Question about Fujitsu Lifebook P8010 Notebook
My lifebook has a black screen but windows running
Backround light is not working
  • max carson
    max carson Oct 29, 2012
    Let me know if you repaired it.
  • Fujitsu Master
  • 7,627 Answers
It could be the monitor or graphics card or CCL are done. Or maybe a simple small switch that shuts-down the light when the lid is closed. I repaired a HP that the switch had "stuck" in the closed position, you could see the screen in the bright sunlight and see the windows OS. The background light,CCL in older machines, was not lit. I once had to access the rear of the monitor, in a laptop, to re-insert a loose ribbon cable that had jared loose causing the screen to go dark.
Posted on Oct 29, 2012
Testimonial: "I think you are close as it appears to be a mechanical problem. One of the screen hinges is loose, maybee its the cable that got stuck... What do you think?"
  • 1 more comment
  • max carson
    The CCL switch is loctated nesr a hinge, if that hinge is loose perhaps the switch is binding or being obstructed in some maner, look closely near the hinge in question, you will need a bright light and in my case a magnifying glass. It sound as if that's the problem.
  • max carson
    try to repair the hinge, tighten the hinge, or see if something is obstructing the hinge/lid fuction. Carefull not to "pinch" any wiring. Had the laptop gotten any unusal bumps or vibrations, god forbid drops from any hight?
  • max carson
    At the bottom of the screen just behind the bezel is the CCL. A small wire runs from the motherboard, to power the background light, via the left or right hinge areas.
Black screen one light on and the fan makes at noise
Try an external screen and see if the laptop boots successfully into windows.
Jan 08, 2013 | Fujitsu LIFEBOOK NH570 - Core i7 620M .66...
Problems with first use setup
LOL, ok does this lifebook have a CD Drive on it? If so you can try the Check Disk Utility.
But before trying the check disk utility, just turn it off and power it back up, it just might work.
If not try the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 02, 2012 | Fujitsu LifeBook AH531
The screen is black and the power light is flashing not constant and I don't think the hard drive is turning
If the screen remains black and does not show the BIOS window when powering up, coupled with the lack of hard drive power, then it sounds like you have a motherboard failure.
If your fans also do not come up, then that will confirm it.
Mar 09, 2010 | Computers & Internet
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Jan 30, 2010 | Fujitsu Siemens LifeBook C1020 Notebook
Black screen when turned on
first thing you do is to change the RAM (memory). if still black screen, you have to re-install or format again the laptop.
Aug 15, 2009 | Fujitsu LifeBook A3130 PC Notebook
Screen turns black with white dots when i turn on my xbox 360
unplug all cords and reconnect them firmly should fix problem
Aug 05, 2009 | Microsoft Xbox 360 Console
I have a fujitsu lifebook N6460 the screen flickers and goes out
Sounds like you back light or LCD inverter is going out, If you don't hear a whine then it is just the LCD screen, if you hear that whine then it is the inverter. An inverter will run 40-60 dolloars as opposed to and LCD screen which usually start around 100 and go up...
Hope this helps, if so please rate my solution accordingly.
Since it seems as though you dont move it very much you might be able to hook an external monitor up to it and using the Fn+F5 button swap it to use the external monitor untill you can get it repaired.
Mar 18, 2009 | Fujitsu LifeBook N6460 Notebook PC...
Settings/backround colour
Heres how you do it
Press Menu
Settings
Display and light settings
Display settings
Main menu style
Click on black
Save
Go back to main menu and see the change
Hope this works
Plz let me know
JonnieC
Feb 19, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Gray backround
Does your scanner software give the option to choose different modes...grayscale, color, black & white?? This sounds like it's scanning in grayscale....if you can change it to black & white, the background should remain white.
Jan 24, 2008 | Epson Perfection 1670 Flatbed Scanner
Fujitsu Lifebook P8010 Notebook Logo
278 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
