Question about IBM 6500 Matrix Printer
Blank line vertical blank
  • bertollini Oct 29, 2012
    The printer goes through all of the motions of completing the print job, but the finished product includes a vertical blank area down the pages.
    Scholar:
  • 111 Answers
Sounds like you have a bad Fret, if moving over a fret from one location to another doesn't work then you might have a bad hammer coil on the shuttle assy and it needs to be replaced. I have in stock rcardenas@mrp.to
Posted on Dec 27, 2012
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
HP Laserjet 3052- Printing problem
Your printer's drum must be cleaned or replaced if damaged.
Aug 09, 2008 | LaserJet 3052 All-In-One Printer
A blank vertical line appears on every page printed
if it is a white void check laser shield glass. toner might be on it causing this problem. There should be a wand in front door use to clean laser area make sure you do each color. hope this helps.
Feb 09, 2014 | Ricoh Aficio CL3000 Laser Printer
Dear Sir, My Screen Of Samsung S8300 becomes blank whenever I make or call or recieve any call. In this stage the there is no response from the screen, but I can hear and talk on the phone,( I am not...
  1. first problem screen blank out
your mobile has a sensor at the top of you phone which is use to make you screen blank when you keep your phone near your ear to save power during a call.(it may be a sensor malfunction)
2.the vertical lines occurrence is common in all mobiles there's no prb with that!!!!
Jun 14, 2011 | Samsung S8300 Ultra Touch platinium-red...
Video displays vertical lines then goes blank
There could be 3 possible reasons for a vertical lines
1. Driver for graphics card needs to be updated
2. Grpahics card faulty
3. LCD problem
try connecting an external monitor and see if the display is also vertical on the monitor, if yes the problem is graphics card, if no, the problem is the LCD. Hope this helps
Dec 11, 2009 | Acer Aspire 5100 Notebook
Philips LCD model 26TA1000, vertical lines and blank white screen with no picture
it would be easier to find it stripped from a damaged set on ebay.
I see several there but need the part number to search
of course you may purchase that and find it to be the lcd driver.hopefully not.
Feb 17, 2008 | Televison & Video
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Blank vertical lines
Make sure you have good OEM supplies installed. Use a good vacuum and clean the toner from the laser scanner window.
Jul 24, 2007 | Canon FAXPHONE L80 Laser
Why do I get a line of faint or no copying on the page?
Does this blank line run top-to-bottom or side-to-side, and which direction is the paper traveling through the machine, portrait or landscape?
Jun 03, 2007 | Minolta EP1031/1031F CS/PRO Copier
White bar on top of screen
It only 1 bar in the middle horizontal? They Call it Vertical Line, sometime looseboard, defectiveVertical IC, Leak capacitor in vertical section. need a Repairman Tech.
Nov 19, 2006 | Sony FD Trinitron WEGA KV-20FS120 20" TV
IBM 6500 Matrix Printer Logo
27 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
