Question about AEG Dishwashers
Aeg anti flood connector too big for pipework
Large anti flood connector on machine is too big to attach to pipework under sink, is there an adapter pipe that can be foxed between the two?
  • 1462 Answers
SOURCE: aeg favorite 645
to check the antiflood, remove the bottom front panel and the bottom tray is exposed. if there is water in the tray, this will actuate the antiflood switch. just mop out the water and the machine will run. turn off from mains when you do this.
however, this will not give a hum. the antiflood switch just turns on the drain pump.
if no water found then get back to me
Posted on Oct 02, 2008
SOURCE: Need to know how to re-set the anti-flood device
I managed to clean the filter inside the dishwasher and drain a little residual water. I then re-plugged in the appliance and the anti-flood device seemed to reset and I have n't had any problems since.
Posted on Jan 19, 2009
  • 457 Answers
SOURCE: Bosch SHE43M was running when a pipe broke under
water is in the base and the float switch is activated. you must remove the water to deactivate.then hit the drain and cancell. let me tell you a quick joke .Im a old bosch tech and i had a call with the same problem. as soon as i got there i notice mouse droppings.the customer had a tech come by and told her she needed a circulation pump amodule the whole thing.wrong!!! what had happen was a mouse had made a mouse bed with the white packing foam and pulled it under the float in the unit. so the unit thought it had water in base and it went into drain mode . I removed foam and problem solved.
Posted on Feb 26, 2010
Testimonial: "Thanks for the great advice. Unfortunately, you didn't see it in time. We ended up paying for a new pump as Sears indicat. Will remember next time."
SOURCE: aeg favorit 64070vi, i 30 fault, think that the
Thanks to all.
What we couldn't work out is what is actual mechanism of anti-flood triggering, and how therefore to reset it - and why all these other fixes work - but then it occurred to us, that problem is when water gets into the base and can't get out.
Our problem was that water inlet at top of washer came loose so water ran down outside the drum but inside the dishwasher, into the base. We tried the tipping method but this just moved water around and I think there must be sensor there which, if it stays wet, leaves anti-flood triggered.
This makes sense because other high level overflows from drum discharge into base - so if it was to overflow, it goes into sealed base only, wets the sensor and triggers anti-flood.
Our solution was patience - tipped it fully on its side, pointed a hot air blower into it for hour or so, then left it overnight. Tipped it back next morning, water which had run into side panel ran out, so it was upright with its base dry - and (touch wood) it worked like a charm.
Posted on Jun 08, 2010
caroldon
  • 17130 Answers
SOURCE: A loud noise from the
It must be the drain tube and the sound is coming from the drain pump.It is possible that the drain motor is jammed and makes the grinding noise with some objects struck inside.So remove the drain piipe, the drain pump and clean the unit.
Test the unit outside to confirm for smooth pumping. Reset back
Posted on Sep 20, 2010
How to fix anti flood error on F60860
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Dado
Sep 28, 2014 | AEG 24 in. Favorit 60870M Free-standing...
I30 message on aeg favorit 50879 u
Activated Anti-flooding system, means water leakage in the buttom of dishwasher. Could be also: faulty Anti-flooding microswitch, floating sensor (styrofoam) blocked mechanically, wiring diagram, electronic.
Dado
Jun 17, 2014 | AEG 24 in. Favorit 40850 Free-standing...
Anti flooding on aeg 64840
Problem was answered earlier. Please check the water level sensor, check the line , remove and reset. Also check for blocks in the INLET and DRAIN filters.
Jan 20, 2013 | AEG Washing Machines
Got an AL4 error on my AEG 64800
al4 is tripping of anti flood float switch in base of machine. look for a leak mopping out the base resets the switch
Jun 19, 2010 | AEG 18 in. Favorit 64800 Free-standing...
Anti flood system triggered Favorit 40660 dishwasher
The problem was solved by opening the machine and finding that the bottom "Y" pipe that has 3 inputs is of extremely poor quality and perforates with pin holes allowing a small amount of water to squirt out. This triggers the anti flood and error status lights flash. The outlet pump is activated and machine does not do anything. You need to replace this hose or like I modified it to work from a 32mm Y plastic junction available from most hardware shops. The wire clamps for this was replaced by "jubilee" screw tight clamps.
I worked on a table and also removed the "Brick" placed at the bottom for balance purposes by cutting the back plastic down with a saw. This made the job very easy...
Jan 13, 2010 | AEG 24 in. Favorit 40660i Built-in...
Anti-flooding system has activated.
Tip washing machine towards you, water in bottom of machine will pour out, so be ready! Should work after that, mine did!
Aug 23, 2009 | AEG Washing Machines
Antiflood system triggered-how to reset on aeg favorit 35080vi
Hello everyone. Have just fixed a problem with my aeg dishwasher thanks to this site. My anti flood switch in, so I unpluged, pulled the machine out, tilted it, wiggled the outlet hose, which I think was a little kinked and way hay it works. Thanks FIX YA. Good luck everyone. Carolyn
Feb 08, 2009 | AEG 23 in. Favorit 88070IM Built-in...
Jan 17, 2009 | Dishwashers
Just purchsed G1173Vi - failed to fit due to exiting pipework on wall being directing in line with the inlet hose which is located directed above the waste hose. Had no problems fitting previous 2...
Hi there!
You say - "obviously I cannot move exiexisting pipework."
, but I would consider it necessary if you need to fit this machine.
The only other option is to fit a diferent model - with connections similar to the one you removed.
Any competent plumber will be able to move pipework in under an hour, and would be considered normal if fitting a sink or similar.
Jun 19, 2008 | Miele Dishwashers
Dishwashers Logo
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
