Question about Lexmark 4227 Matrix Printer
LEXMARK 4227 MATRIX PRINTER PLUS CA DRIVE ERROR 637
ALL LIGHTS ARE BLINKING AND MAKES A SLAMMING SOUND AS IT STARTS BACK UP
3 Suggested Answers
Ajkill
  • 2035 Answers
SOURCE: Lexmark 4227 Plus Matrix Printer on Vista
Operating System Printer Driver Installation Procedure
NOTE: This procedure involves driver installation and port creation using Microsoft's Standard TCP/IP printing.
Step Action Click on Image 1 Click on the Microsoft logo start button. pattlnk_3212007_1551-vistastrtsm.jpg 2 Click on Control Panel. Image 3 Click on Hardware and Sound. NOTE: Classic Mode users can double-click directly on the printer icon. Image
4 Select Add a printer.
Click for Image 5 Network installation
Select Add a network, wireless or Bluetooth printer (for direct IP printing, network print queues - \computernameprintername, etc.)
NOTE: For printers connected via LPT1 (parallel), select Add a Local printer (e.g. IEEE- 1284 compliant printer cable, etc.)
Image 6 Observe Searching for available printers...
Upon completion, select (highlight) your printer, and click Next.
Your printer's IP address will be displayed under the printer description. Use the IP address obtained under Recommended above.
Available Windows Vista Search options:
  • Stop Search - Select this if you can identify your printer prior to search completion.
  • Search Again - If your printer does not appear,determine whether the printer is on the same segment of the networkand confirm successful communication with the printer.
HINT: Windows Vistawill only search the local subnet. If you are confident that theprinter is communicating over the network, select The printer that I want is not listed and try to add the printer's IP address manually.
Image 7 Observe Detecting the TCP/IP Port...
NOTE: Windows will automatically move to the next page when the detection is finished.
Image 8 Observe Detecting the driver model...
NOTE:
Image 9 The Printer name will appear, click Next.
Optional: If youwould like a distinctive printer name and do not want this printer tobe your default (i.e. main) printer, enter a different printer name and deselect Set as the default printer. Image 10 Observe Installing printer... Image 11 Upon completion, a Windows test page will print. You can verify the printer's installation by opening the printer's window.
Posted on Feb 23, 2009
  • 15 Answers
SOURCE: THE WORK ORDER MACHINE IS GIVING ME A CA DRIVE
Error: "637 Machine Check CA Drive Error"
Tear off any paper at the top of the printer.
Press the Load/Unload key.
Turn the printer off.
Press and hold the FormFeed button and turn the printer back on as you do so. Note: Hold the FormFeed button down for a full three seconds after turning the printer on before releasing it.
Press the Micro Up or Micro Down to change the value of the position "Pos = XXX".
Press the Tear Off/Store button to save the setting.
If needed, repeat steps 1-6.
Posted on Jul 09, 2010
Carriage slams into left side
In this case unplug the power supply from the Printer........... 1. Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........ Good Luck......
Feb 22, 2013 | Lexmark Z600 InkJet Printer
We had a power failure and now our Lexmark 2391 dot matrix printer will not print from the top of the page. i need to know how to setup/reconfigure the top of the page? thank you
  1. Push the ALT button and then the PARK LOAD button to back the paper out.
  2. Push the PARK LOAD button to reload the paper. The Ready light should now be blinking.
  3. Use the MICRO up or down buttons to adjust as needed, making sure that the top of form is set on the very first page that enters the printer. Typically, the top edge of the first sheet of paper should be even with the ribbon.
  4. When the page is lined up properly, press the START/STOP button. The printer will record the current position as the top of form and then feed paper to the tear off position.
  5. Use the MICRO up and down buttons to place the top of the paper at the tear off bar.
  6. After the tear off is positioned properly, press the START/STOP button twice to save the tear off position.
  7. Test the positions with a sample print job. If the alignment is still off, follow this entire procedure from the beginning again as needed.
Aug 08, 2011 | Lexmark 2391 Plus Matrix Printer
How do i run a configuration page from the printer?
Dear Friend,
Read this Guide Click Here(This may take a few time According to Connection Speed)
Hope This Helped you..Thanks for Contacting FixYa
May 14, 2010 | Lexmark 4227 Matrix Printer
THE WORK ORDER MACHINE IS GIVING ME A CA DRIVE ERROR IT IS A LEXMARK 4227 MACHINE.
Oct 06, 2009 | Lexmark 4227 Matrix Printer
The check light is on very faint all the time and cannot clear paper jam message.
Please call into our technical support team its free as long as parts are ordered thru us.
Thanks,
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Jul 02, 2009 | Lexmark 4227 Plus Matrix Printer
NOTE:
Feb 23, 2009 | Lexmark 4227 Matrix Printer
Carrier Stall is the error
Please do the following..
To check the cartridge carrier:
  1. Unplug the printer.
  2. Move the cartridges to the left by hand and then take them out.
  3. Try to print without the cartridges in the carrier. Do you still receive a Carrier Stall error message?
  4. If not, put the cartridges back into the carrier and snap them in at the back. The message should no longer appear.
If the power light on the printer is not blinking, the error message may be caused by a communication error. Do the following:
  1. Remove any other devices attached to the USB/LPT port.
  2. Uninstall the Lexmark printer.
  3. Connect the printer directly to the PC and ensure that power is being supplied to the printer.
  4. Reinstall the printer.
Thank you....
Jan 26, 2009 | Lexmark X83 All-In-One InkJet Printer
Lexmark x83 carrier stall
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:95:0:0&framed=&docid=ENUS22722&relevance=0
Use the above link to trouble shoot the problem.
Error: "Carrier Stall" ID:470
Feb 24, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark X1150
"Carrier stall" Error and the Carrier Slams in the Printer ID:ENUS12078 null.gif null.gif null.gif
If the printer carrier is slamming into the side of the printer, please try the following:
  1. Disconnect the power supply from the back of the printer.
  2. Open the front cover of the printer where the cartridges are located.
  3. Look for two black bands that span from left to right (they should have one serrated side and one smooth side). Just above the black bands there is a transparent strip; this strip is called the Encoder strip.
  4. Flick this strip lightly with your finger to make sure that it is running smoothly from left to right. You may need to do this two or three times. CAUTION: Do not pull the strip!
  5. Close the front cover of the printer and reconnect the power supply.
  6. If the problem persists, you may need to contact Lexmark Technical Support.
Nov 16, 2007 | Lexmark X1150 All-In-One InkJet Printer
Lexmark 4227 Matrix Printer Logo
76 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
