Question about Emerson Audio Players & Recorders
Clck radio will not work on batteris
Will not run on batteris
    Master:
  • 444 Answers
There is probaly a switch some where on it, To change it over to (Battery) power.
Posted on Oct 29, 2012
Lost car radio code
The only CLARION code that can be calculated for free is if you have a BARCODE with a SERIAL NUMBER beginning with C700000........
You can see here serial_locate
Sometimes, when you call to the dealer with the VIN and Serial number, they can send it the code (sometimes need pay for this).
Hope helped.
Apr 25, 2010 | Clarion Clck Sirius Satellite Radio...
The driver's window lowers a little bit each time the door handle is pulled. The window is suppose to lower approx. 1" when you're opening the door to clear the convertible top but it won't raise back up...
Probably your battery is bad. either charge or replace that and then learn the windows again. (have you got your radio code before removing battery?) to learn the windows do them one at a time with door closed. hold the down button you hear a clck a few seconds after it opens fully now hold the up/close button and again wait for the click. easiest is to hold the button pressed for 10 secs after the windo has fully traveled down then send it up and again 10 secs after it stops moving.
Aug 25, 2009 | Jaguar XK8 Cars & Trucks
Problem audio
hi im josh in phils. friend may i help you?
Audio is not working. Friend i guess you already know that to make the pc audio work is you need to install or run the audio driver separate cd if you are using with audio cards.and mainboard driver if you are using audio built in on board. then if you haven;t did it so you need to do it.but if you have already installed a such then it is still not working then here are some suggestions of what to do.
1. Go to audio setup utility in BIOS and have the audio select enabled.if done
2. try to run the cd audio first while installing some software right after formating or installing O.S. because there are some mainboards that requires the audio to be run first before the others and you failed to do that audio will not work.
3.There are mainboards or pc such as IBM netvista IBM, COMPAQ, other branded etc.and especially your DELL. that even though you have installed the software it will not work automatically you need to run it first manually to work here: you go to the my computer ryt clck thenn device settings then update/install driver clck then browse go to the drive c where the software audio driver installed find the run or setup then hit it let it run for a while then after press ok reboot your pc. then at start of wndows you wl hear a sound it means successfull installed you can now play audio progrms. thats all friend base from my experience of such many units. good luck hope i helped you.
Mar 07, 2009 | Dell Inspiron 1501 Notebook
Unable to hear the sound after formatting
hi im josh in cebu phils. may i help you? friend the sound driver or IBM is built on the cd of the motherboard try to install it. then after installing im sure it still doesn't work because even the software is installed but it is not running. to make it run and you wl hear the sound. you need to update the driver manually. go to the my computer right clck device manager then clck the icon sound driver then update/install driver./if appears brwsing window.look for the sound folder in the drvce c then clck the run/setup wait until it completes.then reboot your pc.it will solve your problem just do it good luck hope i helped you.
Feb 27, 2009 | IBM (03R0329) Motherboard
My m/b is working ok but there have not sound msi 945 gcm5 m/b
hi im josh in cebu phils. may i help you? friend if no sounds working. you need to install the sound card driver built in if you are using sound card built in mainboard or cd if you are using separately. or if it still doesn't work even the software driver is already installed you need to manual setup the software becuase it was installed in the pc but not running to run it go to my computer device manager then click the icon sound then clck update/install driver if browse locate the driver installed in the c folder.then clck run/setup wait til complete then reboot your pc. it will solve the problem. good luck hoped i helped you.
Feb 27, 2009 | MSI 945GCM5 Motherboard
Have not vista sound driver
hi im josh in cebu phils.may i help you. if the sound card doesnt work even you installed the driver.using vista. Friend to solve this problem you need to install manually your audio driver. go to my computer right clck then device manger then clck sound card icon then go to update driver then browse c prgram files.then look for sound driver then clck the run or setuo inside the folder. then ok. your problem is solved. good luck vote for me so that i wl knw if i helped you.
Feb 22, 2009 | Gigabyte GA-K8NSC-939 Motherboard
My acer is not responding
ther is a corrupted file in your operating system you need to run again your winxp cd if this is your o.s. then clck repair in order to solve your problem.
Nov 25, 2007 | Computers & Internet
64 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
