Question about Kenmore Hepa 200 Air Cleaner
How do I clean the filter in a Kenmore Hepa 200
I have this air cleaner for several years but have not used. My neice needs it now(asthma) so I need to get it cleaned , but I don't know how to get to the filter. Help
SOURCE: kenmore AC2044-1 question ASAP!
If it says "Clean Cell Now" and it is a new machine, it is broken. I have six, yes six, of this model. They are all new and you shouldn't have to clean the filter/cells for a few months.
The way to clean is:
  1. Unplug
  2. remove the white cover
  3. remove the prefilter. Good time to clean the prefilter by removing the 2 retention clips and gently swing the prefilter outward. Clean or groom it with a vacuum. Use the upholstery brush. wash the prefilter in warm, soapy water. No Chlorine! Rinse clean with regular water. Wipe with a paper towel and let dry completely. It is okay to gently use a hair blower to speed up the drying process.
  4. Onto the Cell.
  5. The cell can be washed one of two ways. Either in a hot tub of water or in a dishwasher.
  6. Wear gloves to protect your hands. Never touch the fins or wires. It will ruin them and cut you up. Use the two handles.
  7. Use hot water and dish detergent.
  8. No chlorine and no abrasives.
  9. Soak for 10 minutes, then dip a couple of times to remove stuck dust/dirt/schmutz.
  10. Rinse with clean water.
  11. Allow to dry
  12. Allow to dry
  13. Allow to dry
  14. Okay to use a hair dryer to speed up process.
  15. Reinstall
  16. Power up
  17. Press and hold CHECK button for 3 secs to reset.
Thanks.
Posted on Jan 24, 2008
SOURCE: Kenmore Progressive 335
HEPA Filter Replacement Part No. 83376 and Pre-filter Replacement Part No. 83378
Posted on Feb 25, 2008
SOURCE: Kenmore air cleaner
I just bought the same model and also have the smell. My previous one did not so I returned the first unit and the second units smells the same. I called Sears Customer Support and they told me that it is probably due to the factory smoke test they do on each unit. He said let it run for a few days and it should dissapate. I went a step further and am trying a new filter and if this works he said call the store and they will get me a new filter.
Posted on Sep 24, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: The Kenmore air filter will not turn on.
Check the switch and make sure that it is getting power. You can also disconnect the connectors to the swiitch plug the unit back in and touch them together if that works then you know the switch is bad
Posted on Feb 14, 2009
SOURCE: Users Manual for Kenmore HEPA Air Cleaner Model No 85244
I have an kenmore air purifier and cannot locate where to find a replacement filter or manual for it? Can you help. It is Model # D42M32957
Posted on Aug 06, 2010
I have allergies will it me help me
Hello, Yes will help you, it takes the dirt, dust and pollins out of the air.
Sep 18, 2015 | Kenmore Hepa 200 Air Cleaner
Can I reuse the filters of air purifiers?
Yes, you use these filters repeatedly by cleaning and maintaining it properly. If you are cleaning it for the first time then it is recommended that you must take the advice of an expert.
Oct 01, 2014 | Filter Queen Air Purifiers
Can the hepa filter be cleaned?
The link below will show a page on how to clean and care for your air purifier. Although the Hepa filter can be cleaned multiple times, the manufacturer recommends you replace it every 12-18 months.
Bionaire Air Purifier Care + Cleaning
Jan 09, 2012 | Bionaire LC1460-U Air Purifier
How do I change the filter on the Kenmore 335?
According to the Owners Manual, here's what you need to do,
1.Turn the air cleaner OFF and unplug it from the power outlet.
2. Carefully lay the unit down on a flat surface with the Front Grille facing up.
3. Gently push in on Release Buttons on both sides of the unit, pull Front Grille out and away.
4. Remove and discard used HEPA filter.
5. Remove any plastic protective wrapping and from the new HEPA filter.
6. Set new HEPA filter into the air cleaner.
7. Install the Front Grille by engaging its tabs into the bottom slots on the unit. Then swing grille up and gently push in top to snap into place.
8.Turn the Air Cleaner upright and plug it into an outlet for
operation.
Hope this helped you. Please let me know. Thanks
May 04, 2011 | Kenmore 335 CADR Air Purifier
I had a honeywell hepa air purifier 50250 given to me as a gift with no owners manual! Is there somewhere I can get one? also, there is buttons on the top, one saying check filter and the other saying pre...
http://www.honeywellpurifiers.com/ssi/pdf/honeywell/50100-200-300-manual.pdf
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
PREFILTER:
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
HEPA FILTER:
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
Mar 29, 2011 | Kaz Honeywell Hepa Air Cleaner (50250) Air...
Are there filters that have to be changed and where do you get them?
Yes. You will have a prefilter and after that you will have a HEPA filter. Keep good maintenance on the prefilters which are not washable. You will need to check it once a month to see if it is time to replace. If you have good maintenance on the unit and change the cheaper prefilter, you will get years of service out of you HEPA filter. Bad maintenance means replacing the HEPA filter which is a good chunk of the cost of the purifier.
Sep 28, 2010 | Kenmore 335 CADR Air Purifier
I have a Kenmore Progressive 295 air purifier. I
Hi, are you sure about amazon?! I found your part there for 15$ (less than your budget of 25-30$). Take a look again here:
Amazon com kenmore charcoal filter. I hope this was helpful. Cheers
Jan 04, 2010 | Kenmore 295 Air Purifier
Apr 06, 2008 | Kenmore 85244 Air Purifier
Hi, filters can be found at amazon, click here and take a look: 1 HEPA Kenmore Air Purifier Filter Fits Kenmore models 83200 83202... I hope this was helpful. Cheers
Jan 18, 2008 | Kenmore 335 CADR Air Purifier
Kenmore Hepa 200 Air Cleaner Logo
70 people viewed this question
Top Kenmore Air Purifiers Experts
fordexpert
Are you a Kenmore Air Purifier Expert? Answer questions, earn points and help others
