Question about Kenmore 24032\24036 Top Load Washer
CAR KEYS IN MACHINE
I HAVE A 600 SERIES KENMORE WASHER. MY WIFE THINKS SHE WASHED MY KEYS. IS IT POSSIBLE THAT THEY ARE IN THE MACHINE SOME WHERE? A TRAP, UNDER THE AGIATAOR ETC? IF SO WHAT IS YOUR BEST GUESS ON WHERE THEY MIGHT BE IN THE MACHINE??????
    Novelist:
  • 148 Answers
If the keys are in the washer they woud be around the agitator It is unlikely that keys on a ring would be under the agitator but if youwant to check you can do the following:
FIX
1 Unplug from the wall
2 remove the plastic cap on top of the agitator hold one of the blades of the agitator and turn the top area counter clockwise and the top should unscrew allowing you to lift up the bottom blades
3 Reverse procedure
Posted on Jan 03, 2009
Kenmore 600 washer
Have you cleaned the Filter in the Washing Machine? Sears should have a help center to answers questions.
Mar 31, 2014 | Washing Machines
Kenmore 600 series washer
The dial probably was rotated counterclockwise. That can mess up performance.
Jan 26, 2014 | Washing Machines
Kenmore 600 series fabric softener dispenser clogged
How do I make the waher Kenmore drop the fabric softener
Aug 25, 2012 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
How do i determine if my switch is working on my kenmore 70 series washing machine
i think there is some problem in wiring of spin and drain. thats y it works only for washing. current stops after washing. or otherwise click below link and check the manual may be its timer problem
http://www.askmehelpdesk.com/appliances/kenmore-washing-machine-70-series-repair-manual-479481.html
http://www.askmehelpdesk.com/appliances/kenmore-series-70-washer-manual-445690.html
Jan 04, 2012 | Kenmore Washing Machines
Kenmore series 70 washer will not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
I have a kenmore 600 series tl washer. it will only fill with water very slow
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 09, 2011 | Kenmore 98702 Stacked Washer/Dryer
I have a kenmore 80 series washer (11028802890) that won't agitate or spin. Does this machine have a belt or is it the coupling? I would like to try to fix it myself, if possible.
Good for you. I don't think this model has a belt, I believe it is a direct drive with a coupler. Most likely, if you can hear the motor, the coupler has done it's job and sheared. The coupler is 20 bucks and my wife and I just changed ours out. I need the entire model number and I will get you the part schematic and we will get you going.
Jan 27, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Wife likes to check the wash cycle on the Kenmore
See the following Whirlpool / Kenmore Service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
From a liability standpoint, I cannot recommend bypassing the lid switch except during troubleshooting.
Mechanically it's simple to jump the two outer pins but again, I'd recommend against it from a liability and warranty standpoint.
Jan 20, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
135 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
