Question about Pitco Frialator 40CNG Deep Fryer
I have a used Pitco Fryer that is so old I can not make out the number, it appears to be a PG14-s but that does not seem to match any that I have been able to find. This was from an abandoned closed restaurant, and has sat dormant for several years, even better, they left it full of oil...nasty. Ut has been cleaned, but I am unable to get the pilot to light. Am I crazy to think there is even a possibility of this thing working?
  • babblinggour Oct 29, 2012
    Ok, so i have figured out why the model number is crazy, it appears to be a FrankenFryer, and the door is from a pitco pasta cooker, I beleive the unit is an economy fryer, model 45. I have filled it with water, and it is not leaking anywhere. I have purged the line after hooking it up (held pilot for over a minute). Still, I get nothing.
SOURCE: Pitco Frialator Model 14S
Excellent reason to use Dormont flex lines.
If water gets to your combination valve (the thing with the on-off knob,) it should be replaced. Can you hear gas hissing? If there is gas at the orifice, it should light. check to see that all of the air is purged. Can you smell gas?
Posted on Sep 30, 2008
SOURCE: pitco fryer pilot out
the problem is the thermocouple , and not the gas valve or thermopile
Posted on Feb 12, 2009
  • 26 Answers
SOURCE: my pitco 14S fryer will light but after it makes
Make sure oil temp under 400. If higher, T/stat shot. If lower, High limit shot
Posted on Sep 22, 2009
  • 8220 Answers
SOURCE: Pitco 35C+ fryer. Pilot lights fine; main burner
Its a simple design. If the thermophile does the work of powering the fryer control. Do you have a good pilot flame? If the pilot flame ain't good enough then the millivolts won't be enough to operate the solenoid on the gas valve. Most folks replace both the pilot and thermophile on these fryers since the grease makes such a mess of everything. If the pilot generator is fine then the gas valve is next.
Posted on Jun 01, 2011
  • 684 Answers
SOURCE: pitco fryer
Try removing the oil and boil out the fry tank.
Fryer cleaning manual is downloadable on PITCO site at
Posted on Jun 06, 2011
My pitco fryer SFSG18 will not light it has spark but does not seem to be getting gas when trying to light
Have you tried inspecting/replacing the thermocouple? This is the thing you heat when initially lighting the pilot.
You may also have a stuck pressure valve, but that is unusual.
Apr 02, 2016 | Pitco Frialator SG18S Deep Fryer
How to check gas pressue on pitco frialator
To check manifold pressure, there is a pressure tap on the manifold on which the burners are mounted. Remove the tap, hook up your manometer and turn the fryer on. Be sure you have no gas leaks once you reinstall the plug. The gas pressure should match what is on the data plate.
Apr 12, 2013 | Pitco Frialator 35C Deep Fryer
13 year old pitco frialator fryer pilot wont stay on. changed gas valve and thermopile.... pilot light wont stay lite
Hi there.
Check and tighten all wiring connections.
Check the hi limit for continuity across the terminals using an ohm meter, if it has no continuity, you have to replace the hi limit.
Aug 21, 2011 | Pitco Frialator 35CS Deep Fryer
Where do I find the model number for my Pitco fryer?
You can find the model number at the nameplate located at the back of bottom compartment door.
May 17, 2011 | Pitco Frialator SG14 Deep Fryer
Where is the model number on the pitco fryer?
Model number can be found on the nameplate behind the fryer door.
Mar 31, 2011 | Pitco Frialator SG14 Deep Fryer
Pitco fryer
Jul 19, 2010 | Pitco Frialator SG14 Deep Fryer
The fryer is a pitco 35cs can u tell me y it heats up to 550 and shuts the pilot down
It shuts down because it is tripping the high limit. Apply a soap solution to the lines going from the gas valve to the thermostat. If bubbles appear there is a leak and needs to be corrected. If no bubbles appear then the thermostat is probably your problem.
Feb 24, 2010 | Pitco Frialator 35CS Deep Fryer
Wiring diagrammed of Pitco model 7-2wkss
Sorry to break this to you but all pitco fryer model numbers start with an S, please make sure what manufacture this fryer is made by.
Thank You
Jul 12, 2008 | Pitco Frialator SG14 Deep Fryer
Pitco Frialator 40CNG Deep Fryer Logo
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
