Question about Alpine CDA-9825 CD Player
How do i turn on aux mode on my cda-9825 alpine
I need to have the aux on in order to use my i pod or my mi-fi but when the battery goes the radio turns that option off on the radio how do i get it back?
SOURCE: Peripheral's Connex2Car adapter to an Alpine CDA-9851
the alpine should recognize it as a "changer" when you select the source; ie: radio, CD, changer. Sounds simple, but have you turned up the volume on the iPod?
The Alpine adapter is $100, but works great, you can totally control all your iPods functions, and it displays all song info on the Alpine decks display.
Posted on Feb 06, 2008
  • 132 Answers
SOURCE: Volume problem with the AUX input using iPod
Do you have the ipod turned up too? Whats happening is the alpine is getting to low of a foltage signal.
Posted on Jul 30, 2008
SOURCE: Screen says searching when iPod connected to Alpine CDA-9847
Check your ipod to see if it is shuffle mode. Alpine doesn't document this but they have a bug that causes the problem that you describe. If the ipod is in shuffle mode the Alpine gets confused.
Posted on Sep 29, 2008
  • 82 Answers
SOURCE: hooking up alpine hd radio unit, bt-400, which one do i hook ipod to
Niether .... do you know what you have in hand? Both those extras costed someone some cash ... OK here it is: the CDA-9884 has a dedicated input for ipod (a KCE-422i cable is needed and comes with the new CDA-9884 in the box) ... The HD radio unit allows you to recieve new HD radio signals (digital radio, and stations that have it in your area may also have extra music streams like HD TV does). The bt-400 is a bluetooth adapter to use bluetooth enabled devices with such as a cell phone. If your ipod has bluetooth you could used the bt adapter but I suggest the KCE-422i cable instead, and check out the HD radio too, it's pretty cool.
Posted on Apr 17, 2009
  • 77 Answers
SOURCE: On my Alpine CDA 7892 i have the aux cables right
I believe you need the Alpine KCA-410C - Ai-Net multi-changer/versatile link adapter before you can input from an external source directly.
Posted on May 08, 2009
How to hook an ipod to a rs2640
This one is fairly easy for you! Go to Radio Shack or similar place and get a cable that has an !/8" (3.5m? they may call it) Male, (which is what your I-Pod should use, double check this when you go look at them...some I-Pods use 3/32"), then at the other end you need what they call RCA ends....plug the RCA's into the front AUX IN jacks, plug the other into your I-Pod, set your stereo to AUX and enjoy!
Jan 21, 2013 | RCA RS2640 CD Shelf System
What's your problemI bought a used car that has an alpine cda 9805 radio. It has an auxillary cable that appears can hook up to my I pod nano. I can't find the function/ mode on the radio to g
The source/power button in the top left corner changes the mode. Press the button until the aux appears. The auxillary device must be plugged in to register on the stereo.
Aug 19, 2012 | Alpine CDA-9805 CD Player
Hook up an iPod to Beosound2000 system??
There is an Aux input on the B & O. you can connect the I-pod to through this input. You will need a 3.5mm phono to 2 RCA cable connector. The phono jack goes to the I-pods headphone socket and the RCA ( Red & White ) jacks goes to the B & O Aux input.bobhifi_28.jpg
Apr 01, 2011 | Audio Players & Recorders
The portable setting no longer comes up. instead
you may need to into the menu and turn the aux option back on.
Apr 20, 2010 | Kenwood KDC-MP828 CD Player
How do i connect an ipod in a car
you connect your i-pod to the car stereo using 3.5mm stereo connectors on each end. If your car does not support stereo input in the aux(or if it does not have a sound input jack), then you can also use the cassette adapter. Or if you have a 30 pin connector, your I-pod is recognized immediately. i have attached an image showing my car with i-pod.please rate my solution as helpful.
Apr 02, 2010 | Apple iPod MA446LL/A MP3 Player
How do i hook up my i pod up to a mcm530 philips stereo system?
If it has an aux imput all you need to do is get a dock (which will keep the battery charged while playing) or the cheaper way - by connecting a 3.5mm plug to two RCA phono plugs- lead. The 3.5mm plug goes into the headphone output of the I-Pod and the RCA's go into the Aux imput of the Philips.
It can be any imput on the amp (except phono) such as CD or tape.
You will find that you need to turn up the volume on the I-Pod to hear the sound.
Mar 08, 2010 | Philips MCM530 CD Shelf System
Alpine CDA 9827 using aux mode with ipod shuffle via rca inputs
Unfortunately, the rca outputs are to control an amplifier or crossover. They do make an ipod adapter for that radio, which allows you to control the ipod through the radio. Best Buy or any Alpine dealer should carry something for around $25.
Jul 05, 2009 | Alpine CDA-9827 CD Player
Aux won't work
You Will Need To Unhook Your Battery From Your Car And Re Hook It Up Then Plug Something In To The Aux Port And Then Try To Select It As A Option.
Jun 13, 2009 | Kenwood KDC-MP235 CD Player
Alpine CDA-9825 CD Player Logo
169 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
