Question about IBM 6262 Printer
1120 error code
76x3690 already replaced
Received E6 and F2 code. repair man replaced the control panel key padand it worked for a while. stopped working and got same codes E6 and F2. Repairman saw the control's behind the key pad needed to be...
Hello & Welcome to FixYa
F2-E6 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure then before replacing the sensor you can test it with a voltmeter for around 1100ohms....if it reads more then 1120 ohms then it needs replacement however, if the reading is between 1080-1120 ohms then it is the control board that needs replacement. However, after reading your problem it seems that the sensor is causing this and replacing it is recommended repair. Please get back to me if you have any other questions.
Kevin
Mar 15, 2011 | Whirlpool GBD307PR Electric Double Oven
Cano CLC 1120 error E004 0203 E072 0203 the machine turns on and off the merger does not light not heat MOTHERBOARD TESTED OK, FUSION SYSTEM TESTED OK, TRANSFER SYSTEM TESTED OK, WHAT SHOULD SPARE CHANGE...
Hi
This error is caused due to faulty thermister however; you can check the fuser unit for any jammed paper around the upper fixing roller and try to clean that area. After this is done try to clear the error by entering the service mode, to enter press Additional functions, #. Then go to #7 Printer and press OK, then go to #4 printer reset and press OK, yes= *. If the issue returns then replace the thermistor. Hope this helps...please post back for further assistance.
Daniel
Mar 03, 2011 | Canon CLC 1120 Color Copier
Error code of E005
A E005 code means that one or both of the cleaning webs need to be replaced and there counters need to be reset. Also, maybe the web out sensor flag is out of place
Apr 25, 2010 | Canon CLC 1120 Color Copier
Canon 1120 i have an error code whick is 0105
hi you must reset the counter in service mode *2,8* counter and put new value on mentioned parts
Dec 06, 2008 | Canon CLC 1120 Color Copier
Facing Problem in Canon Colour laser copier 1120
your a, b and c side sensors are bad they are found next to each other in the transfer drum
Sep 12, 2008 | Canon CLC 1120 Color Copier
Infoprint 1120 929 service toner sensor error code
The problem is caused by one of the following (normally it's the cartridge that's faulty, very common on Lexmark's and IBM Infoprints)
The toner sensor is not operating properly, the developer
drive assembly is not operating properly or the print
cartridge is defective
Jun 09, 2008 | IBM Infoprint 1120 Laser Printer
Canon 1120
I don't see where you've indicated the error code. Can't really help unless you describe more of the problem or the error code and any sub code displayed on the LCD display.
Nov 07, 2007 | Canon CLC 1120 Color Copier
Error Message E020, 0400 for canon CLC 1120 Color copier. please give your assitance
This error has to do with Toner concentration of the Black ( 04 ) part of the sub code. The "00" has to do with the reference level or signal value for black. Look to see if the Black toner sensor is soiled. You have to swing out the toner hopper assembly to access the sensor. You will see two thin gray cables coming down from under the control panel. Since you have access to both assemblies - toner and paper jam detect - carefully remove both and clean with canned air. Be careful since you are so near to the $800 drum. Replace both and test. If you still have problems and the drum is old, several years, and has over 40,000 copies on it, you may have to have the drum changed and I recommend a tech do it. Good Luck.
Oct 29, 2007 | Canon CLC 1120 Color Copier
22 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
