Question about LG Washing Machines
LG WF-T1502TP fills and displays PE-internal sensing failure what's wrong?
  • 210 Answers
SOURCE: PE error code on LG WF-T653A
PE is a pressure switch problem. Could be a bad switch or it could be that the hose is plugged. The switch looks like a diapharm switch and is located on the main board. It has a black hose that connects under the bottom of the tub. See if that end is clogged. Otherwise you may need a new switch.
Sgt 48
Posted on Jun 02, 2008
  • 500 Answers
SOURCE: What is the problem if
Pressure Switch faulty.
Replace with P/N: 6501EN1001A
Reply if you need directions for removal & installation.
Good Luck!
* If you found this solution helpfull, please rate with 4 thumbs up & a testimonial.
Posted on Apr 08, 2011
jnchahn
  • 252 Answers
SOURCE: Water sensing level not working on Fisher &
Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
Posted on May 07, 2011
SOURCE: LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Posted on May 22, 2011
caroldon
  • 17129 Answers
SOURCE: m using LG's WF-T7516HN machine
This is a fault with the pump( PE) and so it is possible that the pump is clogged or is inactive .
You will need to remove the pump and test to confirm or replace.,
check this link:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Posted on Sep 06, 2011
LG Fuzzy logic 6.5kg WF-T7519PV washing machine.Sensor panel error PE where E is flashing indication with sound.
This PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch. If no water is going into the machine, check the water inlet valve operation.
Apr 24, 2017 | LG Washing Machines
I have a LG 3step Turbodrum Fuzzy Logic WF-T8018TP when I put on the auto/off button it keeps on showing me the error PE how can a fix this
The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
May 14, 2015 | LG Washing Machines
Fault PE....How do I replace the pressure sensor on an LG fuzzy logic 5kg wf-t502 top loader and where can I purchase this part?
PE Means pressure sensor error this spares is very rare to defect 1st check full pressure sensor the wiring harness any damage or wire cut means the error will show in display
Mar 26, 2015 | LG Washing Machines
LG model (WF-T1122TP) we are trying to wash all we getting PE what that means
Dec 07, 2014 | LG Washing Machines
PE error on WF 1330TP turbo drum machine
Aug 14, 2014 | LG Washing Machines
LG wf-t652a displays an error "PE" & dinging when turned on. Any suggestions.
Pressure sensor error. Check also the pressure hose. The pressure sensor stops the water at a set level depending on the cycle you choose.
Jul 16, 2014 | Washing Machines
Lg intellowasher wf t8501tp
My washer WF-T8501tp shows a PE error code.
Can anyone tell me what's wrong with it
Nov 17, 2013 | Washing Machines
M using LG's WF-T7516HN machine 6.5kg. it is showing error code "PE".What does it mean & what should i do now plz help.......
check this link:
Sep 06, 2011 | LG Washing Machines
Washing Machines Logo
121 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
