Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
I went to turn on my TV, and a big crackling/popping noise came on, and no picture or sound,
    Top Expert:
  • Sony Master
  • 14,553 Answers
First is if this happened unplug the set as you may do more damage if keep trying to power it up.
Inspect in order:
The lamp this model uses.
The power supply board for burnt or damaged parts
A visual inspection of the boards including the ballast that drives the lamp
No luck and then you have to consider based on your skill level here to have the set checked by a technician.
Posted on Oct 30, 2012
  • Sony Master
  • 8,617 Answers
Sounds like you may have an issue with either the ballast or lamp. I would check to see if you can isolate where the sound is coming from. You can get the replacement ballast and the Lam from www.tvrepairworld.com along with free instructions
TVtechmaniac
  • 140 Answers
SOURCE: Sony Wega
Sounds like the lamp - Sony XL-2100U part# A-1606-034-B
Posted on Apr 25, 2008
  • 26 Answers
SOURCE: Tv won't turn on.
Power supply is blown. Google it, check ebay (with tv model name) or just part it out and get a new one. You can also buy these used for really cheap off of craigslist.org
Posted on May 28, 2008
  • 184 Answers
SOURCE: sony wega kdf-50we655 went off and thier is a buzzing noise
Anything that sounds like electrical crackling will be coming from either the lamp or lamp driver/ballast boards or their interconnections. The lamp should be examined first as this is the most likely cause.
michtech
Posted on Feb 16, 2009
pilot210
  • 39 Answers
SOURCE: "pop sound", picture out, burning smell...?
Usually, yes. A bulb that has audibly 'popped' will be apparently bad if you pull it out of the TV (shattered). Other times this is a lamp ballast board.
Posted on May 18, 2009
  • 26 Answers
SOURCE: sony wega made a pop noise then went black
LAMP NEEDS TO BE REPLACED
Posted on Mar 05, 2010
TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here:http://www.discount-merchant.com/Samsung-BP96-01073A-lamp-p/samsung-bp96-01073a-lamp-oem.htm?Click=48173 .Have a blessed one!
Apr 02, 2010 | Samsung HL-R5668W 56" HDTV
Wavey color lines at bottom of picture. Crackling noises coming from back bad picture
Howdy;
The "crackling noises" from the back is causing the picture to distort. 1) Either locate source of "noise" and correct or 2) Call a Service Company and get corrected. I would recommend that you DO NOT USE TV until this corrected. It may cause a fire inside your TV.
Good Luck, Big Irish.
Nov 22, 2009 | Televison & Video
Sony rear proj; kdf 55
If there is no picture but sound is audible then replacing the projection lamp will do otherwise, the TV requires to be diagnosed for any other hardware damages.
Aug 27, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Nov 17, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Crackling Sound
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Jan 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
50 inch 1999 TheatreView Television
#1 When I turn on the TV the power button comes on then blinks 6 times then goes off for a few seconds then repeats the cycle. I have sound over my surround system during this time but no picture.
#2 My sound would crackle and pop every once and a while until now it does nothing. I have to watch it with the surround sound on.
Nov 26, 2007 | RCA HD52W59 HDTV Projection Television
Akai PT5598HD 55 in. Rear Projection
Something like this Id have someone who knows there way around electronics, a qualified tech or someone you trust really well :-) Does the crackling affect the TV picture at all ? My first guess would be dust and or dampness on the audio components. Sometimes this can conduct electricity across small pc chips and reak all sorts of havoc. I had an old Tomas electric organ once, and it actually caught fire because two speaker wires were rubbing together and eventually wore thru the insulation and shorted out, but it was also making alot of crackling and static noises. Try raising and lowering the volume low to high and high to low and see if the crackling noises gets worse. Some audio amplifiers put out quite a bit of power, so I wouldnt trust leaving the TV on without a fire extinguisher handy.
Nov 06, 2007 | Akai PT5598HD 55" Rear Projection...
Snap crackle pop
Check the Flyback, had same problem, replaced it and the unit worked good.
Oct 15, 2006 | RCA P46921 46" Rear Projection Television
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
