Question about Gateway Computers & Internet
I could hear the computer come on and I see the blue light telling me that it is on but the screen does not come on and the red lights that usually appear is not on. Is it broken? It does not turn on even when it is plugged up.
  • Gateway Master
  • 7,627 Answers
How old is it? Perhaps the Monitor is gone or graphics card or it could be as simple as a tiny switch that shuts-down the monitor when the lid is closed. need more info. What red light? I have a old Gateway MX6421 Laptop
Posted on Oct 29, 2012
farhangM
  • 64 Answers
SOURCE: Gateway Laptop not charging
It sounds like defective power jack. Bring it to a reapir shop.
Posted on Dec 01, 2008
  • 461 Answers
SOURCE: gateway laptop randomly shut off and wont come back on
Try removing the battery and see if will start up with power adapter. The battery may have failed. If it is a couple years old the battery may need replaced.
Posted on Apr 01, 2009
Geekman
  • 32281 Answers
SOURCE: Screen won't appear upon start up and I get 3 beeps but no screen
3 beeps POST code (power on self test) means RAM problem.
Reseat the RAM module/s and boot up your computer.
If you have two RAM modules, remove them both and insert one at a time to test them, to determine which module is faulty.
If it still doesn't work then replace the RAM module/s
Posted on Apr 02, 2009
budmrtn
  • 11361 Answers
SOURCE: power comes on but screen stays black
The backlight inverter board may be bad, or worst case will be bad lamp. You should look to see if the cable comes off the inverter board first. You may learn maore here:
http://www.insidemylaptop.com/category/5-gateway-laptops/
Please post back what you find.
Posted on Nov 15, 2009
  • 63 Answers
SOURCE: The "wireless on" light will not go from red to blue
Try this :
1.Download the latest wireless driver for computer (7.20 REV:A, 2/20/09) - Might change depending on your CPU, (7.20 REV:A is for AMDs)
2.You will also need to download the latest Bios (F.42, 3/9/09)
3.Latest version of HP Wireless Assistant (3.00 REV:K, June 2009)
NOW YOUR READY TO START FIXING?????
INSTALL STEPS: You must use this order for an 100% fix
1.First flash your computer with the latest BIOS and if should restart after its complete.
2.Install the wireless driver
3.Install HP Wireless Assistant
4.Restart your computer
5.Flash Bios again
6FIX
Posted on Apr 20, 2010
The blue & red lights on my JVC HD-56G787 tv are blinking alternately
Or the problem could actually be a power supply failure
Nov 08, 2013 | JVC HD-56G787 Television
II get sound for about 15 sec. but no picture and then shuts off
kp57ws50_57_in_rear_projection_hd_228277.jpg Problem with Sony KP-57WS520 57 in. Rear Projection
This model is really prone to one problem in particular--screen even briefly comes up bright red, green or blue and set shuts down.
15 seconds from turn on front power light should blink as set checks several things internally---if something wrong it does not let picture show.
Usually after shut down or failure power light will blink a sequence of blinks but not always depending on problem.
Did you see the screen at all go red, green, or blue before?
the more you tell me the better I can help
Mar 28, 2012 | Sony KP-57WS520 57" Rear Projection...
I have a 24in wide lcd monitor for my computer and
mcdevito75 here, The red power light usually means the monitor is off, if when you press the red button it turns to green, or blue then the red power button means the monitor was off. Your monitor could be burned out.
Jul 16, 2010 | Computers & Internet
Hear sound out of computer rather then earphone. Has worked great up until now. Blue light will not stay on. When charging light is red.
when the red light is on while charging it means it is at less than 25% charge let it charge until the light is green
then tryy connecting it to the computer
Dec 01, 2009 | Motorola Mobility S9 Headphones
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
My screen is bleeding light blue/start up the screen is red
this is an easy fix......your moniter is broken or your video card is broken replace them.
Aug 10, 2009 | Compaq Computers & Internet
View sonicvx2235wn
Hi.
Are you able to see a slight image on it at dusk and maybe with the help of a flashlight. since your blue light stays on the video board, may be okay.
If you can hear audio then your problem should be in the inverter board.
It could have bad capacitors or possibly a burned out transistor.
There is a chance one of your bulbs is creating a problem, but you would usually see a flash of the screen if that were the case.
Even though you do have sound the power board could still be the culprit.
Only way to really tell is to open it up.
If you unplug the screen to video board ribbon, you may notice a different effect in the screen lighting.
Should the screen happen to light up all white, then your inverter is okay.
If it looks pinkish or dark or flickers then the bulbs or a bulb may be the issue.
ebaysbammbammfran
Oct 12, 2008 | ViewSonic VX2235wm LCD Monitor
Tv screen stays black with the blue light and two red lights blinking
I have the same problem, if anyone has a solution PLEASE mail me at macry2121@aol.com
Apr 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Red Light
convergance ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Sep 03, 2006 | Hitachi 57SWX20B 57" Rear Projection...
Computers & Internet Logo
47 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
