Question about LG Home Applaince LG DLE2101W 7.3 Cu. Ft. Electric Dryer - White
LG Dryer making humming noise
This dryer is only two years old. It makes a humming noise when operating. I have already cleaned out the exhaust vent and made sure there was nothing next to/underneath the dryer that could be causing the noise. It seems to be coming from somewhere inside and to the rear.
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: loud vibration
Lot of these dryer had a split or defect in the drum. They will give a free drum but ya gotta pay labor to replace it.
MY LG dryer service manuals and repair videos
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 16, 2012
richroth
  • 9472 Answers
SOURCE: shutting off won't start when hot
The windings in the motor are bad and the motor will need to be replaced. Here is the motor to order.
The part comes with a 365 day, any part, any reason return policy.
Posted on Nov 18, 2012
I ust replaced belt/tensioner/front upper and lower felt and rear bearing and clean vent out still have a vibration/ humming noise could noise come from exhaust blower ?
That is exactly what it is. Frigidaire dryers are known for the bearing wearing down and causing the vibration. Here is the new blower you need.
Don't forget to move the thermostat over from the old blower to the new one!
Oct 19, 2012 | Frigidaire Dryers
Whirlpool gas dryer takes longer to dry though it heats up and turns, yet it has a humming/buzzing noise. What could be the problem?
Had the same problem. There was a bit of a kink in the vent duct which caused lint to build up in duct and also inside the dryer itself over years. I replaced the duct and took dryer apart and cleaned out the air passages.It works great now. As for the humming, mine started about 2 1/2 years ago and I still don't know why.
Jun 04, 2012 | Whirlpool Dryers
Not completly drying clothers
Make sure that your exhaust vent from the dryer to the outside vent is clear. If you have not cleaned it a few years, you will need a professional to come out and clean the vent properly.
Hope this helps.
Nov 06, 2011 | LG DLE5977 Electric Dryer
We have a LG dryer that is about 2-3 years old. The sensor is completely lit showing an obstruction but we have cleaned the vents out all the way to the roof and the sensor stays fully lit. The clothes...
Check the exhaust vent behind the dryer to make sure it's not kinked.
Take off the dryer vent and run the unit to see if it will dry normally. If it does, you still have a blockage in your exhaust vent in the wall.
Jul 20, 2011 | LG DLE2532W Electric Dryer
Maytag electric dryer model MDE6000AYW dryer is running but not getting hot and drying clothes plus making a dining noise every couple seconds while running
Dryer Does Not Run
Your Kenmore Oasis dryer may occasionally not operate as intended. When the dryer does not turn on, check that the power cord is plugged into a working electrical outlet. Check your fuse box to make sure a fuse hasn't blown or the circuit breaker hasn't tripped. Replace the fuse or reset the circuit breaker as needed. Next, check that you have fully closed the dryer door; if not, the dryer will not run. Finally, make sure that you press and hold the "Start" button for at least five seconds.
Dryer Making Noise
Kenmore Oasis dryers will make noises that occur commonly with the running of the machine, including the motor and the sound of hot air blowing into the machine. Listen for uncommon noises with the running of the dryer, such as metallic clanking and excessive vibration. These noises indicate a problem with the machine.
If you hear metallic clanking, stop the dryer and check for any metal objects in the dryer drum. Often, change or other objects left in the pockets of clothing placed in the dryer will then fall out when the dryer starts spinning, creating the noise.
Excessive vibration often occurs when you have not properly leveled the dryer. To check whether the dryer is level, turn it off and try shake it frontward and backward, then left and right. If the dryer moves, adjust one or more of the legs needs to level the dryer: Determine which leg(s) you need to adjust and use a wrench to lengthen or shorten the legs. A level dryer will more quietly due to the elimination of vibrations.
Drying Time is Too Long
You may find that your laundry takes a long time to dry in the Kenmore Oasis dryer. This often occurs due to restricted the air flow within the machine. First, clear the lint filter. Clean it before every drying cycle to ensure proper air flow through the machine.
Next, run the dryer as usual and check the exhaust vent to ensure that airflows out of the vent. If you cannot feel air flowing through the vent, check it for blockage or damage. Clear any objects blocking the vent, or replace it if it has sustained damage.
The blockage may also occur in the exhaust hose attached to the back of the dryer. Unplug the dryer and remove the hose from the back of the machine. Clean out any lint or other obstruction and reattach the hose to clear the exhaust hose.
Mar 09, 2011 | Dryers
Electrolux 12141 Washer/Dryer When opening the door the clothes are really steaming. We haven't noticed this before, the machine approx. 2 and a half years old. Is this normal? Or is it something that...
Your exhaust vent is blocked causing the steaming affect.
Remove the exhaust vent from the rear of the dryer and clean it thouroughly before replacing. Make sure it is straight as possible with no kinks.
Jan 10, 2011 | Electrolux Washing Machines
Dryer is making a rattling noise when in operation. Dryer is eight years old of so. Never heard this noise before.
Rattling could be anything from a bad idler or support pulley or coins in the vanes. If you can hear it you can find it pretty easily.
Eric
Jun 13, 2010 | LG DLE2532W Electric Dryer
Dryer makes humming noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
bb
May 15, 2010 | LG DLE2512W Electric Dryer
The motor has gone bad on your dryer...
Here is a tip I wrote about your problem....
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 28, 2010 | LG DLE2512W Electric Dryer
I have a kenmore HE2 dryer and matching washer. It is 3 years old. It works and eventually clothes do dry. It does heat up. But it doesn't heat up as hot as it used to and it takes twice as long to dry...
Make sure you check your exhaust line and where the air blows to the outside. If your exhaust vent or hose is bent or restricted it will take a very long time to dry the clothes. Sometimes the vent flap on the outside exhaust is stuck shut. Clear dryer exhaust venting is critical for proper operation. Several companies offer a vent cleaning service where they completely clean out the exhaust lines.
Feb 02, 2010 | Kenmore HE2 Plus Front Load Washer
LG Home Applaince LG DLE2101W 7.3 Cu. Ft. Electric Dryer - White Logo
Top LG Home Applaince Dryers Experts
Sal De
marlin siecinski
Are you a LG Home Applaince Dryer Expert? Answer questions, earn points and help others
