Question about Acer Extensa 4620 Notebook
Booting Error Message No Operating System Found
This Item is a Acer - Extensa 5420
Once the booting page loading, I am receiving the error message :
PXE-E61: Media Test Failure, Check Cable
PXE-M0F: Exiting PXE ROM
Operating System Not Found.
So I figured there was a issue on the Bios screen, I went in and reset to defaults, saved and exited, same error message. So I booted the system up using Linux LiveCD 8.10 and used without installation, When I clicked on '' Install '' to hopefully, find some partitions there was no partitions found. ** BTW I am currently using Windows Vista on the Notebook. **
So I figured I should try using the Windows Vista Recovery CD that I have downloaded from the site, Once loaded, I attempted to REPAIR YOUR COMPUTER, once I clicked on that, there were not System Recovery Options - No drivers found. So I clicked Next, Started with Start up Repair, from there received error message of ''ROOT CAUSE FOUND: A hard Disk could not be found. If a hard disk is installed, it is no responding.'' So from the common sense, and the obvious, looking at me right in the face, there was : A. No hard drive or B. Hard drive was not responding.
So Like anybody, I took apart the bottom of my notebook, where I found the hard disk, removed it, ensured it was clean. placed back in with care, rebooted the notebook....and what do you know.....same error message. I really need help here, and please, be easy and not too much terminology, I'm a noob to all this. BTW I also attempted to contact Acer Tech Support, and like the obvious, they wanted to me to pay for software, that wont even work. So to answer any possible questions about accessing the web, I can do so, with Linux LiveCD 8.10. thats about it, no flash players can be used unfourtently, I have tried downloading a number of anti-virus programs, but just receive, error msg to error msg, and so on, and so forth. Any Suggestions will be taken with all respect and gratidue.
Thanks In Advance,
Justin
  • 1 more comment
  • Justin Larocque Jan 03, 2009
    It was working fine, and then all of the sudden....this issue occurred.
    How can I tell if it is detected in the BIO?
  • Randy Dix
    Randy Dix May 11, 2010
    What were you doing when the problem started? Were you reinstalling Vista? Installing another operating system on a computer that originally had Vista? Or was the computer working just fine and then one day you turned it on and got this screen?
    Scholar:
  • 86 Answers
Hi!
Make sure that hard drive is detected in BIOS. If not, there is a problem with the hard drive and any attempt to install OS will be futile since there is no hard drive detected. If this basically means you have a busted hard drive, you may need to replace it then to continue with OS installation.
Thanks.
Posted on Jan 03, 2009
  • Anna Marie Abueva Jan 03, 2009
    Hi!
    Please follow the instructions listed below for recovery attempt: (If all else fails please proceed with the instructions on the bottom of the page since like I've said this could possibly mean that you need to replace your hard drive which could be busted already.) Thanks.
    I want to restore my computer to its original settings without
    recovery CDs.
    Note: If your system is the multilingual version, the operating
    system and language you choose when you first turn on the
    system will be the only option for future recovery operations.
    This recovery process helps you restore the C: drive with the original software
    content that is installed when you purchase your notebook. Follow the steps
    below to rebuild your C: drive. (Your C: drive will be reformatted and all data
    will be erased.) It is important to back up all data files before using this option.
    Before performing a restore operation, please check the BIOS settings.
    1 Check to see if Acer disk-to-disk recovery is enabled or not.
    2 Make sure the D2D Recovery setting in Main is Enabled.
    3 Exit the BIOS utility and save changes. The system will reboot.
    Note: To activate the BIOS utility, press during POST.
    44
    English
    To start the recovery process:
    1 Restart the system.
    2 While the Acer logo is showing, press + at the same time to
    enter the recovery process.
    3 Refer to the onscreen instructions to perform system recovery.
    Important! This feature occupies 10 GB in a hidden partition on
    your hard disk.
    Requesting service
    International Travelers Warranty (ITW)
    Your computer is backed by an International Travelers Warranty (ITW) that
    gives you security and peace of mind when traveling. Our worldwide network
    of service centers are there to give you a helping hand.
    An ITW passport comes with your computer. This passport contains all you need
    to know about the ITW program. A list of available, authorized service centers is
    in this handy booklet. Read this passport thoroughly.
    Always have your ITW passport on hand, especially when you travel, to receive
    the benefits from our support centers. Place your proof-of-purchase in the flap
    located inside the front cover of the ITW passport.
    If the country you are traveling in does not have an Acer-authorized ITW service
    site, you can still get in contact with our offices worldwide. Please consult
    http://global.acer.com.
    Before you call
    Please have the following information available when you call Acer for online
    service, and please be at your computer when you call. With your support, we
    can reduce the amount of time a call takes and help solve your problems
    efficiently. If there are error messages or beeps reported by your computer,
    write them down as they appear on the screen (or the number and sequence in
    the case of beeps).
    You are required to provide the following information:
    Address: ___________________________________________
    Telephone number: _________________________________
    Machine and model type: ____________________________
    Serial number: ______________________________________
    Date of purchase: ___________________________________
5 Suggested Answers
dugiehowsa
  • 114 Answers
SOURCE: Evo N200
The BIOS, which handles the initial start up of your computer, cannot find your hard drive and thus cannot boot your operating system (ie, Windows). Open up your computer and confirm the power cable is firmly connected to the hard drive and that the cable that connects the hard drive to the motherboard is firmly secure. If both of these check out, then try downloading this bootable CD on another computer. This CD, among other things, has a few hard drive utilities that will help further diagnose the problem. http://www.ultimatebootcd.com/ Finally, if the utilities on this CD are unable to see the hard drive itself, then is may need to be replaced. Try testing with another hard drive or another cable to connect it to the motherboard.
Posted on Oct 10, 2006
ajx13
  • 110 Answers
SOURCE: my mini dell inspiration laptop sends me an error
This error comes up if the computer is not able to detect the hard drive. Power off the computer. Power it back on and tap the number 2 key 4 - 5 times at the Dell logo screen. This will take you to the system setp screen. Check if you see any thing listed next to solid state drive. If you dont see any thing try reseating the hard drive. Here are the steps to reseat the hard drive.. If you see an entry next to the solid state drive. You'll need to reinstall windows on the computer. If you have been shipped XP you will need an external CD drive to reinstall windows. If the system was sen with ubantu try to download it to a usb drive and boot off it.
Rate if useful.
Posted on Aug 08, 2009
elix0411
  • 3530 Answers
SOURCE: Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C)
change your boot priority. press power button then keep on tapping F1 key until your reached to setup utility. go to boot menu and set your boot priority 1 to your HDD. if compute wasnt able to detect your HDD . then there is a problem wth your HDD, you need to call you manufacturer for HDD replacement if unit is still under warranty
Posted on Apr 04, 2010
Geekman
  • 32281 Answers
SOURCE: For Realtek RTL8101E/8102E PCI-E Ethernet
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Posted on May 26, 2011
When i try installing windows xp on acer extensa 4220, i get an error message "hard disk cannot be found"
go to BIOS settings and change SATA mode from AHCI to IDE.press F2 while booting up
Jun 14, 2011 | Acer Extensa 4220-2148 Notebook
Hi, I have a Acer Aspire One (mdl ZG5) computer that was locking up, I attempted to format and reload the defaul system config from the hidden disk partition. The process started and then I received the...
Go to the Acer web site Support and Drivers, put your model number in, your operating system and order a DVD with a factory image for your Aspire One. It may cost you, but maybe not. Next order on optical drive that runs on two usb ports from eBay. I have one that costed $50 with shipping or maybe a local tech has one.
Oct 14, 2010 | Computers & Internet
Acer Extensa 5420, Crystal Eye camera just a joke?
Please try re installing your operating system. (Genuine windows xp or vista recommended)
If the problem still persists feel free to get back me @
deepuunni1985gmail.com
Aug 12, 2009 | Acer Extensa 5420-5687 Notebook
My acer 4230 extensa can not boot, tried all options of booting
TRY TO RUN IT AT SAFE MODE AND MAKE GENERAL FIX ON UR SYSTEM IF IT'S NOT WORKING THEN U NEED WITHER TO FIX UR WINDOWS BY REPAIRING UR WINDOWS OR FORMAT UR WINDOWS AND INSTALL NEW ONE
Jun 09, 2009 | Acer Extensa 4620 Notebook
On my lap top i receive message-"error loading operating system"
Trying booting into safe mode by pressing F8 while the computer is booting up.
Choose safe mode with the arrow keys and see if it boots that way.
Mar 20, 2009 | HP Compaq nx9030 Notebook
Acer crystal eye webcam
You can go to the manufacturers website to check if you have the very latest driver for your webcam. if not, you should be able to download it from there.
Go to control panel, then system properties, then device manager, then hardware. check imaging devices to see if your webcam is recognized.
Mar 12, 2009 | Acer Extensa 5420-5687 Notebook
Dell Latitude D600 with boot-up error message
You operating system is corrupted meaning that your harddrive has failed or you got a bad virus. Only fix is having the operating system reinstalled and mostly likely that data is lost. Sorry to have to break the news to you and hope that you can get this resolved.
Jan 15, 2009 | Dell Latitude D600 Notebook
Acer aspire 3000
try booting the hard drive, and pressing F8 and booting to last known good configuration. If that doesnt work gheck out SUPER GRUB, it can fix your MBR if needed.
Jan 29, 2008 | Acer Aspire 3680 Laptop
Acer Extensa 4620 Notebook Logo
1,573 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
