Question about HP Pavilion dv2000t Notebook
I Have an HP dv2000 and my webcam only shows a black box, and it says that all the devices are up to date what can i do?
How do I locate the webcam on HP dv2000
you might need a messenger service to
IE:skype yahoo messenger........
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start right click on my computer select properties then device manager scroll down image devices you could see a yellow question exclamation mark? ! or a red X
right click to reinstall drivers or update driver W7 hope this helps
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question/exclamation mark ? ! or a red X a new driver will need to be installed
hope this helps
Mar 01, 2012 | HP Pavilion dv2000 Series Laptop Full...
I want to webcame drivers free download for hp pavailion dv2000
You can download the WEBcam and device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Feb 15, 2012 | HP Pavilion dv2000t Notebook
HP HP Pavilion dv2000 black screen
If you are using Windows XP:
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Oct 18, 2011 | ASUS Computers & Internet
I have an hp pavilion dv2000 it has a sound for i can hear that it starts-up but no display....what do u think is the problem plz help me....
If you can start in "safe mode", go to "control panel" then, find "device manager" and right click on it. Find "dispaly adaptors" in the list and click on the box at right beside this. It should drop down and how your device. Right click on it and you should see a window showing, "enable" or "disable". If it shows "enable", click on that and you should be set.
Mar 15, 2011 | HP Pavilion dv2000 Series Laptop Full...
HP dv2000-webcam displays black,lights on.
Common issue on this model. The problem is the GPU. Check out www.msbin.com you can reflow the GPU with that DIY guide.
Oct 04, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Webcam not working.
If it an external web cam you need to plug in to your computer , then install its drivers through CD.
Jun 18, 2009 | HP Pavilion dv2000t Notebook
Sound problem in hp pavilion dv2000 with window xp
well u need to tell me which series of pavilion dv2000 Note it's located on the label as in this example: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
Jun 06, 2009 | HP Pavilion dv2000t Notebook
Fullscreening problem
try up dating you video driver. you may not have enough video memory avalible try going to system properties under the advanced tab click dettings in the performance box then click the radio button fro best performance. your desktop colors and display will be very basic but then try to loading the same program. if that doesent work try reinsatlling that program again make sure that your computer meets the requirements. also make sure that you have enough ram also.
Mar 26, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
HP dv2000 laptop webcam
i would try to uninstall and reinstall your messenger software. restart after uninstall.
If it still fails, try to download the newest drivers for your webcam.
and also check if your webcam works with another messenging program like skype or msn messenger... your firewall on your PC could be blocking the webcam data stream
Nov 24, 2008 | HP Pavilion dv2000t Notebook
HP Pavilion dv2000t Notebook Logo
59 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
