Question about Canon IR 1600 COPIER FOR 220 VOLTS ONLY
Canon copier ir1600 it keep on indicating add toner even after replace a new toner.what can i do and a technician?
  • john kamau Oct 29, 2012
    am a technitian
  • 7,627 Answers
Did you try to restart the machine, as in shut-down or up-plug and restart?
Posted on Oct 29, 2012
  • 1 more comment
    yes ! it keep on indicating add toner but if i could know where the toner is i could try and clean it!
    yes !
    yes ! it keep on indicating add toner but if i could know where the tonersensor is i could try and clean it!
3 Suggested Answers
  • 64 Answers
SOURCE: Canon Fax L100 - toner required even though not empty
hi
first do use the original toner if no use the original toner if yes check the toner cartridge may could be brocken ore the toner jammed on it if its ok you have to check the toner sensor that located in side the fax m/c under the toner cartridge may its came out of position .
thanks
Posted on May 21, 2008
SOURCE: I Just replaced the toner
Hi carolyn ,
I am a professional canon service eng . My Name Is D K Kumar . e100 is not related to toner at all . it is the indication that the develper unit has not been detected . remove the left side cover . you will be able to see the top of the develpoer unit. On the left top portion of the developer unit u can see a white coloured accuvator . it is a small white plastic piece ..whhen the side door is closed te white piece should get pressed or should move forward . if the moving action is not happening then the m/c will give u E100 error. in your case the reasons /problem could be :
!) The spring connected to the white plastic accuvator is missing or spring action is not happening.
2) the white accuvator it self is broken or missing.
3) the plastic stick /piece which protudes from the side door and pushes the accuvator is broken.
4)lastly you have not closed the side door properly or not closed at all.
Carolyn if u r able to understand my above tips thn u can do it your self , if not call a your local canon enginer.
best of luck God Bless u
P.S. Carolyn if my solutions have helped u then i request u to kindly reply to me at my enail id: narkumar81@rediffmail.com
Posted on Apr 10, 2011
Canon IR1600 problem light copy
Hello, Either toner cart. for fusing unit is bad. Here is website for manual download.
Canon imageCLASS D860 Basic Manual
Jul 03, 2014 | Canon imageCLASS D860 All-In-One Laser...
My canon ir1600 does not copy the output paper is white please advice
Take the toner package out, shake it, put it back.
Buy a new toner cartridge.
May 05, 2014 | Office Equipment & Supplies
Canon IR1600 Copier
what do you mean copy halfway only on the top of the paper or only on down side of the paper, or only on the left side or right side of the paper...are u using A4 paper..?
Dec 09, 2013 | Canon IR1600 230 VOLT 50/60HZ
I Just replaced the toner in my CANON IR1600 PHOTOCOPIER and now have the Error code E100. I put the old one back in to see if it was different but it still said E100. How can I fix this? Thanks
Hi carolyn ,
Apr 10, 2011 | Canon Office Equipment & Supplies
Want to correct a system error E000 on canon IR1600 photocopier
E000 indicates a low temperature problem in the fuser unit.
  • Check the fuser for any jammed paper and remove it
Check and replace with spare part if needed:
  • the thermo lamp,
  • the thermistor in the fuser unit
A code reset is needed:
  1. Press ADDITIONAL FUNCTIONS, #
  2. Go to #7 PRINTER, press OK
  3. Go to #4 PRINTER RESET, press OK
  4. YES = (*)
  5. Power cycle the unit.
Jan 05, 2011 | Canon iR1600-2000 PS
Canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Jul 02, 2010 | Canon Office Equipment & Supplies
Toner out light
Open an close the front door on the machine a few times and it will add enough toner to extinguish the toner add light.
Feb 17, 2009 | Canon ImageRUNNER 1670F Copier
The start key does not stop its cycle
Control panel definitely needs replacement. Based on the age of the unit and the cost (at least $350) of the repair, I would recomend replacement.
Nov 10, 2008 | Canon NP 7130 Black and White Copier
Canon IR 1600 COPIER FOR 220 VOLTS ONLY Logo
95 people viewed this question
old marine
old marine
