Question about Cameras
Need a driver
No disc
  • rockfixya
    rockfixya May 11, 2010
    ok provide me model number of your camera.
My kid has a vivicam5399 camera but when loading driver from disc the computer wont find the camera can solve this problem for me this is the secound camers we have bought we just ant haveing any luck
Posted on Jan 03, 2009
How do you get the install disc online if your computer want read the disc super multi drive install disc for windows
These days not many disc drives need external drivers. First I would check in the device manager, usually accessible from the control panel and see if the disc drive is listed. If it is and there are no notifications it probably doesn't need any other install. If you select it and right click then select properties it will tell you if its working OK and which drivers are installed. If there is a problem select reinstall or update driver and it will search for one and install automatically. If it can't find one and there is still a problem simply use a search engine put in the name and model of the drive then free driver download, there will be instructions on the site.
Nov 25, 2015 | Computers & Internet
Redfox netbook
You will need to restore the sound driver. If you have the recovery disc or OS disc the driver should be on the Driver/Utility disc. If not go to manufacturer's support site and download the driver.
Nov 23, 2013 | Computers & Internet
Need driver for PI845GLM-L
Driver files can be found at btjunkie.org this is a place I go and get them. If you need future drivers. More than likely you can get the mother board drivers from your disc set provided for you at the time of purchase if you kept them.
You will also need utorrent software as well it is free to download get the software here. Click Me go to the search box type in drivers use this example, XP drivers. There are lots of them you can put on one disc and then insert the burned disc with the downloaded driver files in the ROM drive and point to the driver that has a highlighted yellow triangle or a question mark in DEVICES window which can be found in the control panel or right click on my computer then have the disc ready to be pointed to find the driver during the update driver files link RIGHT CLICK to access the driver update options.
I have used the 700,000 or the 50,000 or any one of the large files of drivers and have been able to repair computers for folks that do not have driver discs that came with there computers. It has never failed me.
You might run into an .ISO which is an image file to download some drivers get the MAGICISO software program at btjunkie.org.
This should enable anyone to find drivers that are hard to find. Use as last resort. Try to use your original discs first or order a lost restore disc makes life easier when installing programs into your personal computer. You may also use paid for Driver update software as well these work pretty well and not to expensive which saves you lots of time and efforts as well. I use driver genius as one of my main programs you can also find this at btjunkie.
Thanks for using FixYa for all your questions. Do not forget to vote for me as well if I helped you. John
Feb 07, 2011 | Computers & Internet
I have re loaded maxtor onto anothe computer using the start up disc but when executing a window appears asking for driver information. what do i need to do ?
it is asking for the drivers that it needs to "talk" toyour drive. a driver is a small software program that makes a hrd ware device work. when you bout the drive there should have beena disc with drivers on it. perhaps the startup disc even. unplug the drive from the computer and install the drivers then re plug it in. it should work. if you do not have the drivers for it you can get them from www.maxtor.com/support
but most likely the disc you have has them on it. the trouble you have is that you MUST unplug the drive and install the drivers FIRST. othwise you will get an error asking for the drivers.
so just unplug it and put the disc in you drive and look for "install drivers" option when the cd starts up.
Jun 27, 2010 | Maxtor (A01E250) 250 GB Hard Drive
Pc will not recognize the camera seems to need a driver. wont load from the disc
Maybe a bad disc? Is the camera new? If it is, get a new disc and try it. There are drivers available on the net, some free, and some programs you have to pay for, but you definately need to get a driver set up some way.
Mar 15, 2010 | Panasonic Cameras
Barracuda7200.10 320 my computer tell me that there is no harddrive i need the drivers for it
You don't need drivers just:
Right click on My Computer,Manage, Disc Management from there you can see new disc the right click on that disc and create new volume and format disc.
Feb 26, 2010 | Seagate Barracuda 7200.10 320 GB ATA-100...
WHAT DO I DO AFTER I'VE INSTALLED WINDOWS ON MY SYSTEM DO I INSTALL THE TWO CDS GIVEN TO ME UPON PURCHASE AND IF SO IN WHAT ORDER?
If you want to install all the products that come with your os cd's, then yes, you will need to install the other disk. The disk should have somthing like "Disk 2" and Disk 3" written on it. If not, once you have installed windows you can install the rest in any order.
Good Luck
C2Solutions
Aug 27, 2009 | ASUS K8V-MX Motherboard
How to install driver disc software
Go into your device manager find the hardware you just installed. Select it and tell it to install new driver and when it looks for drivers select have disc, put it in and it will find the drivers it needs.
If you need more detail please let us know.
good luck, and please leave rating.
May 06, 2009 | Computers & Internet
Need replacement installation disc
Dear Sir:
Do u want operating system disc of drivers disc.
If you want operating system disc.
Please contact the manufacturer of the computer they will be able to send you the disc you need.
if you want drivers disc you can download the drivers for the support site of the computer manufacturer.
Regards
Mohammed.
Regards.
Mohammed.
Jul 18, 2008 | Computers & Internet
Cameras Logo
66 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
