KEEPRITE MODEL N4A336 WHAT IS THE btu
FIND BTU
SOURCE: heat strip installation
It was quite simple, just installing the heat strip and my model only required removing the grill cover and mounting the element. The other optional installations didn't apply to my model.
thanks,
Don
Posted on May 27, 2008
muttandjeff
  • 359 Answers
SOURCE: model #uacc 030jas - BTU/H and SEER
that is a three ton unit and most likely a 10 seer rated seer rating are posted 6 months in cool and 6 months in heat to get the number on the unit if you are more interested in heating rating of heat pumps the aher or annual heating efficiency rating is of the most importance in this category the unit posted very well
Posted on Nov 24, 2008
koolbreezes
  • 540 Answers
SOURCE: need information on the btu
Hey, Back -on line , & the answer to your question is ...go to webpage or type in whirlpool model window unit mod acq189! This equals to 17,800 btu 15 amps 220 volts 3 speed.
Posted on Jan 08, 2009
  • 68 Answers
SOURCE: btu for dometic 59516.531
59516 is a Brisk Air 15000 BTU.
Thanks for using Fixya
Jerry
Posted on Mar 30, 2009
  • 232 Answers
SOURCE: BTU of an old Lennox condensing unit and A coil
38,000 btu AKA 3 ton
Posted on Sep 20, 2009
Testimonial: "Thank you for your help! Chong1238"
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
What is the BTU of modelM6FQ10F2A
the btu rating will be on the same plate as the model number
if there is no btu rating but a kw rating then there are conversion tables to work it out
for example a 2kw unit is close to 9000 btu and a 8kw unit is around 32000btu
May 23, 2015 | Heating & Cooling
Btu rate model ckl49-il serial 0506103005
Built in June of 2005, it has a BTU rating of 49000 BTU or 4 tons. This is a 12 SEER, R-22 cooling only unit.
Aug 10, 2014 | Goodman Heating & Cooling
I have the Model number and serial number but am unable to find the BTU's on mty furnace...Help please?
if you have the model number of the furnace, then you have the btu input of the furnace. The model number usually starts with letters, then the three numbers following the letters are usually the btu input of the furnace.
For instance if it said 075 then it would have an input rating of 75,000 btu/hr or if it said 125 then it would have an input rating of 125,000 btu/hr.
Hope this helps
Nov 16, 2010 | Heating & Cooling
How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Apr 21, 2010 | Dometic Rooftop RV Air Conditioner
Btu's
That air handler can accamodate different size coils. Look for the coil model number. Also you can look at the outdoor unit model number they should be matched up. There is generally a set of 2-3 numbers in the model numbers that will tell you. xxx036xxx is 36,000 btu. tonnage is 12,000 btu per ton so 36,000 btu's would be 3 tons. xxx040xxx= 40,000btu's or 3.5 tons etc.
Mar 16, 2009 | Heating & Cooling
Need information on the btu
Jan 08, 2009 | Whirlpool Heating & Cooling
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
