Question about Galaxy Radios DX-959 40-Channels Base CB Radio
10 kc drop at key up no transmit
RECEICE WORKS FINE ALL SWITCHES SEEM TO BE WORKING PROPERLY, BUT WHEN I KEY UP THE MIC IT DROPS 10 KC WITH NO OUTPUT POWER I CAN SEE MODULATION ON THE METER IN THE RADIO BUT NO OUTPUT POWER ON MY WATT METER AND THE TRANSMIT INDICATOR DOES NOT COME ON. I CHANGED Q51 AND Q53 AND STILL SAME PROBLEM. THANKS FOR ANY HELP ON THIS.
  • jolynz Feb 21, 2009
    THANKS, FOR YOUR HELP, BUT I HAVE ALREADY THAKEN IT TO THE SHOP AND IT WAS A RESISTER TO THE LEFT OF THE MIC, JACK. AT THIS TIME I DON'T REMEMBER THE LETTERING COMBO BUT IT WAS A LONG SKINNY ON THE CORNER OF THE BOARD ON THE RIGHT SIDE. NOW THE RADIO WORKS GREAT.
    THANKS AGAIN
    Champion:
  • 219 Answers
Have you changed the voltage regulaor, or check it first 2 outside legs should red your 13 volt middle around 9
Posted on Nov 21, 2009
  • ePowerAmps CB Radios
    ePowerAmps CB Radios Apr 25, 2011
    I would be nice to know how the issue was resolved. I have the identical problem. I'm not sure which part needed replacing.
    Oh well. I just passed it onto a local cb guy. Hopefully, he'll figure it out and I'll post the results here.
Why is humming coming from speaker when mic is keyed?
this is strange as most times if a proper transmit key is depressed , then the radio switches from receive to transmit , the mfg know this would cause some great squeal from receiver /transmitting so close to a receiver so the part that is the receiver is muted to keep this from happening , id say there is some fault in the part that does this muting of receiver
Apr 13, 2016 | Radio Communications
Uniden PRO510XL low output and "motorboating"
Hi
It sounds like your circuit board may have a bad solder joint. Sometimes during manufacture of the ciruit board, the joint could not be perfectly made. This will limit conduction and create heat which will worsen the effect over time. If you are familiar with opening and working with electronics then I suggest you remove the circuit board and inspect it for cold solder joints. When you find one, you can use a Cigar Torch type lighter to help reflow the solder easily. Out side of that, you mayu want to send it to a Electronics repair shop to do this for you. Let me know more and I will help. Good luck
Jan 19, 2008 | Uniden PRO510XL 40-Channels Base CB Radio
I purchased an old Realistic TRC-431 CB. When I turned it on it worked fine, the mic was keyed then the lights went dim and stayed dim. Now the lights remain dim. I checked the two output transistors...
The problem is with your power supply. There should be a big round transister on the power supply this is the power transister. It will be mounted to the power supply case. Replace this transister and try to operaste your radio again. Make sure that the power supply you use is at leat 7 amps or the radio will not operate properly and you will possibly blow the transister again.
Jul 16, 2011 | Radio Communications
I have a cobra power mic that has no audio output
Sounds like its not wired up right, the audio wire must be off,take the plug apart and check the white wire, re-solder it. here is the wiring, pin1-shield,pin-2audio-(white), pin3-transmit-(red), pin4-receive-(black).....hope this was helpful...
Apr 23, 2010 | Cobra 29 LTD CB Radio
It comes on but not receiving
One of 2 reasons. First is common. Your mic or mic jack may be bad. The way the radio works, is the mic switch switched from receive and transmit. When the mic is not keyed then the switch is actually on receive, and when you key it, you switch it to transmit. So if there is something wrong with your mic, or it is not plugged in, the radio will not be in receive mode.
The next problem if a new mic doesn't solve the problem is...
there is an issue with your antenna or feed system. Make sure coax is good. Use an ohm tester. Make sure its not shorted.
Next make sure the antenna is good and tuned properly.
You may need to replace one or both.
Jan 27, 2010 | Radio Communications
Cb is Keying Down instead of keying up when trying to talk
if you are transmitting fine Don't worry about the meter. Get an external SWR meter, they are better anyway.
Also, make sure the the switch next to the meter is all the way up on s/rf setting. thats for signal power and receive strength.
Aug 30, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Transmit button on the lapel mic will not key the radio
Two things which come to mind, one would be if the PTT on the remote mic is bad/defective, second would be you are plugging the audio device in with the radio turned on.
If your remote mic is failing, the PTT is a repairable item, as is the cord on most models.
Mar 30, 2009 | Motorola MU21CV (1 Channel) 2-Way Radio
Telex WT55 wireless lapel mic & FRM70 Receiver
How do I set the squelch on a TELEX FMR-70 receiver?
Jan 27, 2009 | Telex FMR70 VHF Wireless Microphone...
Magnum 257 No Audio Being Transmitted
Hello.I have a similar situation on a Magnum 257 HP operating on SSB (AM and FM works fine). If i Transmit it works fine, but when i release the Mic button (after TX), in the bottom side were the RX level should be, it appear somth like a signal level 3 to 5 (constant and continous), but i can't get any reception at all. Only if i turn the TX power level to MAXand i transmit, then it goes back to reception, but not every time. Somtime after TX i need to push the mic button 2-3 times to make it recive somthing, but this wors only if the power level is over 60-70% an i repeat, only on SSB.Can i get some help with this issue?
May 10, 2008 | Magnum 257 CB Radio
Galaxy Radios DX-959 40-Channels Base CB Radio Logo
179 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
