Question about Electrolux Washing Machines
I am looking for the program chart/list of Electrolux EW1278F t hat you could find at the detergent drawer handle (hided behind the clear plastic wall) and also the detergent drawer itself. If the sto
I am looking for the program chart/list of Electrolux EW1278F that you could find at the detergent drawer handle (hided behind the clear plastic wall) and also the detergent drawer itself. If the stock is there, how can I order from The Netherlands? Meanwhile, cause I need the chart so badly, would someone pleased to make a copy or type and send it through my email address : "netty.sh@gmail.com". I appreciate it. Thank you so much.
  • yadayada
    yadayada Jun 27, 2017
    "Hided" no such word.
SOURCE: detergent drawer
Sorry I can't respond to questions under the header "'Generic Problem for all washing machines" because the focus it is too broad.
Posted on Jan 26, 2008
dutchman05
  • 487 Answers
SOURCE: no service manual
water filters in the hose attachment at the machine cloggs up. Sometimes fast. take off hose and clean the filters.
This is from whirlpool:
FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Replace failed component.
Posted on Jun 08, 2008
ngfam1
  • 639 Answers
SOURCE: need instruction manual for FL828 Zanussi
Dear Friend,
ngfam1 at your service
I am happy to assist you!!!
At this site you may find where to go to get it!
http://www.user-service-manuals.com/zanussi/FL.shtml
OR
GO ONLINE TO THE MANUFACTURES WEB SITE AND DOWNLOAD OR ORDER THE MANUAL
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
You will be fine now!
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
  • 2692 Answers
SOURCE: software jvc gz mg22as, please send me to download
No software software downloads available. Specifications, Manual and guide.  Replacement CD available by purchase from JVC.
http://support.jvc.com/consumer/product.jsp?modelId=MODL027855&pathId=119&page=3&archive=true
Posted on Jan 29, 2009
  • 92 Answers
SOURCE: User Manual for Sony Trinitron KV-25DA55
try downloading from sony.com
Posted on May 20, 2009
How do I completely clean the Electrolux Perfect Temp Drawer? Gravy has gone in-between the plastic parts.
Hello Gayle, thank you for your post!
I understand that gravy has fallen into the perfect temp drawer on your Electrolux refrigerator. In order to assist you further I would need to have the model number of your refrigerator. You can locate the serial tag (which lists your model number) on the inside wall of the fresh food side. With that model number I can research to see what additional information I can provide you with. I look forward to assisting you further. -Matt
Jan 02, 2016 | Electrolux Refrigerators
How do you remove the clear plastic cover on the crisper drawer of a Samsung Refrigerator Model RF4287HARS
Yes, the clear plastic front of the crisper drawer can be removed for cleaning. Using a thin-bladed, flat-head screwdriver, pry out at the clear plastic slot at the top outside of the drawer, where the clear front piece meets the tab of the white handle piece. Pry out just enough to get the blade under the slot, and then pry inward at the white tab to release the clear front piece at the top of the drawer. Repeat this procedure on the opposite side, so that the plastic front piece is free at the top of the drawer. Next, turn the drawer over on a counter and work the blade of th screwdriver under the tabs at the bottom of the front plastic piece. These should release easily. Notice the bottom edge has three slots and two sections that are interleaved with the bottom of the drawer. Once you have all three pieces separated, the while u-shaped handle piece, the plastic front panel, and the drawer itself, you can clean and dry them easily. To reassemble, first snap the while handle into place on the drawer, by lining up the top of the drawer to the while handle part first. The top of the handle fits over two plastic extensions on th top of the drawer, then swings down to cover the front sides of the drawer. Then reattach the bottom of the front plastic panel to the bottom of the drawer, interleaving the overlapping parts and snapping the tabs in place. Then snap the top of the front panel over the white handle at the top of the drawer, and you are done!
Dec 04, 2014 | Samsung Refrigerators
Leaking clear water from behind the faceplate
Most likely the lid seal and/ or the detergent dispenser seal is leaky. Do not operate the dishwasher in this condition as the water can cause electrocution because the mains voltage comes up to the drawer front panel. Most likely it is the detergent dispenser seal.
see this diagram.
http://spares.bigwarehouse.com.au/images/files/18816_a21ebb5ac093d66472cef9bd1e8f3b12.pdf
Feb 16, 2014 | Fisher and Paykel DD24DCX6 Dishwasher
Electrolux frontloader washer detergent drawer won't stay shut
Hello royal37 - Hi - The dispenser drawer could either be cracked or have a broken latch due to interference between the drawer front and top panel. Contact a professional to move forward accurately and might possibly need to order a service kit (PN: 137146000/part number may be different depending on your model number).
Feb 13, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Electrolux washing machine EWG14440W THE WASHING MACHIN DOES NOT TAKE THE FABRIC CONDITIONER FROM THE DRAWER WHEN WASHING, GETS LEFT BEHIND IN THE DRAWER
Electrolux washing machine EWG14440W This video will show you how to keep your soap draw clear and how to service the parts Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Sep 12, 2011 | Electrolux Washing Machines
Fabric conditioner section in draw always full with water after cycle has finished
Detergent drawer is clogged with soap. to remove look for small plastic clip on the inside above the detergent drawer which needs to be released. Remove detergent drawer unit and wash thoroughly under running water, or bucket. Replace and problem should be solved until it gets clogged again.
Jan 15, 2011 | Bosch Classixx WFC 2465 Front Load Washer
IT IS GIVING ME CLEAR MISFEED (A) I DID THAT AND IT STILL TELLS ME TO CLEAR MISFEED, I EVEN TURNED AND UNPLUGGED IT AND CLEARED AND CLEANED AND STILL HAS THAT MESSAGE
you may have a bad switch. sometimes paper hides behind the drawer. remove your paper cassettes and look begind them for a paper
Jan 06, 2011 | Office Equipment & Supplies
Have a Miele W320, during the rinse part of wash cycle, water pours from underneath the detergent drawer. What can I do to stop this happening?
Is the drawer gunged up? Are you using too much detergent?
Remove the drawer, and clean it with hot water and a brush.
Look into the empty drawer slot for any blockages and remove.
Replace drawer, try pouring hot water into the open drawer to try to dissolve and clear any blockages.
Consider using a dosing ball and adding detergent to the drum.
Feb 18, 2010 | Miele W320 Front Load Washer
Ddo problem
Hi
Thanks for using FixYa. Error DDo means dispenser drawer open. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch to "tell" the machine that the drawer is closed. That magnet might have moved from it's place and that's why you are getting error ddo. magnet is part key number 51. Pull the drawer out and check on the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Please check this link for details(part #51)--
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/5995430112.pdf
You can glue the magnet back and the error will go way.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 17, 2009 | Frigidaire GLTF2940ES Front Load Washer
Detergent Dispenser
The syphon tube needs cleaning by poking something through it to clear blockage.
Jan 10, 2008 | Hotpoint WMA76 Front Load Washer
Washing Machines Logo
43 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Chris Hall
Chris Hall
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
