Cars & Trucks Logo
DANA THIBODAUX Posted on Oct 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HEAD TORQUE SPECS ON 2001 ACCORD ACCORD 2.3 VTEC
NEED TO KNOW HEAD TORQUE AND SPECS NEED TO KNOW INTAKE TORQUE AND SPECS NEED TO KNOW EXHAUST TORQUE AND SPECS
Thomas Perkins
Level 3:
  • Cars & Trucks Master 15,088 Answers
  • Posted on Oct 29, 2012
Thomas Perkins
Level 3:
Answers
15088
Questions
0
Helped
3389666
Points
54869
5 Related Answers
Anonymous
  • 25 Answers
  • Posted on Mar 17, 2009
SOURCE: 87 samurai bolt torque specs for engine
The haynes book is not recommended since there are numerous mistakes and they still will not update. One of the biggest is the firing order.
The factory service manual is the only way to go.
Head bolts - 46 - 50.5 lbs (there is an order sequence for the bolts)
Intake & exhuast manifolds- 13.5 - 20 lbs
Flywheel - 41.5 - 47 lbs
Clutch cover - 13.5 - 20 lbs
Anonymous
  • 548 Answers
  • Posted on Aug 28, 2009
SOURCE: need torque specs for 1987 toyota corolla fx-16
http://opc.mr2oc.com/online_parts_catalog/Engine/torque%20-%20TVIS.gif
Anonymous
  • 198 Answers
  • Posted on Oct 24, 2009
SOURCE: what are the torque specs for intake and head for
For 1988-1995 4.3L,5.0L and 5.7L intake manifold bolts are torqued to 35ft.lbs.Start with center bolts on each side moving out finishing with the bolts in the front of the motor and the back
Anonymous
  • 466 Answers
  • Posted on Mar 06, 2010
SOURCE: need head bolt, intake manifold, and exhaust torque specs
Cylinder Head Bolt Step1- (25 FT.Lbs) Step2(45 Ft.Lbs) Step3(65Ft,Lbs).....Intake Manifold(35Ft Lbs)....Exhaust Manifold Center (20Ft Lbs) All Others (20 Ftlbs).....Thanks
Anonymous
  • 12 Answers
  • Posted on Apr 25, 2010
SOURCE: head bolt torque specs for 200 honda accord 3.0
its a three step process 1st 29ft/lbs 2nd 51ft/lbs 3rd 72.3ft/lbs
Torque specs for 01 Honda Civic 1.6L VTEC to include intake , exhaust, thermostat housing to head cam pully
try referring to the repair manual. usually always has torque specifications:
http://www.papertownspdf.com/downloads/honda-civic-repair-manual-2000-2005/
98 ford windstar intake manifold torque specs
Intake torque specs ' FordForumsOnline.com
www.fordforumsonline.com > Ford Tech Forums > Engine & Drivetrain
May 7, 2010 - 2 posts - ‎2 authors
ISO torque specs for the intake & plenum for a 98 Windstar...3.8 with the ... Our community is here to help you with any questions you have related to your Ford. ... Lower Intake Manifold to Cylinder Head Bolt 8-12 - (71-106).
Torque Specifications - AutoZone
www.autozone.com/.../Ford-Windstar.../Specifications/Torque-...
AutoZoneAutoZone Repair Guide for your 2004 Ford Truck Ranger 2WD 2.3L MFI DOHC 4cyl Engine Mechanical Specifications Torque Specifications. ... Ford Windstar 1999-2003 ... Bolts, Main Bearing Bolts, Rod Brearing Bolts, Crankshaft Damper Bolts, Flywheel Bolts, Manifold. Intake, Exhaust ... Vehicle: 2008 Ford F150, 98 Civic.
Need head bolt torque specs for a 1996 saturn sl
Quote:
Originally Posted by norvelplagbao52
1993 saturn sl2 1.9 dohc cylinder head torque
specs and sequence
Cylinder head bolt
tightening procedure:
CYLINDER HEAD BOLT TIGHTENING SEQUENCE:
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
torque the cylinder head bolts. Torque: 30 Nm (22 ft-lbs).
In sequence,
torque all bolts. Torque: 50 Nm (37 ft-lbs)
In sequence, turn each bolt an
additional 90 degrees.
specs and sequence
Cylinder head bolt
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
In sequence,
8helpful
3answers
HEAD TORQUE AND SPECS FOR A 2001 HONDA ACCORD 2.3L
Tighten the cylinder head bolts. Tighten the cylinder head bolts is sequence to 29 Nm (3.0 kgf-m, 22 ft. lbs.). Use a beam-type torque wrench. When using a preset type torque wrench, be sure to tighten slowly and do not overtighten. If a bolt makes any noise while you are torquing it, loosen the bolt and retighten it. Make sure the threads are clean, new heads bolts are best.
14helpful
2answers
Head torque specs for 92 honda accord with f22a1
Thanks for using FixYa.
To install:
  1. Install a new head gasket on the engine, making certain it is positioned correctly. The cylinder head dowel pins and the oil jet must be in place. Refer to the illustrations if necessary.
  2. Install the head. Lower it straight down onto the block, aligning it correctly.
  3. Apply clean engine oil to the bolt threads and the contact face of the bolt head. Install the head bolts finger-tight.
  4. On all models except 1988-89 DOHC Prelude and 1992-95 Preludes with 2.3L and VTEC engines, tighten the head bolts following sequence A. On 1988-89 DOHC Preludes, use sequence B. Use sequence C on 1992-95 Preludes with 2.3L and VTEC engines.
    1. On 1984-89 Accords and 1984-91 Preludes, tighten the bolts in two passes. The first pass should bring the bolts to about 22 ft. lbs. (30 Nm). On the second pass, tighten the bolts to their final torque of 49 ft. lbs. (68 Nm).
    2. On 1990-93 Accords, tighten the bolts to 29 ft. lbs. (40 Nm) on the first pass, 51 ft. lbs. (70 Nm) on the second pass, then tighten the bolts to their final torque of 78 ft. lbs. (108 Nm).
    3. On 1994-95 Accords and 1992-95 Preludes, the bolts are also tightened in three passes. Tighten the bolts to 29 ft. lbs. (40 Nm) on the first pass, 51 ft. lbs. (70 Nm) on the second pass, then tighten the bolts to their final torque of 72 ft. lbs. (100 Nm).
      Fig. Fig. 9: Cylinder head bolt torque sequence A
      Fig. Fig. 10: Cylinder head bolt torque sequence B
      Fig. Fig. 11: Cylinder head bolt torque sequence C
  5. If applicable, assemble the intake and exhaust manifolds to the head. Use new gaskets.
  6. If applicable, install the cam, rockers and camshaft holders.
  7. If equipped, install the EGR crossover and air suction pipes.
  8. Connect the exhaust pipe to the manifold using new nuts.
  9. Install the timing belt.
  10. Install the valve cover.
  11. Install the cylinder sensor (if equipped) and the distributor.
  12. If applicable, install the alternator.
  13. Install the power steering pump, then connect the inlet hose to the pump.
  14. Install the accessory drive belts. Adjust the belt tensions.
  15. Install the heater hoses.
  16. Install the cruise control actuator if it was removed.
  17. Connect the spark plug wires. Connect all the wire harnesses and vacuum hoses to the cylinder head, intake manifold and throttle body/carburetor.
  18. Connect the throttle control cable and/or accelerator cable at the throttle body.
  19. Connect the fuel lines.
  20. Install the brake booster, PCV and charcoal canister vacuum hoses.
  21. Install the air cleaner and intake duct.
  22. Refill the engine coolant. It is recommended that the engine oil be changed whenever a cylinder head is removed.
  23. Connect the negative battery cable.
  24. Start the engine, allowing it to idle. Bleed the cooling system. Check the work area carefully for any signs of fluid leakage or any indication of the timing belt rubbing or slapping the covers.
3helpful
Need cylinder head torque specifications 2004 hyundai elantra
Install the cylinder head bolts. Starting at top center, tighten all cylinder head bolts in sequence as shown in illustration, using the Cylinder Head Bolt Wrench (09221 - 32001) or equivalent. Repeat the procedure, re-tightening all cylinder head bolt to the specified torque. (torque spec is Cold Engine 105-115 Nm (76-83 ft lb) )
. Install the timing belt tensioner pulley.
. Install the timing belt on the camshaft sprocket, making sure that the tension side is tightened by turning the camshaft sprocket in reverse, all timing marks are in alignment.
. Adjust the timing according to "Timing Belt"
. Install the rocker cover and tighten the bolts to the specified torque. Tightening torque: Rocker cover belt:
2.5-3.5 Nm (25-35 kg.cm, 2-3 ft. lbs.)
. Install the timing belt cover.
Install the new intake manifold gasket and the intake manifold. Tighten the nuts and bolts to the specified torque.
Install the new exhaust manifold gasket and the exhaust manifold. Tighten the exhaust manifold attaching nuts to the specified torque.
. Install the surge tank and tighten the nuts bolts to the specified torque.
. Install the power steering oil pump and bracket.
. Install the ignition coil.
. Install the air intake hose.
Connect the vacuum hose, fuel hose and water hose.
. Install breather hose.
HOW TO FIX A BLOWN HEAD GASKIT?
Buy a gasket kit for the upper end. Remove the valve cover intake and exhaust manifolds. Remove the head bolts. Remove head and clean up block from old gasket material. Take the head to a machinist and make sure that it is not warped. If it is warped either replace the head with a new one or have it machined true. Install new gasket and get torque specs with new head bolts and follow torque sequence using the correct torque specs. Clean exhaust, intake and valve cover of old gaskets. install new gaskets and torque according to specifications.
11helpful
2answers
Need torque specs for 2000 chevy malibu 3.1 cyl heads & intake
(step 1 ) the torque specs for the heads are---1998 through 2001 are 37 foot lbs. ( step 2) rotate an additional 90-degrees (1/4 turn). intake manifold bolts ( lower ) step 1-- 62 in-lbs, step 2--115 in-lbs. intake manifold bolts/studs ( upper ) 18 ft-lbs. this is for the 3.1 v-6, have a good day!
3helpful
3answers
Need head bolt, intake manifold, and exhaust torque specs
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
