Question about Sony Playstation 3 (PS3) Console
PS3 Error code 8002F314
My system automatically told me it needed updating,so I started it as usual.Unfortunately it never gets past 99%. I have tried the 'disconnecting AC...etc...' message instructions displayed on screen following the failed install, but yet again no joy!! Is anyone able to help me out? Please bear in mind I'm no 'techno person!' and my 8 year old lad is driving me nuts!!!lol Thanks
gamerfixer07
  • 344 Answers
SOURCE: PS3 update problems
Hello!!
Ok, no matter how you try to install the firmware it will always write it to the hard drive first before install. Now if it gives you the 800 error while downloading it's your hard drive and it may need to be re-formatted or replaced. If you get an error during installation, then therewas a misplaced piece of code during the download and it needs to be downloaded again.
BTW, the power button default reset is ONLY for the Video output settings.
Hope this helps. Good luck and happy gaming!!
Posted on Oct 23, 2008
treborswindl
  • 212 Answers
SOURCE: PS3 Update successful,install failed,systemrebooted,error8002F14E
On the playstation 3 site error code tool says this code is an issue updating the PS3 sytem software. Try to start with the hard drive uninstalled then try again installed. If that dont help i would format the hard drive in a laptop and see if it helps. worst casr scenario you could dissasemble the PS3 and unplug tha battery on the main board and see if that helps. Good Luck
Posted on Nov 24, 2009
  • 41 Answers
SOURCE: My ps3 is stuck on the system update screen on
Your PS3 hard drive may be corrupted. Do you know, send back to game shop is too expensive and waste your time. Learn the repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only hard drive problem, you can repair other red and yellow light issues as well. After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
Posted on Jul 20, 2010
  • 839 Answers
SOURCE: I'm receiving an update error
The most common method to fix PS3 error codes is to check all of the cables and connections to the system. This is standard with most electronics and can solve many issues relating to a weak connection. It's often the most overlooked and underappreciated method of fixing a system.
The next thing that you can do to repair PS3 error codes is to do a hard reset of the PlayStation 3 itself. This can fix most software update errors and restore functionality to your system. This is another method that is often overlooked due to its simplistic nature and ease of use.First make sure that all of you're audio video cables are plugged in to the correct ports and that your power cord is plugged in correctly. If this doesn't fix PS3 error codes then you can do a hard reset of the system itself. If your problem continues to persist after this you may need to work on the cooling system or repair a piece of defective hardware.
Click here to download repair guide if u need
Posted on Dec 22, 2010
  • 304 Answers
SOURCE: My PS3 streams iplayer, 4OD
Hi, Currently the Playstation Network is down due to hackers so updates, which come from the PSN, aren't able to be done currently. However streaming media, such as iplayer and 40D don't go through PSN which is why you can access them currently. Sony has said they hope to have the network back up by the end of the month so until it's back up you unfortunately can't update your games.
Posted on May 12, 2011
Failure to configure updates reverting changes ?
When (if?) you regain control of your PC, turn off or disconnect the Internet and disable automatic updates.
Then perform a system image backup.
Only perform manual updates from then on.
If you have a similar problem, restore the system image.
Aug 14, 2014 | Acer Computers & Internet
My hp a 1410n desktop powers up but shuts down after five seconds
#1 on the list for this is shut down from over heat due to CPU fan not running or CPU overheat. Check to see if your CPU fan is turning on when your system is powering up. If its not.. thats your problem (get a new fan)... Even if it is it could mean the fan is not properly contacting the CPU with thermal paste. If this is the first time you\'ve powered the system up, your next step is to go out and get some thermal paste and put it under the CPU fan, if you\'ve been running the system and this problem just cropped up.. skip the thermal paste, its already there. #2 Next possibility is BIOs power settings are incompatible with your hardware. For example the frequency on the CPU is set higher then it can operate and its over heating. Some systems will automatically shut down and restart with default settings others you have to get into and set to default. can you get into BIOS? Can you reset your BIOS settings to defaults? Check your mother board manual. #3 A compenent is shorting out your system and needs to be replaced. Is the system posting prior to shutdown (beeping once on start up?) If its beeping more then once that means something else and you should read your manual. If its not beeping then its a short somewhere and you can bet you have a bad part in the system. To identify which part it is you can either disconnect things (RAM, Drives, vid card, PCI cards,ect) one at a time, attempting to start the system after each one or you can take everything but the bare bones out and try to start it. I usually take all the RAM out but one stick and start by testing them. Your RAM is the most likely place for a problem in this situation. #4 If you\'ve striped it down and it still can\'t get a boot (with no post beep). You need to replace the mother board.
Jan 18, 2014 | Computers & Internet
Message on screen: Windows failed to start. A recent hardware... It then cuts to startup repair and attempting repairs. Have gone through this a dozen times only to end up where I started. What do I...
I assume you've already tried pressing F8 on startup to get into the start-up options screen (from there you can attempt "Restore System to a previous date.").
If you can't get anywhere with the F8 options, try starting up your system from a Windows Install disk. (Unfortunately, few computers come with this. Some have a Restore mode using either a special startup hot key or a set of optical disks, but this usually involves formatting C: and wiping out everything before setting it back to factory original state.) Once you have the Windows Install disk going, watch for the Automatic System Repair option to come up. This is different for each version of Windows, so I can't give you more than that other than to follow the on-screen instructions.
Note: virus infections can disrupt the hardware registry and produce the symptoms you have. By now, your backup registry is corrupted (that is why the automatic repair fails). I've found the easiest virus fix for a desktop computer is to remove the hard drive and install it as a second drive in a known-good computer, then have that system scan the problem drive for virus infections and file system corruption. If you have a 2.5" - 3.5" drive adapter and can remove the drive easily, you can also use this tactic on laptop hard drives. You will probably still need to repair the operating system damage.
Nov 14, 2011 | Computers & Internet
How do i renewer my Nokia software
You can update your phone's software or reinstall it by following the steps below.
1.Download Nokia Software Updater from the following link.( http://europe.nokia.com/support/product-support/device-software-update/update-with-pc ).
2.Install it on your computer along with the PC Suite provided with your phone.
3.Connect your phone via USB Cable to the computer in the PC Suite mode.
4.Backup your personal data to the Memory Card or your PC using Nokia PC Suite.
4.Double click and open the Nokia Software Updater (Make sure that the broadband connection is active on your PC)
5.Your phone will be automatically identified by the Nokia Software Updater and will find the available software updates.If there are no new updates available for your phone you can reinstall the software.
6.Click on the start button to proceed.Please don't try to use or disconnect the phone until update is complete and phone is restarted.
7.Disconnect the USB Cable when the update is completed and phone is restarted.You can use the phone as usual.
Jun 21, 2011 | Cell Phones
Blackberry 8520 curve was reset app 523 error what i do
Connect to the Desktop Manager. If your device still having problems. Wipe it with BBSAK. Then insatll software from Loader application.
May 04, 2011 | RIM BlackBerry Curve 8520 Smartphone
Fisher price kid tough music player is displaying a flasing exclamation point... please help!
I went to www.fisher-price.com/kidtough/ re-downloaded the software and installed/launched it but didn't get any updates. So I disconnected the player but left the Fisher-Price software running in the background and started doing other stuff. When I went to shut down my computer, I was about to shut down the Fisher-Price software when I noticed the message prompt "THERE IS AN UPDATE TO THE SOFTWARE, WOULD YOU LIKE TO DOWNLOAD IT" I was so excited to see the prompt and I hit OK. It told me to connect the player to the computer before starting so I did and it automatically did an update. It appears to be working now! Sure hope this doesn't happen again!
Mar 05, 2011 | Play Inc Fisher Price Music Play and...
I have a 1999 Toyota Corolla and electronic key system has only locking button. The unlocking button is lost and I was told I need to buy one online. Last night after coming home I have locked with...
I am having the SAME problem with my 99 Corolla, Still searching for a way to disable the factory security system, for the last two years I have the vehicle hotwired through the headlights to start it. (1 wire to battery positive, 1 wire to starter hot lead, touch them together.) unfortunately this has proven very dangerous as the vehicle will start even in gear, and take off without a driver. additionally, because the alarm is going off continuously, the battery dies if not disconnected after every use. I found the fuse in the relay box that disbles the alarm, and the car starts fine, unfortunately, It it also the fuse for the alternator, so that solution will not work either. If anyone has found true way to disable the system, PLEASE offer your suggestions!
Nov 01, 2009 | 2003 Toyota Corolla
Aspire 5610 won't go past stage 3 configuration update
If you need to reformat the system, you can usually access Acer's built-in eRecovery by pressing Alt-F10 at the splash screen. Just bear in mind that restoring the system to factory specifications will erase the contents of your hard drive, so please ensure that your important data is backed up before doing so.
The "Vista Boot Loop" is a known issue though, but does have a solution, see here
If you are unable to use the repair portion of those steps, there is another workaround, but requires the use of other bootable media, such as Ubuntu (which you can download for free here). From there, try following these steps to get the pending.xml file renamed (see Comment #12 specifically, when using Ubuntu)
If you can solve it using the latter method, then you can get back into the system without having to reformat the entire hard drive and starting over.
May 08, 2009 | Acer Aspire 5500 5570-2609 Laptop
Sony Playstation 3 (PS3) Console Logo
447 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
