Question about Toshiba Satellite Pro A210-EZ2203X Notebook
My dtoshiba satellite pro a210 turns itself off, maybe because it gets too hot?
Shuts itself down, maybe its too hot?
  • 1 more comment
  • max carson
    max carson Oct 29, 2012
    How long does it stay on before shutting down?
  • Henry Hornsby Oct 30, 2012
    All day at first, then shorter periods of time. I purchased and am using a Belkin stand w/fan under it and now, no problems! Thanks for the help.
  • max carson
    max carson Oct 31, 2012
    Excellent, never use on a soft surface. needs that air flow.
  • Toshiba Master
  • 2,878 Answers
Suggestion: Blow system out with canned air. Those bunnies really pile up.
Posted on Oct 31, 2012
Testimonial: "This helped, thanks!"
  • 20 Answers
SOURCE: Toshiba Satellite A210 will not boot
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena8
Posted on Jan 03, 2010
  • 5 Answers
SOURCE: satellite pro a210 vista c0000218 error
boot the computer .....
Posted on Jun 17, 2009
SOURCE: My Toshiba Satellite A75-s206 shuts down by itself.
I own one and just came across the best solution.  I'm assuming by shuts off, you mean it just completely blinks out in an instant without warning - this is the processor getting too hot and shutting off to protect itself.  First you will make sure the fan & heat sinks are clean and working properly, then you will enable the power management features of the processor (Toshiba's power utility does not do this).
First, of course, get the canned air and blow out all the fans and heat sinks so they can work properly.
Next, download and install the RightMark CPU Clock Utility (search google for it).  It will take a little reading up to figure out how to use it, but here's the basics: 1. Go to the "profiles" page  a. under "Profile Selection" set it to use "Performance on Demand" for both AC power and battery (current and startup).  b. Then hit the "Defaults" button at the bottom, and then hit "Apply" 2. Now, expand the "profiles" tree (on the left side, there should be a little + next to it) and go to the "Performance on demand" profile and do the following: a. Click the "CPU Settings" button at the top. b. Hit "Defaults" at the bottom of the page c. For both AC power and battery, check "Use throttling", and then check all the indexes (0-7) in the list below. d. Below that, set the "target CPU usage level" to 75%. e. Hit "Apply"
If that all works properly, you should be able to go to the "Monitoring" page and watch your processor throttle up and down automatically as needed.  You should find that within a minute the fan gets a lot quieter because the processor is so much cooler.  Now that it's running properly, you can open the "Settings" page and check the boxes "start minimized to system tray" and "Run at windows startup", now it will run completely automatically, you won't even notice it except the fans will be quieter and your battery will last longer.
What it does: this laptop uses a Pentium4 processor, and by default WindowsXP does not manage the processor power settings on "desktop" processors.  Toshiba's power utility also does not manage these settings very well, so your processor is always running near full power no matter if it's playing a video game or just editing a text document.  The RightMark utility automatically adjusts the processor's clock speed, operating voltage, and throttle according to how much speed you need at any given moment.
Posted on Apr 08, 2009
Sebin
  • 712 Answers
SOURCE: My Toshiba Satellite L310 cannot shut down,
Try this, in the power option (control panel) and in one of the tabs there is an option called "turn APM (advanced power management) on", check it. I think this will solve the problem.
Posted on Feb 05, 2010
  • 6771 Answers
SOURCE: my satellite pro A 300 shuts down when pluged into AC power
The power adapter needs to be checked or better still sub out with a second power supply.
Posted on May 14, 2012
Toshiba satellite A210-19T just updated but laptop will not boot up just says 3 of 3 updates configuring please do not turn off your computer
when starting your laptop togglr F8 key and then start in safe mode and then go to system restore and pick an earlier date and follow instructions
Jan 18, 2013 | Toshiba Satellite Pro A210-EZ2202X...
My toshiba satellite a210 running vista now has upside down display. ctrl/alt/arrow will not resolve problem. Right click on desktop does not give required option to alter orientation.. any clues?
Try this method see if it works
1. Right click on the desktop
2. Click Properties
3. Click the Settings tab
4. Select a different resolution and click OK
Oct 10, 2012 | Toshiba Satellite Pro A210-EZ2203X...
I have a broken DC input jack on a Satellite Pro A210-16V. I am simply trying to source the spare part to fix it myself! Thanks!!!
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=3211
^Copy-paste in browser^
Kinda pricey, but it's the whole harness. No soldering required.
**Open up your machine and visually compare them! It SHOULD be right, but sometimes they're different even though they are for the same model.
Hope this helps!
Feb 23, 2010 | Toshiba Satellite Pro A210-EZ2203X...
Misc card stuck in slot, how do i get it out ?
1. Shut Down The laptop
2. Remove the laptop Battery ( Close the Lid , turn the laptop Up side down, search for a battery Lock tab, move it to Unlock position, You can see a Lock/Unlock mark on the Laptop cover, this will eject the battery from the slot.
3. Get a tweezers carefully pullout the memory card from the card slot, utmost care should be taken not to damage the card slot contacts
4. After taking out the card put back the battery make sure that it is in the locked position
5. Start the computer , try out the system
6. Verify the memory Card reader functionality using a proper card as per the maker guidelines
Jan 31, 2010 | Toshiba Satellite Pro A210-EZ2203X...
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell me...tc! :)
Jan 05, 2010 | Toshiba Satellite Pro A210-EZ2202X...
We are looking for lan card drives for satellite pro 2100. If you can help us...
Google
" Toshiba Satellite Pro M15-S406 Intel PRO/Wireless LAN 2100 WiFi Driver with Cisco/WPA 1.6.0.46 "
link
http://cdgenp01.csd.toshiba.com/content/support/downloads/calexico_wpa_xp.exe
Don
Jul 11, 2009 | Toshiba Satellite Pro A210-EZ2202X...
My display screen keeps going upside down
in the VGA options make rotations to normal
i hoe it will work
mvmanish
Jun 14, 2009 | Toshiba Satellite Pro A210-EZ2202X...
Restoring
Its f10 but be sure to press it repeditally, But toshiba normally come with a restore CD, so you need to be sure that it did not come with a restore cd.
Mar 28, 2009 | Toshiba Satellite Pro A210-EZ2202X...
FROZEN IN LOGGING OFF MODE
go to control panel , sounds - under windows sign off choose no sound for this event.
If all else fails depress the power button until it powers off (longer than 5-10 seconds) or remove battery. after restart go into bios setup and reset default values and re-start your computer
Don
Jan 18, 2009 | Toshiba Satellite Pro A210-EZ2202X...
Toshiba Satellite Pro A210-EZ2203X Notebook Logo
96 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
