Question about Microsoft EXCEL 2004 for Mac
"unable to read file" message when opening an Excel workbook.
I created a workbook in Excel with a pivot table to present various financial data.  I also password protected the workbook.  Prior to today, I had opened and closed the file several times without problems.  However, on my last attempt to open the file I received the following message "unable to read file".
Is there a way to open the file? I am using Excel 2004 for Mac.
Thanks.
  • mac_pamela Jan 22, 2009
    Were you able to find a solution for this problem. I have the same issue and need an answer. Thank you.
  • unkeloz Jan 28, 2009
    same problem - even rebuilt the file, saved it, and issue came back after exiting Excel.  This sucks!!!
  • Microsoft Master
  • 3,866 Answers
Okay those of you that is having this issue try reinstalling the Ms office software along with any emulation program you have on you mac.. this will shore up alot of problems that can reside from coruption. Thanks
Posted on May 22, 2009
I was sent an excel file (.xls). friends on mac and pc can both open it.
i am on mac and keep getting unable to read error. it must be something with my mac. what could it be? nobody else has this problem.
How Repair of Excel file?
If there was such problem, the simplest decision is described here:
http://www.excel.repair/ - Excel Repair Kit. A Microsoft Excel repair tool for corrupted Excel spreadsheets. Program open, read and save data from damaged Excel files.
If at you it didn't turn out to solve a problem, it is possible to try to solve it otherwise:
1. Click the Microsoft Office Button Office button image, and then click Open.
2. In the Open dialog box, select the corrupted workbook that you want to open.
3. Click the arrow next to the Open button, and then click Open and Repair.
4. Do one of the following:
3. To recover as much of the workbook data as possible, click Repair.
(a) To recover as much of the workbook data as possible, click Repair.
(b) To extract values and formulas from the workbook when an attempt to repair the workbook is not successful, click Extract Data.
Oct 17, 2015 | Computers & Internet
Excel workbook error
I came across this issue today. An update to the Office Compatibility Pack that was still on a computer caused the default PROGRAM for .docx and .xlsx files to be the Microsoft Open XML Converter program and make the "Default Programs" in Control Panel think that Excel and Word were actually the Microsoft Open XML Converter scholarship essay writing assistance program as well.UNINSTALLING the Office Compatibility Pack in Programs and Features and then a simple reboot fixed the issue.
Also:
1: Try to repair it manually when MS Excel does not automatically STARTS File recovery mode.
Click the Microsoft Office Button, and then click OPEN.
Now select the corrupted workbook that you want to open.
Click the arrow NEXT to the Open button, and then click Open and Repair.
Choose either Repair (to recover as much of the FILE data) or Extract data (to extract values and formula when repair process is not successful).
2: Open with Open Office: Try to open your Excel file in Open Office. It is an open-source Office suite that is able to open & SAVE Microsoft Excel files.
3: Save in HTML Format: Open your Excel file and save it in HTML format. By saving the workbook in HTML format, you may be able to filter out the corrupted elements.
4: Save in SYLK Format: Open your Excel file and save it in SYLK format. By saving the workbook in SYLK format, you may be able to filter out the corrupted elements.
5: Try 3rd party software like Excel Repair Toolbox
link: https://www.repairtoolbox.com/excelrepair.html
Jun 18, 2015 | Microsoft Office Excel 2007
Size of the excel file increased from 721 KB to 50MB
Many businesses use Excel to track their data and expenses.
However, you can run into problems when files grow too big.
Try reducing the size of your Excel files in different ways to eliminate your storage problems.
Remove unnecessary graphics and fonts from the Excel file.
Simple report data doesn't need a lot of excess formatting to make it attractive.
If you need to keep different fonts in your file, reduce some of the font sizes you originally used.
Reduce the number of pivot tables you allow in your data analysis.
Run your pivot table wizard when dealing with involved calculations.
When given options to format the file, choose those that allow the data to refresh instead of adding a new table.
Input your data, close the file and save as an Excel (XLS format) file and as an HTML (XML format) file.
To do this, choose "XML Data" in the "Save as type" drop down box.
Change the name of your document as well, so you can tell the difference between the two files.
Open the XML file and save it back into the regular XLS file to create a smaller file than the original.
Again, rename this file, as well as changing its type. This act removes odd programming left from past calculations since the last "save."
Check into file compression software such as OzGrid.
These products exist because you cannot open a file once it gets too big.
Compress the XLS data by compelling the program to recalculate the cells used for your file.
Excel File Size Reduce Software 7.0
http://www.newfreedownloads.com/Business/Spreadsheets/Excel-File-Size-Reduce-Software.html
http://www.ozgrid.com/
or
Microsoft Excel files can contain thousands of cells filled with data.
When you combine this information with graphics, such as charts and graphs, as well as ever-expanding links to other worksheets, you can end up with an enormous file that takes up precious system space and slows Excel down.
While there are many software programs available that promise to shrink Excel files, there are many ways to reduce the bulk without downloading a new application.
1. Click on any cell in the Excel file you want to reduce.
Open the "Go To" dialog box in Excel 2007 by clicking the "Find" drop-down arrow on the Home tab of the ribbon and selecting "Go To."
In Excel 2003 or earlier, go to the "Edit" menu and select "Go To."
You can also use the keyboard shortcut "Ctrl+G" in any version of Excel.
2. Click the "Special" button on the "Go To" dialog box.
Select "Blanks" and click "OK." Click the "Clear" drop-down in the "Editing" group in Excel 2007 and select "Clear All."
In Excel 2003 or earlier, go to the "Edit" menu, point to "Clear" and select "All." This will clear any blank cells to help reduce the file size.
3. Go to the very last cell containing data in the Excel file.
Select the entire row beneath this cell by clicking the number to the left of it.
Hold "Ctrl+Shift" and then press the down arrow key to select all of the cells beneath this point.
4. Click the "Clear" drop-down in the "Editing" group in Excel 2007 and select "Clear All."
Select the column to the right of the last cell. Hold "Ctrl+Shift" and then press the right arrow key. Again, select "Clear All."
5. Repeat Steps 1 through 5 for any other Excel files that are linked to the workbook you are trying to reduce.
Save the files and then check the new file size by clicking the "Office Button" in Excel 2007.
Point to "Prepare" and then click on "Properties." In Excel 2003 or earlier, go to the "File" menu and select "Properties."
The file size will be listed on the "General" tab.
http://www.ozgrid.com/Excel/ExcelProblems.htm
Apr 22, 2013 | Microsoft Office Professional 2010
Excel sheet has been lost how to recover
Lost Excel file can be recovered from:
  1. Recycle Bin - If you have deleted the file with normal delete.
  2. Backup - If have maintained the backup of file.
  3. Email - It may possible that you have mailed the file to someone.
  4. 3rd Party Recovery Software - Recuva, Stellar Data Recovery ...
Oct 29, 2012 | Microsoft Office Excel (License Only)...
Properties in importing excel table to an access table
This article explains how to import a Microsoft Excel file into Microsoft Access version 2.0 or 7.0. Microsoft Access can import files from Microsoft Excel version 2.0 through version 7.0. However, Microsoft Access cannot import Microsoft Excel 4.0 workbooks (.xlw). This article assumes that the Microsoft Excel file is using standard database formatting. That is:
To import a Microsoft Excel file in Microsoft Access 2.0 loadTOCNode(2, 'moreinformation');
  1. Save the file in Microsoft Excel using standard database formatting listed above. Close the file.
  2. Start Microsoft Access 2.0 and open the database you want to import the Microsoft Excel information into.
  3. On the File menu, click Import. From the Import dialog box, choose the appropriate version of Microsoft Excel that you are importing and click the OK button. Microsoft Excel 7.0 files are not on this list. If you are importing a version 7.0 file, choose the Microsoft Excel 5.0 option.
At this point options such as whether to append to an existing table or create a new table may be selected.
To import a Microsoft Excel file in Microsoft Access 7.0 loadTOCNode(2, 'moreinformation');
  2. Start Microsoft Access 7.0 and open the database you want to import the Microsoft Excel information into.
  3. On the File menu, click Get External Data and then click Import.
  4. From the import dialog box, choose Microsoft Excel (*.xls) for the Files Of Type option.
    This will display only the Microsoft Excel files.
  5. Find the desired file and click the Import button.
The Import Spreadsheet Wizard appears and allows you to choose options specific to the file.
or you just use the link for any problem where you can get details of the importing
http://www.techrepublic.com/article/techniques-for-successfully-importing-excel-data-into-access/5276622
May 05, 2011 | Computers & Internet
What is exel sheet extension in office 2010 ?
Excel Workbook
.xlsx
The default Excel file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Workbook
.xlsm
Uses the same basic XML format as the Excel Workbook, but can store VBA macro code. Users saving an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Template
.xltm
Can contain a VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0). Workbooks created from this template inherit the VBAProject part or Excel 4.0 macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental program that runs additional code. Excel add-ins use the Open XML file format to store data, and they support using VBA projects and Excel 4.0 macro sheets.
Feb 21, 2011 | Computers & Internet
How can enable mail recipient as attachment excel
MAIL RECPEINT AS ATTECHMENT OPTION NOT VISIBLE IN MY OFFICE 2003 PROFESSIONAL
Apr 11, 2009 | Microsoft Office Excel 2003 for PC
MS EXCEL 2000 corrupted workbooks/worksheets
it sounds like you are going over the limits of the program these are the specs. I would recommend dividing up the data if you can. or moving it to a database that can act like excel and hold more data.
Apr 29, 2008 | Microsoft Excel for PC
Forgot password to open Excel sheet
If you mean that you can open the Workbook and read the Worksheet - then all you have to do is select all and paste it to another Worksheet. This will allow for changes of formulas etc.
If you mean the whole Workbook - then I dunno.
In future, either use the same password for everything (easy to remember) or Protect the work with nothing entered into the password field (leave this blank). This last will protect the work from people who try to guess your password, but will be easy for you to remember - eg every password is left blank.
If you must use unique passwords, then keep a record of them somewhere other than on your computer.
Sorry I can't help with the "Workbook" solution - but somebody else out ther may be able to do so.
Apr 25, 2008 | Microsoft Office Professional 2007 Full...
Excel Pivot view
Highlight the entire pivot table and name it as a range. Then in the formula, replace the reference to the table addresses with the range name. Then wherever you move the table (move, not cut and paste) it will automatically gather the right data. Thanks for rating FixYa!
Oct 19, 2007 | Microsoft Office Standard for PC
Microsoft EXCEL 2004 for Mac Logo
744 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
