Question about Honda Portable Generator Model Ex1000
I have a ex1000 with a broken freq switch stuck on 50hz,how can I fix
Freq switch is broken stuck on 50 hz.all the fingers are exposed on front of switch.no buttons in place.can I jump out or move fingers to get 60hz
Kicker dx 250.1 class d monoblock amp has a fixed lpf at 80 hz 24db octave non adjustable. My car stereo is a pioneer deh-x55hd with the sub control set at 100 hz -6 slope unable to turn sub control off to...
Do you have the subwoofer amp connected to the pioneer thru pre amp connections; pre amp output of pioneer to pre amp input of Kicker amp. Page 10 of the manual explains how to adjust the subwoofer output. You can select the cutoff freq. that will pass to the subwoofer; The slopes don't match perfectly, but if you use the -12 slope , it should work fine.
Cut-off frequency:
50HZ
63HZ
80HZ same as kicker cut in freq
100HZ
125HZ
160HZ
200HZ
Output level:
24
to
+6
Slope level:
6
12
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-X5500HD_OwnersManual112712.pdf
May 19, 2014 | Car Audio & Video
E60 Error Code on converted 60Hz outlet
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
Unplug your washer for 1 hour and then plug it back.See if this reset helps.
Aug 06, 2008 | AEG L74800 Front Load Washer
Out of Range
Your horizontal should be between 30k-80khz while vertical should be 50-75 hz. So you are definitely too high. I would check supply voltages and open it up and look for any obvious issues with capacitors.
May 14, 2013 | Envision G22LWK 22" LCD Monitor
Please cherish me with samsung compressor capacity code,btu,armps chart for 220-240 50hz. Thanks for the co-operation.
Letter before the dash indicates vol/freq, Q for 220/240 @50 hz.
This will give you the decoding information you seem to be looking for on the compressor.
Sep 25, 2011 | Samsung Heating & Cooling
The time falls back by about 10 mins a hour? I am using it in India with a 230/110 adapter but working at 50 Hz instead of 60 Hz Is the timing derived from supply freq? i don't think so but just asking ...
The frequency of the power supply line IS where the clock obtains it's reference...it is divided internally to provide the timing for the microprocessor...the only way to make it work properly to my knowledge is to plug into 60 hz supply.
Jan 03, 2011 | Coby CRA108 Clock Radio
50 hertz microwave to send in Philippines which frequency is50-60
u.s. is all 60 hz. not sure in the phillipines,the only issue is it will cook slower due to the lower input frequency, it shows no electronic control board in the diagram, sometimes a different freq. can throw electronics off i.e. the clock would run slower and not keep accurate time on 50 hz. as it would on 60hz.
Oct 11, 2009 | Sharp R-510HW Microwave Oven
How do you set this stuff?
Need more info..
How many amps and their RMS rated power.?
If one amp, how many channels + individual power for each channel?.
Two crossovers set at the same freq.is redundant and likely to cause more problems.
Do the front speakers have their own X-over? whats the X-over point? and what is their freq. response (total) are they separates
Rear speakers same question.
I'll point out that you cant hear below 20Hz unless your a whale and very few instruments go that low except organs and synthasizers.
The subsonic filter merely block the lower harmonics from eating up amp power.
Their is no universal setting. all systems are different, as are cars, interiors, ears, windows up or down, noise floor, etc.
A RTA helps with the basics but you will still have to tune by ear,
Good sound is difficult enough to achieve,
Great sound is trial and error and very time consuming.
Sorry no simple answer here. Find a good installer ,preferably with sound judging experience,
It wont be cheap, but if you have enough money invested in the system, Don't skimp. or all you'll have is bragging rights
Best of luck, Sumthin
Jun 10, 2008 | Car Audio & Video
Connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
May 14, 2008 | Connex 3300 240-Channels Base CB Radio
Honda Portable Generator Model Ex1000 Logo
Top Honda Air Tools & Compressors Experts
John Trevino
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
