Question about GE Nautilus 24" Built-in Dishwasher
GE Nautiflus GSD 3200 dishwasher won't fill - GE Nautilus 24" Built-in Dishwasher
  • 1003 Answers
SOURCE: Ge Dishwasher GSD 2000z
REPLACE TIMER CONTOL BOARD
Posted on Feb 02, 2008
  • 572 Answers
SOURCE: GSD 2600 Dishwasher; water enters, but no spraying/washing going
check the chopper assembly
Posted on Feb 08, 2010
tbirdfan1
  • 3051 Answers
SOURCE: My dishwasher GE profile quiet power II MV832134B
Hello there again
I think we got disconnected in the chat room so i will post the solutions here for you to check ok
The water doesn't drain from the machine If the water doesn't drain from your dishwasher, check these: Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt If the motor isn't turning or working, the unit won't drain. at all." If the motor hums but doesn't turn, it may need to be replaced.
Posted on Jun 27, 2010
marka19
  • 1430 Answers
SOURCE: I have a GE GSD 5130 Dishwasher that leaks about
This is more likely the hose connection at the drain pump or the pump housing is leaking. You will need to remove the toe kick, place unit into a drain cycle and inspect for a leak. Here is a couple links that should help.
http://appliancehelponline.com/dishdraincircpumpvideo.html
http://appliancehelponline.com/dishwasherdrainpump.html
Posted on Jul 15, 2010
kel1guy2002
  • 3740 Answers
SOURCE: GE Potscrubber Dishwasher Model GSD
Hi and welcome to FixYa, I am Kelly.
There is and internal float switch that controls power to the inlet water valve. If the float is sensing that the unit is full of water it will go through all portions of the cycle but.... will not have any water in it at all.
Take a look at this diagram and check items 302 through 308:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=209408&diagram_id=20816425#d20816425
The float should move up and down around 1/2 inch. I believe your float is stuck in the UP position. This is usually caused by food particulate on the stem (Item 306). Clean it up and it should work. You can gently push the stem up and down from under the unit and you should hear the micro-switch click as you raise and lower the stem. No click = bad micro-switch / no power to the inlet water valve. You can briefly jumper across the micro-switch to see if you get water flow during fill cycle. Just be aware of the dangers of working on live circuits.
Thanks for choosing FixYa,
Kelly
Posted on Feb 16, 2011
What causes the water to stay running on a ge gsd series dishwasher?
The float is stuck it may need to be replace it is located on the front left side of the dishwasher
Apr 08, 2013 | GE 24 in. GSD1000G Built-in Dishwasher
Ge diswasher won't fill with water
When the program is switched on if there is no water flow despite the fact that the inlet flow is good, then the inlet valve is defective. it can be a failed valve if there is no action and if the flow is low then it can be a clogged valve. Remove, back flush and reset, if not replace, provided there is power to the valve.
Oct 22, 2011 | GE 24 in. Profile PDW7880G Built-in...
I have a GE GSD 5130 Dishwasher that leaks about 12 oz of water when it is pumping out the wash water and the rinse water. Its fine during the wash and filling cycle. Is it a seal problem?
Jul 15, 2010 | GE GSD5130 Dishwasher
GSD 3200 Series will not start, has a humming noise. I do not use it very often. Water started then stopped. I now have water standing in the bottom
Hi - My dishwasher 9 years old GFE GSD 3200 stopped working on wed this week 02/13/2013. Similar symptoms - water will not drain and nothing but a click and humming sound on all positions of the timer. Yesterday friday I called a repaurman who said it will cost anywhere between $200 - $250 if he comes in to fix it including all parts, etc. I thought of buying a new one for about $350 - then I thought let me try. I googled and got to this website ad a few others and followed the instructions of opeing the drain pipe below the sink and used a vacuum to suck - not much was found. Then I opened the two drain openigs inside the dishwasher - the ones at the back and found a few particels and a glass piece about 1/2 and inch - still the dishwasher wont work. Today I decided to check out te motor and pump. I followed the suggestion of rotating the motor blades and still no luck. Then I disconnected all pipes, pulled out the dishwasher in the middle of my kitchen, lay it flat on the front and opened the disposal section where there is a small blade that is connected to the spindle of the motor. With great difficulty, using scissors, a thin pin, a thin screwdriver, a thin nose plier, I tried to pull out all kinds of things like hair, wet paper, food particles, metal wire, etc. etc. After this the spindle of the motor started rotating much more freely. I then re-assembled everything and connected power and started it. Yahooo! It works as it worked before. I guess I lucked out. Just wanted to share with you good folks whose posts I have been reading since yesterday, 02/16/2013.
Oct 27, 2009 | GE Dishwashers
GE Profile Dishwasher Mod. #GSD 4430
I have the same problem right now. What is the casue?
Oct 19, 2008 | Dishwashers
GE Nautilus - GSD 4200J00BB
i try to reply to evertone what is it in regards to?
Sep 09, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Dishwasher GSD 4130 Y01WW skipping cycle
i beleive your right id change the timer
Feb 25, 2008 | Dishwashers
GE Nautilus 24" Built-in Dishwasher Logo
48 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
