Question about Delta 473-SD Saxony Single Handle Kitchen Pull Out Faucet with Soap Dispens...
How do I remove the handle on Delta Saxony 473-SD faucet?
2 Suggested Answers
  • 68 Answers
SOURCE: Leaking kitchen faucet delta saxony 473-sd.
on top of the on off handle ther is a little cap pull it off un screw it carefully take apart the top once u see the top of the cartrige carefully pull it out and replace it and it should stop the leak
Posted on Jan 25, 2009
How do i remove the caprp50 to a delta faucet 473-sssd that appears to be cross threaded?
IF CROSS THREADED YOU MAY HAVE TO USE TWO PIPE WRENCHES ONE TO HOLD FAUCET IN PLACE THE OTHER TO TRY TO UNSCREW IT MAYBE YOU COULD USE SOME WD40 OR SOME RUST REMOVEL SPAY TO GET IT LOOSE IF IT IS SO TIGHT THAT IT JUST WILL NOT BUDGE YOU MAY HAVE TO CUT IT AND BUY A WHOLE NEW FAUCET.
Feb 03, 2015 | Delta Model 473: Saxony Kitchen...
Can i remove the flow restrictor on my delta model 473
Usually these are located in the aerator section of the unit.
May 26, 2011 | Delta Model 473: Saxony Kitchen...
The faucet has lost a small screw on the hot/cold handle. The head of the screw has a red/blue design. Where do I get a replacement screw?
Go to hardware where your faucet is sold and determine what screw you need. The red/blue dealy is just a screw cover.
Feb 23, 2010 | Delta 473-WHSD-DST Saxony Diamond Seal...
After a recent water main break, our Delta Model 473 kitchen faucet now has very low water pressure. It also continues to flow for a few seconds after turning it off. I tried unscrewing the screen and...
Check the screen at the hose connection under the sink. Check the hoses for any large debris in them. Verify that the water pressure coming from the water outlets under the sink is good. There is obviously a restriction somewhere...you just need to locate it.
Sep 26, 2009 | Delta Model 473: Saxony Kitchen...
Delta 473 loose connection to sick
There should be a nut holding the plate on. What is holding the u-shaped plate up?? You can't tighten the faucet from above. Seems strange the nut disappeared.
Aug 08, 2009 | Delta Model 473: Saxony Kitchen...
My Delta Saxony faucet drips when I turn it off....I have to play with getting the handle in the right position for the drip to stop
if you know how take out the cartridge and clean it out.this may help,if not you may need to replace the cartridge.good ouck on your project.
Aug 06, 2009 | Delta Model 473: Saxony Kitchen...
Delta 473 faucet very loose where it meets the granite
This is a view from the underside of our sink. Is this what you were talking about? The steel plate is W-shaped (upside down in this case) and has a single nut larger than 3/4". It's almost impossible to fit a wrench up there to tighten it.
Jul 30, 2009 | Delta Model 473: Saxony Kitchen...
Jan 24, 2009 | Delta 473-SD Saxony Single Handle Kitchen...
Delta 473-SD Saxony Single Handle Kitchen Pull Out Faucet with Soap Dispens... Logo
32 people viewed this question
Top Delta Plumbing Experts
john h
Craig Butler
Craig Butler
Mike
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
