Question about Frigidaire Ovens
Broken stovetop I accidentally shattered the cooktop of my Frigidaire FEF364DWA glass cooktop stove. Where can I purchase a replacement part? Would be be less costly to just buy a new stove?
  • 163 Answers
Hi!!! With my experience some of them glass tops are very expensive check everywhere before you buy it and the labor to install one is high also.Good luck..
Posted on Jan 03, 2009
  • Jon Henderson Oct 27, 2011
    I just replaced my Jen Aire glass top - $300 ! Pretty good compared to a new Jen Aire for over $2,000. If you are handy at all, the replacement is easy and it took about 30 mins to get everythign off and back together. Just remember to make sure all plugs are back in under the glass befire you screw everyhting back together.
Removal of inner glass door.. how.??
Open door to about 15~20 degree angle, pull up on door and totally remove from stove. Lay face down on flat surface. Now can access all screws to separate the inner and outer panels and to replace the glass. To return to stove, use locking pliers to pull the door hinge stubs out to their 15 degree open position, slide door on and close.
If glass not broken, just can't see through, no need to remove door or glass. Use glass cooktop cleaner, apply and let soak 3 minutes, then use new single edge razor in holder to shave off the baked on grease. May have to repeat 3x then switch to glass cleaner and clean again 3x, should be quite clean and clear unless seal has failed on the double pane thermal glass and internally obscured in which case the only cure is to replace the glass... return to paragraph 1.
Sep 20, 2015 | Ovens
Glass top on my Kenmore oven shattered- is t repairabe
Probably cheaper to replace whole oven try insurance if u have its an accident so insurance may pay if u have.
Oct 16, 2014 | Kenmore Ovens
My outer glass shattered on lower oven
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Dec 11, 2010 | Ovens
Frigidaire Self Cleaning Electric Oven - Inner glass shattered, need part and instructions for door
It isn't that tough to change the glass assembly. Most of the Frigidaire have 4 screws that hold the front of the door to the inner part- sandwiching the glass in between. It is only sold as a unit- 2 glass pieces, assembled with an aluminum frame. Call All brands Appliance parts at 508-587-7100 and they'll get the part out to you. (Tell them Greasy Wheels sent ya, they'll take good care of you.) The most common reason the glass breaks, is a scratch in the glass. Sometimes it's just a dragged pan, other times it's from cleaning it with a sharp instrument. Don't do that....
Oct 24, 2017 | Ovens
Replacing a glass cook top
I have the replacement cook top that you need (part #WB56T10165). I work for a GE Appliance distributor and will sell you the part for WAY less than list price. The item is an unopened, genuine GE replacement part.
Let me know if you're interested.
Jan 09, 2008 | Ovens
Ovens Logo
344 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
