Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door opens alittle then closes but not back all the way
Ok let me try to tell you the problem I'll push door button to open door door opens about 18 inches then reverses maybe back 8 inches.So I'll push botton again samething happens over and over never closeing or opening all the way so you have to keep pushing button to get it back closed.This a 1/2 hp door opener Thanks for any help you could give.
  • carris427 Jan 05, 2009
    Hi again thanks for info alittle more about problem this was working fine then just started.I did before lube door and by hand works nice spring feels and looks good.Like I said I push door button door opens 18 inches stops so I push again door will close 6 inches then reverse and go another 6 inches never closing or opening.Then everytime you try to open or close just does samething over and over and like I said was working fine before.To get it to close back down push botton and it goes down then tryes to reverse before getting to bottom so push botton and it stops and then push again goes alittle further down keep doing that until its closed all the way.Like a said this was working fine day before a few days ago I adjusted the down travel alittle and lubed door other then that seemed ok.Thanks for any help
    Hay guys one other thing this does this with or without door hooked to it.Thanks
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
If you have a Chraftsman/Liftmaster:
1.Check to see if the door is running correctly.
A. Run the door down and pull the emergency release. See if the door will run easily by itself.
1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of lubricant (not WD 40)
2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken or needs more tension) in this case call a professional door repair company in your area.
B. If the door runs fine then check the up and down force on your operator (the box that hangs from the ceiling and reads Craftsman). If the light(s) on your operator go from front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
C. If this does not solve your problem the top bushing could be going out of your operator. Open the case and see if a lot of black filings are on the top of the big gear. If so the gear assy. will have to be replaced part # 41C4220A
Posted on Jan 04, 2009
My door will open and close completely, then the next time it only begins to close ,goes about 12 inches then reverses..what is wrong with it
Try turning your down force up alittle higher if your door is only wanting to go down a foot or so. If your light bulbs are flashing, you then have a problem with the safety eyes.
Dec 26, 2014 | Building Materials
Refrigerator door will not stay closed
HI MANDY.normally the gasket dont go.it's rare.i would think u'll need to check the bottom door bush.parts difficult to get.u'll probably need to get a MANMADE ONE.good luck ali
Jul 12, 2012 | LG LSC26905TT Side by Side Refrigerator
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
Door goes down and when it stops at botton, it turns and goes back up ??? Need adjusting ..How can I adjust???
Adjust the position of the door by using the black and purple buttons. Black moves the door UP (open) and purple moves the door DOWN (close)
Setting the up position: 1. Press and hold the black button until the LED starts flashing slowly, then release. 2. Push and hold the black button until the door reaches the desired UP (open) position 3. Push the door control or programmed remote control. This sets the Up (open) position and begins closing the door. 4. Immediately when the door begins to close press and release the black or purple button. This will stop the door Setting the Down position: 5. Push and hold the purple button until the door reaches the desired DOWN (Closed) position. 6. Once the door is closed, If there appears to be too much pressure on the door, you may toggle the door back and forth using the black and purple buttons to reach the desired closed position. 7. Push the door control or programmed remote control. This sets the Down (closed) limit and the door should open.
Aug 11, 2011 | Chamberlain 3/4-HP Whisper Drive Plus...
Can not open the door in microwave the release button springs seem to not working can that be fixed. Have opened the release button but cannot see the problem
Do not pry the door open since there is an easier remedy which will lead you in the direction that you need to fix your problem. Take the cover off after you disconnect the power to it. Once you have taken the cover off (only a few screws) you will be able to see the two latches that hold the door closed and the link that opens both of them. You can just lift both latches at the same time and it will open. After you have done that take a good look and press in on the open door button and you will see where you have the problem of the door hanging. That button should push a linkage that pushes up on both latches at once to open the door. It is spring loaded so that it comes back down so that when you close the door it will hold the door close.You need to take the cover off the microwave so that you can pull both of the latches that hold the door closed up. When you push the button in it engages a linkage that pushes both taches up at the same time to open the door. It is springloaded and will come back down during normal operation to hold the door closed when you close it again. That area is where your problem is. By looking at what happens when you press the open door button you should be able to readily see where the problem lies in that linkage
Feb 12, 2011 | Sharp R-1610 Microwave Oven
I have a problem with a guardian 21230L garage door opener when you push the button the light flashes but no door movement happens can you help cheers Tom
I have the same problem. Door does not open or close when press the push button and/or transmitter. The light flashes 5 times. Manually open or close the door is ok. On the manual troubleshoot, it says it's either the opener is overheated or it's on vocation mode. I don't know how to switch of vocation mode. Is it possible the thermal sensor is broken?
Can someone help?
Jan 28, 2011 | liftmaster Electrical Supplies
I have Garage Door Opener from Sears. Wall push button & the the remote from my car open the door OK , but it does not close the door from my car (which is programmed) Wall push button close the door...
If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have bad sensors.
Dec 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door opens OK using the remote or wall push button switch Door will not close on either remote or wall push button switch Door will close if we hold wall push button until door closes How do we...
Use the pull cord and disconnect the opener from the door.
Operate the opener and let the carrier slide back away from the door.
Is the carrier moving smoothly when disconnected?
Next, lift the door by hand from the bottom to the top. Is it moving smoothly?
If not, lubricate the axles of all the rollers on both sides of the door.
Check the cable pulleys at the top sides of the door channel, lubricate them as
well. Are all cables in all the pulleys, there are 4.
After checking those things, there is a "up force" and "down force"
adjustment on the opener, try increasing the "up force" by turning the
adjustment in the direction of MORE force.
Give me some thumbs up if this helps you.
Gary
Dec 14, 2010 | liftmaster Chamberlain Garage Door Opener...
GE French door fridge problem. When you close one door the other door pops open alittle most of the time. Is this normal on french door fridges?
Hello, In a word, Yes. It is totally normal, when you close a door it pushes air into the unit and depending on how it is closed the other door will "pop" open slightly from the "push" of air. Thanks for coming to fixya. macmarkus :)
Jun 20, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
Door dosent close.move about 1 ft then opens.gear was replaced prior.worked for 2 days.now will not close.no flashing warning lights,when door disconnected garage door ok, springs ok,disconnect chain from...
You may not have had the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen the coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Jul 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
424 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
