Question about Lands Phones
Philips SE245 Quad Telephone Cannot get beyond 'Unregistered'
Have had instrument approx 5 yrs. Suddently Phone No. 3 reads 'Unregistered'. Followed manual re 'PIN' & dialing 0000 - no joy. Tried 'Registering' following manual, get as far as putting in '3' (phone number). Number does not show does then 'Unregistered' appears in 'Window'. Remembered to press BASE and await 'beep'efore starting above. Can you help, please? New batteries have been inserted.
SOURCE: Handset No Link To Base error and no dial tone
My battery is a Ni-Cd. I bought it new on eBay (TL26554 battery number). I allowed the new battery to charge for a long time and then tried to see if it would work. But no go....the handset gave me the same error message. Good Luck to you too! Mmmmmm
Posted on Sep 18, 2007
SOURCE: handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Posted on Nov 19, 2007
  • 4 Answers
SOURCE: how do i set the time setting for panasonic kxt7456 black digital super hybrid system anyone has the manual? or set of instructions?
ok, the link isn't working properly, so I'll try to explain:
step 1 press "program" button, then **1234
step 2 enter 000
press next (or spkr phn button) for date
press next (or spkr phn button) for time
press fwd/dnd button
press fwd/dnd button again
press sel (or auto answer/mute button) to change am/pm
press store (or auto dial/store)
press end (or hold button)
press spkr phn button or pick up hand set and hang up to leave programming mode.
Posted on Jan 29, 2008
SOURCE: Cordless Phone problem- uanble to use!
Solution:
Unplug base unit
Remove both batteries from the phone(s)
wait 60 seconds
Plug in base unit
Replace batteries in phone(s)
Press speaker icon on base usnit for 5 seconds
Press menu
Select adv adv settings
Select registration
Enter 0000 then press ok
should go from waiting, to searching, then to 'welcome'
press ok...
should be up an running!! :-)
Posted on Nov 16, 2009
SOURCE: PHILIPS ID937 phone.
Fixed:) Ok so I bought 2 extension handsets from different people off of Ebay, both new. First one wouldnt register or would say incorrect pin (0000). So I tried the second one, same thing. Here is what I did: When attempting registering, make sure the handset is physically on top of the main base station, IE charging. Start the registration process on the handset and press-hold (dont let go) the locate handset button instead of press and hold for 3 seconds (like the manual says to). If that didnt work, I removed the batteries and tried pressing and holding the same button for 3 seconds, then release. Wait 10 seconds, then press and hold for 3 seconds. Repeat. If the handset timed out and went back to the main unregistered instruction screen. I took the batteries out and tried again. It was a bit of trial and error but each cycle I removed the batteries to reset the handset. First extension handset took 20 minutes of head scratching, the second 2 minutes. Hope this helps someone. The build and sound quality on these units are great, the tech support....not so much.
Posted on Feb 26, 2010
I have Uniden DECT1480-3. I purchased two expandable handsets, but I cannot figure out how to get the new handsets to register with the base unit.
Up to 6 handsets can be registered with the DECT 1480 phones. I have the 5 phone unit and needed to add the 6th phone. All I got was "Searching" in the display and the battery wouldn't even charge!
So here's what you have to do to get additional phones (up to 6 units) to work with the base. If you can get past step 1, it's a snap...
Step 1: Place a charged battery in the handset. This could be a problem if all your handsets are not registered, since unregistered phones don't charge (who thought of that design?). What I did was SWAP the battery from an already registered and charged phone with the new unregistered phone.
Step 2: Here's where the magic happens. Press the 'END' and '#' keys simultaneously... hold them down until a System Reset menu appears. Select "Deregister HS" and press Menu.
Step 3: Now, do the same thing again (hold down END and #), but this time select Base Unavailable and press Menu. You will see Base Unavailable Yes/No... Select Yes. Then place the handset in the base, wait a few seconds, and Voila!. it's registered. You can even change handset numbers using this menu if you play around with it.
Thank you, helpful employee at Costco for supplying the magic code. And hey there, UNIDEN... including this in the operation manual would have saved many customers much grief with de-registered phones!
Enjoy!
May 14, 2011 | Uniden DECT 6.0 Cordless Telephone...
Where can i get a wharfedale in120-3 manual - my
reading unregistered , dont know how to fix it . Has been working
ok previously
Nov 21, 2009 | Lands Phones
Philips dect 122
Normally , one base can register 4 hanset in EEPROM setting. The model, Maybe you can try press the "page" key, then plug the power cord , after 5 to 6 second , release "page" key. Try to register handset again.
Dec 13, 2008 | Philips DECT 2252S Cordless Phone
Tru 9496
SOLUTION:
1. First, remove the battery cover on your unregistered TCX905 and look under the battery to confirm that you indeed purchased a TCX905 because some Uniden handsets were packaged as 905's but were not.
2. Take the fully charged unregistered 905 to the base unit TRU9496.
3. On the TRU 9496 base unit press "Menu" then select "Registration" and press OK
4. You should get the message "press the # key on the remote handset".
5. Depress the "#" key on the unregistered 905 and it should register.
Aug 07, 2008 | Uniden TCX905 Cordless Accessory Handset...
Philips dect245 searching problem
1. try to reset handset. try sw reset in the manual .
2. try to clear the base. unplug power cord, press and hold "page " key , and plug the power cord , after 5 to 6 second release page key.
3. Register again.
4. If there is still searching , open the base and handset, to check ,if the antenna is broken or not.
Jul 30, 2008 | Philips DECT 2252S Cordless Phone
Philps TV problem
When I turn the TV on, I get a horizontal line across the screen approx 1/3 from the top. My TV make is Diamond and is approx 6 yrs old
Mar 14, 2008 | Philips Magnavox 27MS343S 27" TV
Solution:
Unplug base unit
wait 60 seconds
Plug in base unit
Press menu
Select registration
press ok...
Feb 21, 2008 | Philips CD1503B/17 Phone
Philips CD130 Cordless Phone User Manual
registering again didn't work for me. I used the following steps
1. close the handset (long-press red button)
2. discconect the base unit from the power source
3. reconnect to the power source and long press the intercom (the only button on the base unit) for 5 seconds.
4. turn on the handset (long-press red button)
with 2 seconds and it will be connected again.
hope this helps.
Jan 25, 2008 | Lands Phones
Lands Phones Logo
43 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
