Question about SPARKLE Computer GeForce 7300 GT, AGP Graphic Card
No detect video from PC to TV
After I insert geforce 73000GT card in CPU, I connect cable to TV and the result are not detect at PC. I can't solve this problem.
  • wishmaster10 May 11, 2010
    did you change the video settings to tv in your computers video settings
  • 47 Answers
Right click on the desktop then click settings.. then click advanced.. then there should be multiple tabs pertaining to the tv setting.. make sure the tuner in the card is set to the appropriate setting.. and format... usually NTSC for use with a TV a a display.. then ensure that you successfully clicked the second monitor in the display/ settings tab then check the box that say says "extend my desktop to this display " and then you tv should hav an image
Posted on Jan 09, 2009
Can't install drivers for GeForce GT 430. "Graphics Adapter Not Found."
I am assuming that your PC is working alright connected to the onboard graphics port.
Make sure any supplementary power connectors to your video card are in place, and the card is firmly inserted into the PCIE slot.
If you try these two items with no results, you might try installing the card in a known working PC. It could be a problem with the card itself.
Mar 24, 2012 | PNY GeForce GT 430 Video Card Bundle
Radeon 7000 series
you can connect your video card to your tv by either a dvi to hdmi cable or s-video. There is no need for 2 graphic cards unless you want to connect more then 2 monitors.
Feb 23, 2012 | Nvidia GeForce FX 5200 Video Card Graphic
Hello, I just bought my ECS Geforce GT430 (Model: NGT430C-1GQR-F). I put it on the PCI-E slot, conected the crt cable and turned de PC on, he GPU chassis fan started normaly, but there's no image on...
First off all please make sure that your crt is connected to your graphics card directly not your onboard crt port.
after this please go to your bios and choose your pcie card as your default video card.
Once done please save all sitting and restart your pc.
Hope this solve your problem.
Regards: Kartikey
Apr 14, 2011 | EliteGroup ECS NGT430C-1GQR-F GeForce GT...
I have recently assembelled a nvidia geforce 5500 agp grphic card. how should i make my pc boot from that hardware
its automatic. your motherboard will automatically detect your nvidia the moment your insert the card to the video card slot and it will automatically disable your built in video card.
Mar 27, 2010 | Nvidia GeForce FX 5500 / 256MB DDR / AGP...
Problems with 8400GS graphics card
First, you need to be sure you have installed the correct drivers for the card that corresponds to your OS.
Second, you need to go into the control panel (assuming you are running Windows of course) and tell the computer you now have a new graphics card installed and to use it instead of the default one detected when the OS was installed.
Reattach the monitor to the GeForce card and reboot. All should be OK.
Jan 06, 2010 | HP NVIDIA GeForce 8400GS - Graphics...
TV-out problem on my geforce fx6600 graphics card
boot into safe mode (F8) and uninstall the video card.
Dec 09, 2009 | Nvidia GeForce FX6600 512MB PCI Express...
My desktop gateway 3 series does not have a video card.....I would like to add one....is it hard to do so ??I want to buy a geforce 9600 or greater...
It is not so difficult as it seems to be.
First ensure that your computer meets the system requirement for installing a particular Video Card. You can get these details on the box of that card.
Once you are ready with all the details and the compatible card, follow the instructions as under:
  1. Turn off your computer and disconnect the power chord
  2. Open the Cover of your computer Tower.
  3. Disconnect the monitor cable from the Onboard VGA
  4. Locate the compatible card slot.
  5. GEForce 9600 would require a pci express slot
  6. Match the notch on the card with the Card slot and insert the card with a slight push.
  7. Fix the card to cabinet with a screw on top
  8. Connect the Monitor cable to the newly installed Video card
  9. Close the cover
  10. Connect the Power cable
  11. Restart the computer
  12. Your operating system will detect the new Video card and prompt you for drivers
  13. Installed the necessary drivers from the CD provided with the Video card
  14. Finish the installation and reboot the system
That's it you have a new Video card installed !!
Please let me know if you need any further help in regards to this.
Thank you for choosing Fixya
Oct 12, 2009 | Gateway GT5220 PC Desktop
I have an HP pavilion 250n desktop that i'm trying to fix for a friend. when i boot up the system, everything boots up perfectly normal, except there's no video output at all. it has a nvidia geforce 4800x...
If neither the onboard video and the GeForce video work, the problem may be the Ram. If it has 2 dimms or more, take them out and insert one at a time, powering down/up the computer each time you swap the memory.
I would clear CMOS, just in case.
If that does not do it, I would suspect that the Processor got over heated and is causing the problem. Is the CPU fan working? Is the Power Supply fan working?
Please remember to rate all users who assist you for free :)
Oct 03, 2008 | HP Computers & Internet
Connecting my pc to my tv
verify the settings for your monitor are correct. with a video card that supports an HDMI output you should be able to go into your display properties (maybe advanced properties) and either force the TV detection or force the HDMI output to be enabled so it's displaying on your PC and your TV simultaniously. I know with N Vidia GeForce video cards you can do this and with most major brands it should work similarly.
May 17, 2008 | Philips Shielded Serial Cable...
SPARKLE Computer GeForce 7300 GT, AGP Graphic Card Logo
180 people viewed this question
Top SPARKLE Computer Computers & Internet Experts
David Payne
David Payne
Are you a SPARKLE Computer Computer and Internet Expert? Answer questions, earn points and help others
