Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Frigidaire dishwasher not completing cycle.
By psy_here on Jan 03, 2009
Our Frigidaire Dishwasher model FDB710LCB0 won't complete a wash cycle. It continues to run. We can manually move the knob to the drying cycle. However, when the drying cycle is complete, the dishes still have a lot of water left on them. Is this possibly an issue with the timer, the heating element, or the hi-temp boost thermostat?
Solution #1
posted on Jan 03, 2009
Not Rated)
rockfixya
Rank: Wiz
Rating: 80%, 338 votes
hi,
The cycle doesn't complete
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
On some units, the pause is timed and the unit continues after the allotted time.
On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
I see an error code
If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Good Luck
Thanks for using FixYa
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
Water is leaking from the bottom of the dishwasher. Seems to be coming through some sort of material... (More)
Answer
AEG diswasher, it stopped with error code 30 flashing and the pump constantly running. After... (More)
Answer
Purchased a Bosch SMU50E15AU dishwasher and think the water hose may be too short as the washer... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
