Instruction manual for maytech water softener
Owners manual
2 Suggested Answers
  • 101 Answers
SOURCE: Pentair water softener leaks water;
open the top and reseat the hole,if not replace the hole. hop this could help you.
Posted on Apr 23, 2008
How to install a water softener
I know this doesn't occur to very many men, but I KNOW there are excellent step by step instructions in the manual. You should read it, or get a manual online.
Nov 17, 2013 | Valumax 5600SXT 30k Water Softner
Need owner's manual or set-up instruction manual for Pentaier Structural Water Softener - Model #CH30127
That is only the softener tank. We need to know what water softener valve you are using on the tank itself for further assistance.
RJ
Aug 19, 2013 | Pentair 14 x 65 Structural 30785 Poly...
My water heater is leaking and only 4 years old. Will the use of a water softener void the warranty?
The warranty should not be void by using water softener, BUT read product manual.
http://waterheatertimer.org/Water-heater-manufacturers.html
1) First thing: Why is water heater leaking? Where is the leak?
http://waterheatertimer.org/Leaking-water-heater.html
For example, if you have electric water heater leaking from element, then replace element.
Replace leaking TP valve.
If water is leaking down vent pipe, and combustion chamber rusted out, then vent problem must be corrected.
These are not covered by warranty.
If tank is rusted out, then read below.
2) If water heater is rusted out after 4 years, you might have stray current corrosion.
This happens when hot and cold pipes are not connected together with a ground wire, and/or if cold water pipe is not grounded to earth.
This might not be covered by warranty.
3) Read water heater instruction manual for advisories.
Tanks rust out when anode rod is depleted. Softened water depletes anode rod faster.
Instruction manual says to check anode rod each year.
Checking anode rod is like checking oil on an engine. If oil was never checked and engine burned up, the manufacturer will not honor the warranty.
If anode rod is depleted, and tank is rusted out, the warranty might not cover the rusted tank since owner was supposed to check for anode depletion.
4) Anode rods can also be covered with calcium deposits and stop working.
This night not have anything to do with water softener, but anode stops working and tanks rusts out.
In any case the owner's manual probably says to check anode rod to prevent leaking from rusted tank
http://waterheatertimer.org/Replace-anode-rod.html
Sep 07, 2011 | Water Heaters
Where does the fabric softener and washing powder go in the LG WF-F5207PC 5.5KG top loading washing machine?
Put powdered detergent in the box at the back of the opening of the washer (opposite the control panel when the lid is open). If you use a liquid detergent, dilute it 1:1 with water and pour into the bleach dispenser at the front left of the washer. The fabric softener dispenser is near the bleach dispenser but a little closer to the tub and towards the middle of the left side of the unit. As with a liquid detergent, dilute 1:1 (30ml:30ml) with water before pouring into the dispenser.
If the fabric softener dispenser isn't working, add the fabric softener in the final rinse.
The manual for the washing machine is available here: http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-F5207PC-_E . You will need to review the unit or enter a security code.
I hope this helps.
Feb 13, 2011 | LG Washing Machines
I need to know how to set the program on an elite water softener
You can find your owners manual here. http://www.nelsencorp.com/default.aspx?page=customer&file=customer/nelcor/customerpages/Fleck_Serv_Man.htm
Your system is a fleck 5600SE
RJ
Apr 12, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Water softener seems to be draining all the time
http://www.puritecwatersofteners.com/documentation/Hydrotech_5600MI_manual.pdf
I'm pretty sure this is the manual for your unit. It might not be exactly like the one you have but at least could give you info for it. This is something you might have to contact the manufacture for. Hope this helps!!
Mar 31, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Washing Machines Logo
Top Washing Machines Experts
