sep 04, 2011 | Garden
19e412-0134-01 won't start. gas leaks out air
The float is stuck on the carb flooding the engine and leaking gas out of air filter. Remove the float bowl after the gas is turned of or drained. Thoroughly clean carb And bowl with carb cleaner. Reove the float {very carefully} if it is copper, shake it. If you here fuel in it then it is no good. If not then clean everything and reassemble. If it needs to be replaced, most small engine repair shops will have your parts.
Aug 28, 2011 | Porter Cable BSI550 W 5,500 Watt Generator...
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
