Question about Dell W3707C 37 in. LCD Television
My Dell W3707C LCD TV won't quit flipping. The only button that works is the power button. I can hold the channel button down and flipping stops for about 2 minutes and then it starts flipping a
  • Lizzy70068 Nov 02, 2012
    Brought this TV in and found out it was the key control board that was out. Part 454aci31L01 and have not yet to find one. It is listed at several sites as available, but they say they can't get it. If anybody has one let me know. Thanks
    Top Expert:
  • Dell Master
  • 14,553 Answers
One of two basic things here, unplug set to see if after a while it helps, and if channel scanning up or down on its own suspect the button associated with the direction it changes is a bad one.
Posted on Oct 30, 2012
SOURCE: lcd power off issue
ummm there isnt a fan in these units.....
Posted on Dec 12, 2007
headstrong
  • 233 Answers
SOURCE: 23 inch lcd tv by dell wont turn on as if no power
if this is a DELL W3201C read this.
Have the same model and same problem
probably It is a bad inverter board, in my case one of the 16 transformers is burnt out on the inverter board. still trying to find a replacement component. if not replacing the board is the only option or getting the inverter board repaired.
by the way, this TV has a Samsung panel: model LTA320W2-L03. so it needs parts for a Samsong not a DELL.
DELL does not manufacture or fix them becuase they don't make them
Posted on Dec 28, 2007
  • 90 Answers
SOURCE: DELL LCD TV locked up w/screen message "main menu locked"
without a remote and disabled keypad keys, the only other option, is to open the unit up a physically RESET the TV. remove the cables from the power board. i believe it has a phillips head screw. careful when you separate the rear cover from the front cover. there is a board screwed in the lower right corner, there is a connecter and a ground cable screwed to the rear cover. take your time prying on the rear cover. once you separated the two pieces, look for the light yellow board with your AC power source. Unplug it for 30 minutes and repeat the process. while your at it, also look down to the lower left side of the monitor. u should be able to see the keypad. press each button, while pressing, look to see if the button is pressing against the circuit board. it may be loose, try this test, u just may be able to fix your keyboard as well. hope this works out.
Posted on Jan 30, 2009
SOURCE: Dell w2600 wont turn
Same problem, this is my solution. The system will start everytime if starting from power off one starts from sleep. Thus the trick is to use sleep mode to shut it down. I do not use the sleep function on the remote (it would be worth a try, let me know if you do that), but rather I have chose VGA as the entry signal ad have hooked the TV to my PC, and then I put the PC in sleep mode. The TV will do the same. When it is in sleep mode through the PC, the system cvomes back to life if the remote from the cable is used to change channels.
Posted on Mar 22, 2009
budmrtn
  • 11361 Answers
SOURCE: i have a dell lcd tv/monitor that just stopped
Power supply module will be the first place to look at, from what you describe, at least the 5v standby power supply is still working, It can be the power supply module is bad or it is not getting the control signal from the main board to turn on the main power supply on.
Posted on Oct 31, 2009
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
Volume at max and won't go down
This sounds like a common problem on these TVs. Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Aug 12, 2012 | AOC L42H861 42 in. LCD TV
How do I clean the inside of the screen
If it is a projection screen you have to take it apart. First lay the tv face down on a bed then remove the screws that hold the back on. Be carefule some of the screws are hidden and most of them are torx bit. Please make sure you dont void any waranty by doing this! When you have all the screws out the flip it back over and carefully pull the face and screen off. This will allow you to clean it. DO NOT use anything but mild soap and water. I hope this helped.
Jul 30, 2012 | Dell W3707C 37 in. LCD Television
AOC A15X221 have picture no sound
Nov 20, 2011 | AOC A15X221 15 in. LCD Television
Where is the t-con board on the w3707c from dell
Boards: http://www.shopjimmy.com/catalogsearch/result/?q=Dell+W3707C
It can be on the center top of the LCD panel or center bottom depends on the version you have.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jul 13, 2011 | Dell W3707C 37 in. LCD Television
My dell vostro 2510 won't power on, when i press power button to turn on the pc , the power light turn on for about 5 sec then it turn off itself,
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Jun 18, 2011 | Dell Vostro 2510 Laptop
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
Had electrical storm last night. Tv shows the Westinghouse symbol, nothing else. This is when it is turned off. When you turn it on (from the tv, remote won't work at all), symbol disappears for 30...
If your TV has a reset switch on the back, use it. If not, Unplug the TV, hold the power button down for 30 seconds, let it go and remain unplugged for another 5 minutes or so.
Plug it back in, and see what happens. Try changing the inputs/channels/etc to see what happens. If you're still having this issue, Take your TV in for repair.
- Sidenote, a $25 power bar with built in protection curcuits are the easiest way to protect your equipment from this kind of thing, and quite a bit cheaper than forking over $300 for a new TV everytime there's thinder and lighting.
May 11, 2011 | Westinghouse 32" Flat Panel LCD HDTV
My tv cannot turn on. Even with the remote controller. What could be the problem?
Just make sure that the wall outlet you are using is actually live. Try plugging in a reading lamp to that socket to make sure it has power.
If power is good, then check where the power cord enters the back of the tv for a fuse holder.
If there is one there, then unplug the tv and replace the fuse with a new one.
Otherwise you might be looking at getting out your screwdriver and disassembling the tv to have a look at the main power supply circuit board.
I looked at the owner's manual located at the following link but they did not mention if the set had an easily accessible fuse there or not.
http://support.dell.com/support/edocs/systems/W3707C/en/index.htm
Good luck and keep us posted on how you are making out.
Jan 21, 2011 | Dell W3707C 37 in. LCD Television
Dell W3707C 37 in. LCD Television Logo
150 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
