Question about HP Compaq Presario SR1617CL PC Desktop
POWER AT HOUSE WENT OUT WHEN POWER CAME ON COMPUTER WILL NOT START UP WHEN I PUSH START BUTTON
  • HP Master
  • 5,660 Answers
Suggest you test to see if the problem is the Power On switch, or the Power Supply.
This is a Top view of the motherboard used in a Compaq Presario SR1617CL Desktop PC,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00496280&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=1144705
Scroll down to the photo of the motherboard. To the right of the Blue and Black ram memory slots, is a whitish connector with two columns of 12 socket holes.
Looking at the motherboard layout illustration above the photo, ATXPWR1 is the connector.
The 24-pin ATX main power cable from the Power Supply, plugs in here.
This is a general example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Observe the photo to the far right.
The Green wire is the Soft Power On wire. Abbreviated as PS_ON.
ANY Black wire you see is a Ground wire.
The Power On switch is bypassed.
The Green wire is briefly jumped to ANY Black wire.
IF, the Power Supply comes on you have a bad Power On switch.
IF, the Power Supply does Not come on you have a bad Power Supply.
This does Not involve any splicing of the wires, nor the wires of the Power On switch.
The preferred jumper wire is a straightened out paperclip, bent into a U-shape.
The top of the U, is wrapped a few times with black plastic electrical tape.
This taped area is for your fingers, and thumb to hold onto.
Turn the U upside down, and the 'Legs' are what is used.
One leg goes down into a socket hole with the Green wire in it, the other leg goes down into ANY socket hole with a Black wire in it.
Where the wires go down the connector, is the Back of the connector. This is where the legs of the U-shaped jumper wire go.
One leg of the U-shaped jumper wire, slides down into a socket hole with the Green wire, and RIGHT NEXT TO the insulation of the wire.
Has to slide down into the socket hole pretty far. Far enough to touch a female metal terminal at the end of the wire.
http://www.molex.com/molex/products/datasheet.jsp?part=active/0002081202_CRIMP_TERMINALS.xml&channel=Products&Lang=en-US
Same thing for the other leg of the U-shaped jumper wire.
Slides down past the insulation of ANY Black wire, and touches that female metal terminal at the end of the wire.
Contact made with the jumper wire is no more than 2 seconds.
The Power On switch is a Momentary Contact Switch.
Voltage used by the Soft Power On circuit?
5 Volts DC.
In comparison two D cell flashlight batteries store 3 Volts DC.
Not saying there may be a small spark. Have you ever played with flashlight batteries, and flashlight bulb when you were younger?
You can wear a glove on the jumper wire hand if it makes you feel safer.
Again;
This fits a LOT of desktop computers,
http://www.directron.com/atxswitch.html
You have to get power first before any diagnosing can continue.
Not to get your hopes up, but most if the time the problem IS the $5 Power On switch, or Power Supply.
Past this point it means fried motherboard, and/or Processor, and/or Ram Memory, etc.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Oct 30, 2012
Keep getting a E4 Code
This E4 Phenomena means "no water":
No or slow water fill (not
reaching the full level in 15 min),
therby computer sends display message "E4"
Reasons:
1) The house water tap is not open, or
2) This is the most common E4 reason- The water inlet valve (that the hose is connected to) is blocked.
3) The water pressure is too low and the flow is too weak.
Solutions;
1) Open the water tap, then push the START/PAUSE button again.
2) Clean the water inlet valve. Shut off house water supply on the wall then, unscrew (lefty loosy) each hose from the house and the machine and look for a screen and clean the junk away from the screens. You may have 1 or 2 screens depending on the hose there may be 1 screen where the hose connects to the house and another screen inside the machine valve. Then, return hoses and turn on the water pressure again, Then push the START/PAUSE button again.
3) Wait for the normal water pressure to return to the house before use.
Oct 08, 2013 | Haier HLP23E Top Load Washer
Lexus rx 300
might be computer is messed up
Sep 09, 2013 | Cars & Trucks
3 year old pushed the z power key and computer went into shutdown mode. Now it has no power. I have unplugged it, and held down power key for 30 seconds as suggested by ACER but still no power
shouuld havee restartd when you hold the power button down release and push to start but try this remove the charger and battery from the laptop
then press and hold thee power button down for about 3seconds
replace the battery and charger(charger should be plug into power source)
push the power button to turn on should start up
May 30, 2011 | Acer Aspire m5640 PC Desktop
Dell 4400 Main power in house went off while using my computer and then went back on about an hour later. Now when I try and restart the PC, the power button light turns yellow like it is in sleep mode...
The power supply or mother board probably went out. Did any other items in the house stop working? This happened to me years ago and the electric company reimbursed me for damages.
You can try unplugging the power cord for a few minutes, then retry listen for any beeps from the computer. If it is powering on but nothing on the screen and no beeps *********** board is probably toast.
Dec 10, 2010 | Dell Dimension 4400 Power Supply ** FREE...
I have a 2001 dodge ram sport. i went to the store and when i got out of my truck and closed the door the alarm ingaded, so i got the remote from my house and it wont disngage the alarm. how do i turn it...
There should be an override switch mounted up under the dash.. It willl either be a push button or a toggle switch.. If push button, with door open turn key on then off then push and hold the push button in for about 4 to 5 secs then the alarm should shut off nad the little led should goes solid. if toggle key on then off and the toggle the switch to the opposite side
May 08, 2010 | Ram Pickup Alarm Remote Auto Start...
Push button to start and does not start
Your problem could be with the "push to start" switch or "door" switch.
Apr 14, 2010 | Roper RES7648E Dryer
My 1999 Ford Windstar will not start. Drove it to a friends house just fine and went to leave and it wouldnt start. Havent been having any problems with it. Charged the battery, holds the charge. Will turn...
It sounds like a fuel pump or ignition module. Possibly may have tripped the inertia switch. Look on the passenger side kick panel at your feet.There is a switch there with a red button.Make sure it is pushed down.If not,push it down to reset it.
Mar 06, 2009 | 1999 Ford Windstar
Sony vaio will not turn on
sounds like the battery
see if you can have somebody that out like radio shack or best buy
Feb 07, 2009 | Sony Computers & Internet
Download not complete Leopard not working
Try to boot your computer with the Recovery disc, by turning on your computer and slot in the disc, and pressing the C key. If it succefully boot in, try to restore the Mac software.
Feb 06, 2009 | Apple MacBook Pro Notebook
Mp3 player shutdown
mine does the same thing i dont kknow how to fix it
Jan 24, 2008 | RCA OPAL M4001 MP3 Player
HP Compaq Presario SR1617CL  PC Desktop Logo
51 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
