Question about Creative Labs Zen Digital Media Player
Can't find music on player
I am unabel to find the music that i loaded on my zen player. so i can't make a play list
  • 45 Answers
To creat a Play list you have to do it with the computer
connect ur player now in the creatives software u installed
there is facility to make play list
Thank U
Posted on Jan 05, 2009
Zen mozaic won't delete albums?
was your action deleting or just removing ?
Removing Tracks On your player, to remove tracks is to remove them from the Selected Music view only. The tracks are still in the player and can be accessed from submenus like Artists or Albums.
x! To permanently remove tracks, use the delete function. See Deleting Tracks. x!
On the main menu, select Music > Now Playing.
Press OK. In the Now Playing view, the progress bar changes to a rating bar.
Press OK again. The Selected Music view appears.
Press or to select a track.
Press and select one of the following:
Remove > Remove Track
Removes the current track from the list.
Remove > Remove All
Clears the list.
x!
Deleting TracksThis action permanently deletes tracks from your player.
> To only remove tracks from the Selected Music view, see Removing Tracks. <
On the main menu, select Music.
Select any submenu with audio tracks, for example, All Tracks.
Press and select Delete Track
x!
(details from "view all knowledgebase solutions" on the site of Creative)
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=17897&prodName=ZEN+Mozaic
Jun 28, 2009 | Creative Labs Creative Technology Zen MP3...
Need Creative Zen user manual. No longer on the website. I really just need to know how to create playlists if you can help me with that.
  • Creating playlists for Creative Zen MP3 player
  1. Step 1 Turn your Creative Zen MP3 Player on and add music to its hard drive if you haven't already. Without music on your player, you won’t be able to select tracks for a playlist.
  2. Step 2 Select "Music Library" from the Main Menu. The Main Menu should appear as the first menu when you turn your device on.
  3. Step 3 Select "Now Playing" from the options available, then press the Options button.
  4. Step 4 Select "Save as Playlist" from the list of options. This will save the tracks you have listed currently as a playlist that can be reloaded later.
  5. Step 5 To play a playlist back, go to the Main Menu, select the playlist and click
Jun 16, 2009 | Audio Players & Recorders
Have a new 4G mp3 player. How do I get to place
if you dont want it to stop after each album ..load your music on a single folder ( it will play in the order...probably alphabetical...so if you load them with the singer name first ..it will take the albums in order too), or look in its menu and build play-lists...in the other problem I dont know if it has the shuffle option or not ...you just look on the manufacturer site for the exact model ...and try to find meniu specifications..in case you do not have a user manual....
Apr 07, 2009 | Creative Labs Zen V MP3 Player
Zen v plus
I guess it broke.
Try re-installing the firmware, it's worth a try.
If this doesn't work, it means the screen is dead..
you can get it fixed for free if it's still under warranty.
Oct 13, 2008 | Creative Labs Zen Touch MP3 Player
Creative zen mp3 help please
You will need to put the Zen into recovery mode and erase the firmware, then reload the firmware. Follow these steps:
To Erase the Firmware:
1. Get a paperclip and straighten it out.
2. Hold down the Play/Pause button, and put the paperclip through the reset hole. Release the paperclip while continuing to press the Play/Pause button until you see the screen change.
3. Select "Reload Firmware."
To Load the new Firmware:
Go to www.Creative.com/support --> downloads. Click through the navigation and download the latest Zen Touch firmware. Reboot your computer, then plug in your Zen via USB cable. Double-click the firmware icon and then click upgrade.
Apr 02, 2008 | Creative Labs Zen Touch MP3 Player
Charging
As long as you have the USB 2.0 type cable, and the software loaded, you can charge the ZEN V on your computer. Be sure to load the software first. It will take several hours to charge fully the first time. While it is charging you can add music. When you see the plug icon in the upper right corner, it is fully charged. Be sure you are not adding music while you disconnect. Otherwise, just pull the plug and the ZEN should play for up to 12 hours.
Mar 21, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen stone mp3player....works but wont let me play music..
Here are a couple suggestions. Did you load music on? Do you have headphones in? Tried turning up the volume?
Feb 18, 2008 | Creative Labs Zen Stone Plus MP3 Player
Mp3 music wont play... all other functions ok
Your Computer may not be recognising it.
If it came with an installation cd,i suggest you reinstall but back up your music on a memory stick or recordable cd.
I would also try using another usb port.
I Doubt its stopped playing because its been dropped on the floor as my best friend has one of these,and her one has been dropped in the bath,on the hard floor lots of times and still works
Hope I Helped You.
Good Luck With It.
Regards,
Sophie x
Oct 26, 2007 | Creative Labs Zen Nano Plus MP3 Player
Mp3 player will not play syncsmusic
you may have a broken headphone jack.
do you have any music that you know worked before?
Jun 01, 2007 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs Zen Digital Media Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
