Question about GE Spacemaker JVM1640SJ Microwave Oven
GE jvm1653sh01 range lights won't turn off
Just bought condo with this microwave. One of the two range lights was out and the other was unscrewed so it wouldn't come on (figured out why). I replaced the bulb that was burned out and screwed the other all the way in. The range lights stay on and won't turn off. I set the time and date after plugging back in and the light buttons won't do anything. Suggestions?
  • 2 more comments
  • Eric Bailey Oct 29, 2012
    To confirm, the model number is jvm1653sh01. Not sure why fixya added the other model number
  • Eric Bailey Oct 30, 2012
    I bet switches aren't terribly expensive. Could you provide part numbers for both switches, where to buy, and instructions for replacing them?
  • SD Tech
    SD Tech Oct 30, 2012
    Google with the model number to locate the numbers and the parts is my suggestion
    Looks like this is the diagram: http://www.searspartsdirect.com/partsdir... I only see two parts that say anything about being a switch. This onehttp://www.searspartsdirect.com/partsdir... and this one: http://www.searspartsdirect.com/partsdir... Are those the two switches you are referring to?
    Top Expert:
  • GE Master
  • 14,553 Answers
Got a short at or in the switch assembly that is causing this and unit would have to be unpowered and checked to see if one or both switches are bad.
Posted on Oct 30, 2012
catriver
  • 878 Answers
SOURCE: We own a GE Microwave jvm1653sh01
The first thing I would check would be the magnetron TCO (thermal cut-out). This is a little safety devise that protects the magnetron in the event of overheating. These can act up even without overheating. I believe the nuetral side of this TCO runs through the board, and therefore the flickering and shutdown. When the TCO cools, it resets. If it were the door switch, you would blow the fuse and wouldn't be able to set the time without changing the fuse. There are other cavity thermostats that could be the culprit but my quess is on the magnetron TCO. When working with microwaves always unplug the unit and discharge the capacitor. This is high voltage..Good Luck
Posted on Jun 12, 2006
  • 579 Answers
SOURCE: Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
Posted on Jan 02, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Posted on Sep 16, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE JVM1440BD Microwave hood lights don't work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
If your relay is bad and you want to replace it yourself, it is part # 3501-001050 and you can find helpful exploded view diagrams of your microwave and order that part here.
Be sure to also do any needed circuit board repair with 30AWG wire to prevent it from doing worse damage if another bulb shorts.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 09, 2009
I have to replace microwave light bulb. It's GE counter top Microwave JES1142PSE model. I hace opened the microwave and have located the bulb,but could not unscrew.I don't know needs to be pul
That exact model number is not showing up, so you may want to check the tag on or in the unit and look here for parts.
Most of the models in this class of ovens were not really made to be serviced, so GE only makes the turntable parts available.
It also sounds like your bulb is an assembly - the socket and bulb and one piece.
So your local appliance parts store should have a generic replacement for it. You should take the bulb.
Be careful when disconnecting the leads.
Apr 14, 2013 | GE Microwave Ovens
Can't turn on light
That can usually be economically repaired. Details are here.
Jan 09, 2013 | Maytag 2.0 Cu. Ft. Over-the-Range...
GE profile mirowave JVM1350WW002 - won't heat
There three area's of concern, magnetron, "heats food" the high voltage diode, "sometimes crack" the high voltage capacitor, "usually shorts"
Mar 24, 2012 | GE Profile Spacemaker Over-the-Range...
My GE JVM1750DM blew an internal breaker or fuse when I attempted to remount a lamp lighting the stove top; it had fallen out of its mount. Where is the internal reset or breaker located, and how do
There are fuses inside the unit. No internal breaker. A lot of the time that damages the main circuit board too. Blowing the trace that supplies the power to the bulb off of the board. will probably need a new baord, or someone to repair that one.
Sep 24, 2017 | GE JVM1750DM Microwave Oven
Range lights on a over the range GE mirco wave won't work. The touch pad works and says the lights are on but no lights
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
Or you can buy and install a new control circuit board (smart board) from the Pros here, our favorite supplier.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
Oct 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Vent motor turns on, but does not draw air in as it should...
the vent tube in back may not have been changed over they can be vented or ventless but you must switch the flap in back you had the answer in your question ... good job,,..lol
Jan 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
103 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
