Question about Bowflex Treadclimber
Need to know how to change walking belts on a bowflex tc5000
All i need to know is how to change the walking belts
SOURCE: the machine will quit wright after you start and
Had my TC5000 for a year and this is the first time this happened. I use it everyday. Googled "Bowflex Teadclimber error codes" and found this link  download.dfxi.com/supportdocs/AM/Bowflex/BFX_TC135_AM_2008.pdf which is a pdf manual.
I'm going to try this fix now, hope it works for you and me
Here's what it says for ERR LS:
Belts stop turning and “err LS” or “err OS” is displayed Calibration Re-calibrate machine using Owner’s Manual calibration procedure. Speed sensor 1. Cycle power off and on. 2. Put the machine in calibration mode (see Calibration procedure in Owner’s Manual) but do not start the calibration routine. 3. Remove right rear plastic cover to view LED diagnostics on control board. Caution: Machine is on. Current is active!! 4. Locate LED D on the motor controller board. LED may be lit or unlit. 5. Manually advance the treadle with your foot, and check if LED D is blinking. 6. If LED D is not blinking, then the speed sensor is not supplying a signal. Check that the speed sensor wire is plugged into the motor controller board, to the connection labeled “P1”. Check connection of speed sensor to jumper wire. Check speed sensor adjustment (use business card to set gap between sensor and pulley). If LED D still does not flash replace sensor. I/O cables If LED D is flashing when the belts are turning but err LS or OS persists check connections and for signs of visible damage to any of the three I/O cables. If no damage, check continuity using a multi-meter. If a multi-meter is not available contact customer service for replacement cables and further assistance.
Mike
Posted on May 30, 2009
ercupa190
  • 12223 Answers
SOURCE: I went to push the power button on my Bowflex
Dear Sir:
Thank you by your question, and I will try to help you.
1) The power button may is defective or dirty contact.You must turn off the power( disconect the power cord) 2) Clean with special spray for lubricate switch, etc( Radio Shak or other Electronic Shop) you can use too alcohol isoprophilic to 100% very effective!.
3) Try to probe again, conect the power cord.
4) If not solution with this, reset the circuit breaker, and try again.
5) Measure with DVOM, the transformer, and see very carefully if there are Input to the transformer and output from the transformer, check any electronic component around of it. See if there are some smell to burn( like capacitor, diode, resistor, transistor, or some faulty cold solder) and fix it.
6) If everything is o.k your problem will be in Relais or contactor for the main motor, try to clean the relais or contactor, very carefully, disconnect the power cord, and clean the contact with special spray for electronic contact, or use the alcohol isoprophilic 100% . 7)Try again, if after check all STEP, mentioned before the problem is the PCB, you must contact to the factory for replace the PCB.
Thank you in advance, sincerely. Blessing. If you neee additional help, you can reach me. E.CUADRA MANAGUA, NICARAGUA. C.A.
Posted on Sep 26, 2011
ercupa190
  • 12223 Answers
SOURCE: Bowflex TC5000 L5 Belt will not move antmore.
Dear Sir:
Hello , I hope everything is fine with your family.
Thank you by your request, and I will help you inmediately.
You have a Mechanical problem, please do the following:
Please do this with carefully!
The motor drive belt is adjusted independently from the walking belt. Some newer models have an auto tensioner which is a lever that has a wheel that puts pressure on the drive belt and a spring on the other end that automatically loads the belt to the proper tension. You should not adjust these since they are preset.
Tension can be affected slightly by adjusting the tension of the walking belt but if you have a slipping problem, the drive belt will require replacement. If your drive belt is too loose, it will slip on the front roller pulley or the motor pulley. If it is too tight, it will increase your amp draw to the point that you may have an electronics or motor problem. Due to this, it is better to be on the safe side and replace a drive belt rather than risk over tightening it. A drive belt is usually $29.99 or less while many parts you can damage by over tightening can be more than $300.
Additionally, too much tension can cause bearing failure in the motor and the front roller and front roller pulley failure. It is better to having the belt a little too tight rather than too loose due to the possibility of injury if the belt slips.
Motor Belt Adjustment- Icon Units
DO NOT REMOVE ANY OF THE MOUNTING BOLTS TO THE MOTOR. SOME MODELS WILL REQUIRE 2 9/16" WRENCHES AND MAY REQUIRE TWO PEOPLE TO ACCOMPLISH THE REPAIRS
Before beginning this repair: Check to make certain that the drive belt requires adjustment. Check out belt slipping instructions or with the motor cover removed, walk on the belt normally and try to stallthe belt to make it slip.
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
Step 1- Find the motor mounts
. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Step 2- Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Step 3- Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts from Steps 1 and 2 and test your treadmill for slipping. If belt continues to slip, repeat Steps 1, 2, & 3. If a second attempt does not repair the problem, skip to Step 5.
Step 4-
If your treadmill is not equipped with a bolt as described in Step 3, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described in Step 2. Tighten the bolt from Step 1 and test. If the problem is not corrected, repeat Steps 1, 2, & 4 and retest. If problem persists, skip to Step 5.
Step 5-
If you have arrived at this step, let's make sure you have a drive belt tension problem. With the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The entire front roller assembly repaired or replaced (see the help topic on replacing a pulley) and the drive belt must be replaced. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
Step 6- The belt should be able to be turned by hand at approximately a 90 degree angle from its normal operating position.
Thank you in advance, sincerely. God bless you.
If you need further help, please reach me.
E.CUADRA
Posted on Sep 28, 2011
What does error code 1649uli indicate?
You have to call the Company representative who will guide you through the error code. Call :1-800-628-8458
In case you don't have the manual, here it is: http://www.searspartsdirect.com/partsdirect/user-manuals/TC5000-Bowflex-Parts-BOWFLEX+TREADCLIMBER-manual
Good Luck!
Feb 02, 2016 | Bowflex TreadClimber TC5000
Why does my Bowflex TC5000 cut out?
If you're running the machine on a dedicated circuit then your unit is drawing too much current. This can be caused by friction and drag. Solution: Lube deck/belt. If problem persists, replace deck/belt. If you ignore this fix this will blow your controller. .
Apr 29, 2014 | Bowflex Tc5000 Climber Treadclimber...
HOW TO CHANGE MY TREADCLIMBER TC10 WALKING BELTS
Bowflex has a service manual for the TC10 that includes walking belt replacement instructions, If you call customer service they should be able to email the whole manual or just the belt replacement steps.
May 07, 2013 | Bowflex TC1000 Treadclimber
Bowflex TC5000 won't start! Lights on circuit board show power.
see the video and proceed according and fix it. God bless you
Jan 08, 2013 | Bowflex Tc5000 Climber Treadclimber...
We canNOT get the belt on the new treadclimber - there's no give and it's just not going
Can you describe your machine type (TC5000, for example) and what you've done to try and reposition the belt? Also which belt are you referring to? The treadle belt or the motor belt? I just went through a complete deck/walking belt replacement, and it's not for the faint of heart. Needed to dismantle almost 85% of the machine.
Aug 28, 2010 | Bowflex Treadclimber
I have a TC5000 When I am walking for about 5 to 15 min. It stops. and when I pull the safty pin out and put it back in its ok for about the same time and quits again.
Check to make sure steps are being counted. This tells the machine someone is using it. The step counter is in the center of the steps on most machine. It will sometime count intermittenly. Another thing to check is if the machine seems to be laboring more when you start to walk on it. This could be a sign that it needs lubricating. Check manual for lubricating proceedures.
Nov 16, 2009 | Bowflex Treadclimber
I am having trouble with my Bowflex TC5000. The calibrations is failing. The treads aren't moving but the monitor is trying to calibrate.
The motor must move the drive pulley for calibration to pass. remove rear covers and check drive belt. you should hear the lwr board relay click to engage the motor. if you hear it and the motor does not move and you have checked the belt then you need to test the motor. Typically remove the belt and turn by hand...it should be very smooth and spin freely. If not replace the motor. Direct 9 volts to the motor leads unplugged from the board will tell you if the motor is good. be careful as capacitors are present and risk of shock is always possible. capacitors stay charged for about 10 mins after unit is unplugged
Jul 30, 2009 | Bowflex Treadclimber
The machine will quit wright after you start and
Mike
Mar 18, 2009 | Bowflex Treadclimber
My bowflex tc5000 will not calibrate
Check the speed sensor and make sure it is no farther than a credit card away from the drive pully. Unplug unit Located...remove left and right rear covers and back cover. 3 screws in each and 4 screws in back. Follow 2 black wires up to drive belt pulley under back of left treadle. slide sensor in with cc between it and the pully. Recalibrate
Dec 07, 2008 | Bowflex Treadclimber TC5300
Bowflex treadclimber 5000
Hi ddmyatt.. They sell what is call dry lube at sports store's. for spraying under the tread's and on the wheels that the tread run's on.. Lift the tread and spray as far under it as you can on both side's. She'll be lot's quieter then before and lots easier on the motor too..
Nov 03, 2008 | Bowflex Treadclimber TC5300
Bowflex Treadclimber Logo
216 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
