Question about Pioneer Audio Players & Recorders
My pioneer reciever loses fm signal after 3-5 mins of use then goes to static.
Its an early 90s sx 2300.plays fm perfect for a few minutes then cuts out to static.
  • Rj Almeida Oct 29, 2012
    it plays perfect for a few minutes,i can turn it up loud with no distortion,works perfect at a low or high volume.the volume knob is smooth thru the range and doesnt distort when raising or lowering the volum.im only running two speakers,one per channel.
    once it begins to lose signal after a few mins it slowly distorts till only static is audible
I would begin by re-booting the receiver. Your operations manual may have instructions about how to re-boot. The second thing I would address is the placement of you FM antenna. Perhaps when you turn on the FM band you may sit in a certain position relative to the placement of the antenna, which may affect your signal. The question would become even more complex if you get your 5 minutes of good FM sound when you turn on the receiver, or is it just when you switch from any other function to FM. This could be related to the heat factor in the receiver which affects the connections to FM function..
Ernie
Posted on Mar 22, 2015
    Master:
  • 444 Answers
Do you have a (FM) Antanae hook up to it?
Posted on Oct 29, 2012
tech48
  • 624 Answers
SOURCE: My pioneer sx-315 audio reciever
The problem you are having is the unit is going into protect.
You can try disconnecting all the speakers and then see if it turns on. If it does turn on you may only have a bad speaker.
Then just turn the unit off and plug in one speaker at a time. If it still turns on, that speaker is good. Keep doing this with each speaker until it goes into protect again, and then you know the last speaker plugged in is the bad one. Make sure you turn it off after checking each speaker.
If it still goes into protect with all speakers disconnected you most likely have a problem in the amplifier circuit.
I have the complete service manual in PDF format with parts list and schematics, but it cost $10.00
Let me know if you want to purchase it and I will give you instructions for that. I can give you a direct download link after purchase using PayPal.
If you would like any further help just let me know.
Dave
Posted on Jun 27, 2008
tech48
  • 624 Answers
SOURCE: Pioneer sx-205 gives a overload
Does it play normal on any sources, or do you only have the tuner and CD for available sources?
There are many different things that can cause this type of problem.
It could be bad solder connections on in the amplifier circuit or power supply, it could be a bad speaker or a bad output channel inside the receiver if this happens only when it gets turned up loud.
The overload warning happens when the amplifier circuit has excessive current or DC voltage on the outputs. Unfortunately the only way to determain if it is the speakers is to change them with other known good speakers and see if it still happens. But before buying any speakers you need to have the receiver ruled out as the source of the problem.
It can also go into overload if you have the wrong type of speakers connected, or too many speakers connected. Each speaker jack should only have one speaker connected toit. If you are using for example, 4 speakers connected to the "A" speaker jacks meant for just 2 speakers, it will create a load to the amplifier that the amplifier is not rated for.
Look on the back of the receiver and it will have listed the proper impeadance for your receiver. Most will say:
8 ohms or more "A" or "B" speakers
16 ohms "A" and "B" speakers
That means you must use 8 ohm or higher ohm rated speakers if you are using only speakers"A" or only speakers "B", but can not use 8 ohm speakers if you are using speakers "A" and "B" at the same time. Then they must be 16 ohm speakers.
Two 8 ohm speakers in one speaker jack is a 4 ohm load, that is why you can not use more than 1 speaker per speaker jack.
I hope you found this information useful, and if I can be more help just let me know.
Dave
Posted on Jun 28, 2008
SOURCE: Pioneer Stero Receiver model SX-3700-
It sounds like your volume control pot has dust in it.You need to remove your cover from the receiver,spray pure denatured alcohol in the small openings in the back of you volume control dial and turn the knob all the way up and down several times and then blow low compressed air threw the same small openings while rotating your dial.That should fix your problem.Be sure you unplug your receiver before performing this procedure.
Posted on Feb 20, 2009
smarthome2
  • 1114 Answers
SOURCE: I have a 'vintage' (70's) Pioneer sx 535. What is
Depends on the connection on the back. Most older receivers used unbalanced 300ohm connections. In short, any speaker wire will do. Newer models used a "F" type connection (Coax end) which you can still cheat and get a 75 to 300 adapter at radio shack or any other local electronics store. Hope this helps.
Posted on Oct 01, 2009
Testimonial: "Informative. Thanks. "
SOURCE: Looking for replacement remote for Pioneer sx-205
The Pioneer SX-205 does not have remote control capabilities.
Posted on Nov 05, 2009
How to hook-up an AM antenna to pioneersx2300
go to the part store and get an antena it plugs into the system giving you am and fm frequencys
Jul 22, 2012 | Pioneer Sx-2300 Am/fm Stereo Receiver With...
My pioneer overloads and cuts out
this unit draws alot of power if you have too many things plugged in on the same circuit then it will shutdown and reset itself. unplug reciever and plug straight into the wall
Nov 13, 2011 | Pioneer SX-315
How do i hook up an antenna to the pioneer sx-950
There are two antenna sources on the Pioneer SX-950.
Both of these outputs are located on the rear panel of the receiver. The AM is a permanent mount. The FM is standard RF/Coax which will run to your antenna.
Antenna Inputs: FM 75 ohm, FM 300 ohm
Am Ferrite Bar Antenna
Hope this helps,
TechGuy21
A
s
Jul 04, 2011 | Audio Players & Recorders
Pioneer SX-2300 powers up, but no sound.
Does the output relay click about 5 sec. after powering on? If it does check if the tape2/tape monitor is on. Check speakers and wiring. Try headphones.
There aren't any fuses for the output.
If no relay then it probably needs output transistors and a few resistors.
Dec 17, 2009 | Audio Players & Recorders
!994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
Apr 06, 2009 | 1994 Buick LeSabre
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
FM radio intermittent static on '95 volvo 940
Sounds like you either left something loose or lost a piece of shielding. Was there a filter on the antenna that you forgot to put back on?
Jan 10, 2009 | 1991 Volvo 740
Signal indicator brake lights and fm radio
You may have an intermittent switch or possibly a shorted or broken wire. As for the radio, I'd yank it and put an after market deck in. GM radios aren't known for their quality. But, you could check the back of the radio to see if the antenna lead is plugged in securely.
Hope this helps.
Aug 11, 2008 | 1999 Pontiac Grand Am GT
150 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
