Question about Sharp CD-XP2200 CD Shelf System
Sharp cdxp2200 need free manual how to set channels
    Master:
  • 444 Answers
Manuals Online.Com. You can download manauls for no charge.
Posted on Oct 29, 2012
How do I set up tv channel manually for air installation
Refer its user manual for details. If you have't it with you now, try this link to download it for free. www.retrevo.com/
Electro help
Oct 20, 2014 | Sharp 70" Aquos LED TV - TVs & Home...
Sharp TV
Without the specific model number, I can't give you teh exact sequence, but you need to setup the set to only enable channel 3. Work your way through the menus to select channel 3 as your "favorite" channel. Disable all of the others. The set should then turn on as channel 3 at all times. Feel free to post the model number and I'll pass along more details.
Dan
Mar 20, 2008 | Televison & Video
HOW DO I REPROGRAM SHARP AQUOS TV
Clearly with the owner manual if needed but most programming for the consumer is done by with the remote hitting the menu button and looking for what you want---channels? look for antenna/cable in setup part of menu and select which you have---locate Auto program and engage and set searches for all available channels based on what is hooked up to it for signal.
If you need a owner manual GOOGLE works best with the model number of the set and "manual" or similar words.
Apr 02, 2012 | Sharp Televison & Video
How to adjust for best picture a Sharp Aquos Quattron 3D LED LCD 52 inch tv. I'm having problem maintaining perferred brightness. Also when initial turn on the screen goes to channel then shuts down and...
This sounds like a setting that can be adjusted. What I like about some of the Sharp televisions is the av mode setting (preset brightness/contrast adjustments). I am not looking at the manual for this model so I'm not sure if this is an option on this television. However with this being a high end aquos model there is free assistance available to you. You can register your television at aquos advantage and chat live with an aquos advisor at Sharp's Midwest Corporate Headquarters. The agent may advise you to call in if your television need and Industry Initialization because you have to be talked through it. I advise the chat reps initially because when you call you aren't able to speak with the Midwest Corporate Sharp reps unless your call is being escalated.
http://www.aquosadvantage.com
Apr 22, 2011 | Sharp AQUOS 52in. LE820 LED LCD HDTV
How do I tune the channels on a sharp cx34g3 TV. thanks
Yes, according to the manual, press PRESET, then VOLUME DOWN to automatically set all the channels the TV can pick up. Sharp has the manual for this model at http://support.sharp.net.au/CustomerCare/Operationmanuals/default.asp
Oct 01, 2010 | Televison & Video
Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
Feb 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp VCR vc-a41 tuning to TV
do you have cable? if yes both tv and vcr should be on ch #3 (to record).......ok no cable you are already set up look at tv right....just need to record..you need your vcr remote.....turn on vcr...press the menu...go to ch settings..auto scan will look for and lock in your channels...also make sure the air/cable selection is on air (unless connected to cable)....hope this helpful....feel free to rate
Oct 14, 2008 | Sharp VC-A410U VCR
Taping TV shows
You need to have an antenna in (from TV antenna or cable). Set the VCR to that channel and press RECORD. Or use the on screen menu to set up the recording time/channel
You really need to have a manual to find the step by step instructions for your VCR. Go to this website and search
for a VCR manual from Sharp. I was there and did not find the exact manual.Download a couple of ones that have similar model numbers and follow the process.
www.retrevo.com
Or call Sharp and ask them to fax/email you a manual.
http://promosearch.sharpusa.com/search/?sp-q=vc%20h954&sp-a=sp10009e61&sp-k=
Mike
Oct 31, 2007 | Televison & Video
Missing manual for - sharp VC-A560 VHS
I lost my manual and the biggest issue of getting this set up is getting the vcr to the channel you need for play back either channel 3 or channel 4. To change the channel you hold the power button and the tv/vrc button at the same time till you get the channel you want. Three flashing lights is channel three, four flashing lights is channel 4. every time the power goes out mine resets to channel 3 and will not play videos until I reset to channel 4. Hope that helps.
May 24, 2007 | Sharp VC-A560U VHS VCR
Sharp CD-XP2200 CD Shelf System Logo
48 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
