Question about Brother MFC-7820N Printer
Continual paper jams in rear of printer
I have an MFC 7820N printer and it continues to have paper jams in the rear of printer. The paper continues to crinkle and sometimes prints and other times it jams. Do the rollers ever need replacing in this printer?
  • Anonymous Feb 23, 2009
    always used 96 24 bright in this printer why should it be different now?
  • jean4552 May 11, 2010
    Mine is jamming too. What do you clean the rollers with? Thanks!
  • 39 Answers
If the paper is jamming at the exit rollers, you will be need to clean the rubber on the rollers. It gets shiny and does not grip the paper to take it away.
Posted on Mar 03, 2009
  • Paul Bell Sep 17, 2009
    I clean the rollers with Isopropyl Alcohol and the green kitchen scouring pads. When the rollers are shiny they often have white/grey markings on them. Keep scrubbing until rubber is roughened up.
  • Troy Scorer Aug 26, 2012
    Worked for me, Thanks mate
Have you tried using different grades of paper
ie if you are using 80 gram try 100 gram it should help
Posted on Jan 11, 2009
Our Brother 7820N all of a sudden started paper jamming. Took everything out and it still jams. What can I do.
Try the link below, if its not working that may be a hardware issue and needs repair: 7820n Paper Jam
Aug 26, 2010 | Brother MFC-7820N Laser Printer
Paper feed jams. feeds from lower tray, turns 180 deg. then jams. Single sheet feed is fine
while keeping the paper .. ensure that it is properly stacked... fan the paper and ensure that it is not stuck to each other.. also open the printer cover and see if any paper is stuck inside..
Try to open the rear access door ,and clean the paper roller with slightly damp lint free cloth
Aug 12, 2010 | Brother MFC-7820N Printer
I cannot get the BACK COVER OPEN message to GO AWAY. I tried to open the back black cover and check to see if there were any paper jam and i also opened the front cover and ejcted the ink toner and no...
There is a little cover there that has a sensor flag on it. It is most likely in a jammed position. If you are able to carefully take the cover out, you can bend it slightly, readjust the sensor flag, and reinstall it.
Thanks
Mar 12, 2010 | Brother MFC-7820N Laser Printer
Paper Jam
Have you checked for paper jammed in the rollers or any other small item like a paper clip? Also are you running this on wired or wireless connection?
Jan 13, 2010 | Brother MFC-7820N Printer
MFC-7820N Paper Jam On Exit After Fuser
Hello, I can solve your problem for $50 plus shipping.
Jan 12, 2010 | Brother MFC-7820N All-In-One Laser Printer
How do you remoce the drum to clear a paper jam on
Lift the top, remove the toner and open the access panel in the back, remove the printer tray. You should be able to see the full path the printer takes from start to finish. Rarely do you need to take anything else apart. If these areas are clear as the printer will attempt to clear jams when you start it up.
Nov 08, 2009 | Brother MFC-7820N Printer
Recieve multiple paper jams that wont stop!
Is there a sensor flag that is stuck and/or broken?
May 22, 2009 | Brother MFC 7420 All-In-One Laser Printer
Back cover open error message MFC 7820N
Reseat inner rear paper guide to allow sensor to home correctly
Mar 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
Back cover open message on brother mfc 7820n
Had same problem. Closer inspection revealed bit of paper out of sight. Removed the toner cartridge and worked to free torn paper. Then restart. Hope it helps.
Dec 15, 2008 | Brother MFC-7820N Printer
http://www.fixya.com/support/t150137-one_more_person_back_cover_open_problem
Oct 24, 2008 | Brother MFC-7820N Printer
Brother MFC-7820N Printer Logo
1,299 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
