Question about Huffy 26 in. Cranbrook Cruiser Bike
Raise seat adjustment of seat
  • 3 Answers
Where the post beneath the saddle meets the frame, you will find a quick release skewer. pull the part that looks like a tab outwards, it will swing around and outwards, loosening the seat post. you should now be able to twist and raise the seat post, then flip the tab back down.
Posted on Oct 31, 2012
Sorry I think I was meant to type Volvo S60 2.5T 2005. The question was how to adjust headrest for the front passenger seat in this car?
The headrest is not adjustable. It's part of Volvo's safety feature. The seat will recline/pull back and cradle you in case of an accident.
Of course, the downside is that if you don't find it comfortable in the position it's in, you could grow to hate it. Can you lean the seat back a little and raise the bottom cushion a bit to adjust the angle?
Dec 04, 2014 | Volvo Cars & Trucks
2001 Chevy Silverado 1500 How does rear seat
There is no adjustment that I know of. I had a 2000 Silverado and the only adjustment was the ability to raise the bottom of the seat up to place large items in the back.
Oct 15, 2014 | 2001 Chevrolet Silverado
Seat height adjustment
Hi
There should be a set of levers on the right hand side (left hand if you are on the left). one of these will move the seat back and forth, one will raise and lower and one will move the seat back.
Some of these rise and fall levers are a "pump action style" where you push down to get the level or pull up.
Other type will raise the seat fully either up or down. Its on a cam.
I have had these seize before and have had to replace the mechanism.
Cheers
Roger
Apr 21, 2014 | 2006 BMW 318 Ci
How do I adjust the seat height on a Pronto M51 with SPJ+ Joystick
The seat height can be adjusted by removing the seat and raising up the 4 seat pillars on the bottom frame. With the pivot seat model you can raise the center post seat pillar.
Feb 12, 2014 | Invacare Pronto M51 Power Wheelchair
Passenger seat won't lock in place
The adjusting lever for seat position is not locking into place. On the bottom of seat are runners on each side with holes in them that the adjusting lever tabs will lock in and hold seat in place. The seat slides on the runners if those tabs are raised. There is also a connecting wire or rod from the lever to the other side of seat so when lever is pulled up, tabs on both runners are raised for seat to slide. Something is keeping the tabs from locking into the holes on the runners in your car. Maybe the adjusting lever is broken somewhere, or the wire/rod came loose, or the lever is just dry and sticky and needs a shot of WD40 to loosen it up. If you can't see it and fix it with seat in place, then pull the seat back off for the repair. Good luck. Post back if my explanatiopn is not clear or you still need help.
Jun 19, 2012 | 1998 BMW Z3 Roadster
Cannot raise seat on Clear Creek Loosened quick release and pulled up but rod doesn't budge. How to raise seat?
use a pair of channel locks or a pipe wrench tohelp pull the stem up little by little without deforming the head....should work now with quick release adjustment...
May 22, 2011 | Cycling
Front part of driver seat not raising or lowering
it is probably the motor that works the front only fix is to replace whole seat track.
Feb 11, 2010 | 2004 Chevrolet Suburban
Driver seat back won't raise after its been reclined
The control switch has developed a problem (intermittent contact or just broke inside) Replace the switch. That should fix it.
Jun 14, 2009 | 2007 Hyundai Santa Fe Limited
Raising the driver's Seat
I don't believe there is an adjustment for height
Jul 28, 2008 | 1998 Toyota Corolla
Seat adjustment
Passenger seats are usually manually operated from a latch or bar under the front of the seat. the seat back should have a lever between the door and edge of seat to make adjustment pull up on lever push back on seatback.
Jun 08, 2008 | 1990 Oldsmobile Cutlass Ciera
Huffy 26 in. Cranbrook Cruiser Bike Logo
106 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
