Question about Toshiba Satellite M30-S350 Notebook
Toshiba satellite M30 wont power up...
Hi, my laptop will not power up! I have charged it... I turned it on for like 10 minutes with out pwer cord in (battery said 98% full) and it switched itself off! Now it wont turn on at all and the yellow light(power cord light) on the front of the laptop is flashing in code: 2-3-3. Can you help me please -Matt
  • Anonymous Mar 14, 2014
    Power buton light just flashes 3 times and then shuts off. Laptop wont turn on. What can I do? I just fixed one problem
  • 71 Answers
You are using the wrong charger which is damging the battery or the battery is fulty
Posted on Aug 17, 2007
    Problem Solver:
  • 9 Answers
  • 385 Answers
Hi Your memory module might be faulty. Replace with another or try another and see if that helps.
Posted on May 16, 2007
SOURCE:
My laptop charger is not working
Two possible causes:
1)your laptop charger is dead or malfunction
2)your laptop dc jack is loose or malfunction
If you need to turn around your charger at one position so that the laptop will charge, that means your dc jack is dead. Otherwise your laptop ac adapter should be replaced.
If you need to purchase a new toshiba charger, you may click the following link to take a look at Toshiba Satellite M30 AC Adapter:
http://www.chargerbuy.com/replacement-toshiba-satellite-m30-ac-adapter-15v-5a.html
Nov 21, 2012 | Toshiba Satellite M30-832 Laptop Charger...
New battery HP g61 is fully charged but not working \
Maybe the AC Adapter Power Cord is not working. If you can't get on the laptop with the power cord then it is bad and the battery might be drained so you have no power source to power up the laptop.
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 30, 2012 | HEWLETT-PACKARD HP G61A50US 156 AMD Athlon...
T will indicate charging but it won't charge actor
Apr 23, 2012 | HP Compaq nc6400 Notebook
Batterie ne charge pas
Apr 02, 2012 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hi I have a Toshiba laptop model no.psl2xu-ookoof and it doesn't charge anymore so what do I do
If the laptop works only off the Power Cord and the battery is not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let the latop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in and remove the power cord. If it won't boot or shuts down then the battery is dead and needs to be replaced if the power cord is ok.
Mar 26, 2012 | Toshiba Computers & Internet
I have problem waking up my Toshiba C655 computer. Is there a setting that should be changed?
Worth a shot! Take your battery (bottom of device) out of the laptop for about 10 minutes, make sure the power cord is not plugged in, put the battery back, charge laptp back up with power cord, test it out.
Jun 28, 2011 | Toshiba Satellite L655-S5101 Laptop
I have a DELL Inspiron Mini. The power LED light is alternately flashing white and red. The netbook will not come on unless I have the power cord plugged in. When I do plug it in and power on, the...
This could indicate a bad battery. Try removing the battery and powering on the laptop. If the power LED remains white then you have a problem with the charging circuit. That means your battery could be defective or the battery charging circuit on your motherboard is faulty.
Feb 21, 2011 | Dell Inspiron Mini 10 Notebook
Toshiba satellite m30 bios password
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Jan 11, 2011 | Toshiba Satellite M30-S350 Notebook
Won't power on
Hi friends,
please check the dc adapter voltage,And battery also.
Ensure the adapter light is gong on, if ok condition, please measure the voltage.
Voltage will be E1705 DC Car Adapter (20V/6A 120Watts) check it.If not work please purchase from
http://www.amazon.com/Adapter-Inspiron-Latitude-Precision-Workstation/dp/B002BH8XAO
http://www.amazon.com/Dell-INSPIRON-Latitude-PA-10-Original/dp/B0034JWXBI
For battery
http://www.amazon.com/Lithium-Ion-battery-Dell-Inspiron-E1505/dp/B001E41PHI
Hope it will help you.
Dec 17, 2010 | Dell Inspiron E1705 Notebook
Acer aspire 5536 wont boot up
remove power cord, pull out battery, press and hold the power button for 10 full seconds. Wait 1 minute, place battery back in and then power cord. Then try it. This should work. If by chance it does not, check your memory chips because an effective one will prevent boot up. You can remove one at a time and try booting to see if one is faulty.
Aug 12, 2010 | Acer Aspire 5500 5570-2609 Laptop
Toshiba Satellite M30-S350 Notebook Logo
276 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
