Question about Hotpoint 24 in. HDA3740G Stainless Steel Built-in Dishwasher
Lights 2 and 4 flashing hotpoint lft114 dishwasher
5 Suggested Answers
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
SOURCE: My hotpoint Aquarius Dishwasher starts up bu only
I had the problem of flashing lights and water did not pump out.Found a piece of bacon in drain pump wedged between impellor and pump body...cleaned it out...problem solved..
Posted on Aug 21, 2010
  • 195 Answers
SOURCE: fitting details for Hotpoint LFT114 dishasher
Hi when adjusting the legs just get it squair with the counter top keeing also level , it is ok if it tips towards the rear a little ,,once you get it set then install the two screws to keep it from moving ,
Posted on Dec 10, 2011
tobyyeld
SOURCE: how do i adjust the back foot on hotpoint lft114
If you look at the front of the dishwasher, below the door, you will see a red hexagon shaped nut. It requires an 8mm spanner or socket. Turn it clockwise to raise the back, anti-clockwise to lower. It works best if you can lift the back at the same time to take some of the weight off the foot.
Posted on Jul 25, 2012
When my dishwasher finishes it no longer lets out 3 beeps and when you open the door there is no power even though the dishes are clean.
Hello J Arnott,
Sorry to say I'm here in the USA.. and I could not easily get a similarly designed model to reveal itself (for me) to gain a better understanding of your Hotpoint LFT114... (nor could I pull a FREE copy of your user manual (without registering or otherwise exposing myself to cyber-freaks (sorry)).
Regardless of the specifics.. suffice it to day your machine is NEW enough to be quite visible and relevant...
I looked over the LFT114 HA... Display board... £42.93
(there are many LFT114
And your trouble description was quite excellent in detailing
as SEQUENCE failure of your control modules...
Although it is possible to repair these things ... it seems you have several PCBs (printed circuit boards)... replacement is usually the first best GUESS (looking at the back () side would not hurt anything)...
I have rescued many a circuit board by simply "de-soldering"...
then re-soldering a connection...
(special care, skill & tools required... not tough nor expensive).
You description and troubles indicated the beeps & lights missing: is a clear indictment of your "DISPLAY board"...
A reminder... don't touch any PCB you value without first grounding your hands (professionals use STATIC WRIST STRAPS... CHEAP (unlike circuit boards) & available EVERYWHERE).
Also... Take lots of pictures of EXACTLY WHERE every wire comes from... (look them over BEFORE you get in trouble).
Be patient & FORCE nothing.
and of course... be safe (REMOVE POWER).
Comment me back BEFORE you guess wrong... (I'll try to help) .
Spares:
Hotpoint LFT114 HA PCBs Modules
Jul 15, 2016 | Hotpoint Dishwashers
I have an hotpoint sdw60 dish washer that is flashing 2 yellow lights, these are numbers 5 and 7 (fast and dry 40c) and (delicate 50c) can anybody tell me what this means.thankyou
Hotpoint Indesit dishwasher flashing lights fault error codes ...
? 15:08
www.youtube.com/watch?v=FRLbrBPHcnE
May 3, 2015 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/hotpoint-aquarius-fdm-dishwasher-flashing-lights-and-there-fault-codes ...
Oct 02, 2015 | Hotpoint Dishwashers
Lft114 dishwasher does not get hot and start and wash button flash
3rd and 4th light flashing. Problem with control board. how to replace control board?
Dec 30, 2013 | Hotpoint Dishwasher Lft114uk Led On/off...
Fitting details for Hotpoint LFT114 dishasher
Dec 10, 2011 | Hotpoint Dishwashers
My hotpoint Aquarius Dishwasher starts up bu only runs a few moments before stopping with 2 lights flashing " wash " " drying "
Mar 18, 2010 | Hotpoint 24 in. FDW60 Free-standing...
My hotpoint LFT114 switches on, has all four wash cycles, has water but will not work even when the door is fully engaged. What could the problem be
G.E. motors (G.E. and Hotpoint) have an issue with the impeller seizing. Turn the electricity to the appliance off. Remove the lower front panel(s) to gain access to the motor and its impeller. Take a flat head screw driver and carefully insert it within the motor impeller area and try to turn the impeller clockwise. If stuck or hard to turn, keep trying until it loosens (turns freely). If it turns freely, activate the dishwasher and see if it works for you. If the motor impeller does not turn, contact an appliance service company.
Feb 20, 2010 | Dishwashers
LFT114 Flashing start light and Eco wash light? Not washing but water coming in
means either Heater Open circuit or NTC thermistor detached from casing. so check resistance of heater.. if ok then pcb required...
Dec 17, 2009 | Indesit 24 in. IDL700 Built-In Dishwasher
Hotpoint LFT114 Fully intergrated dishwasher. Hi I've just installed this machine and I find it very noisy compared to our old one. Everything seems to be working OK and dishes come out clean but can't...
Hi! noises can be very elusive, but some more info might give me enough to narrow down your search or figure out if what you are hearing is normal. First, what dishwasher did you have before? The noise that you are hearing, is it during the fill cycle, the wash cycle , drain cycle or just overall noisier than your old one
Nov 05, 2008 | Dishwashers
Hotpoint 24 in. HDA3740G Stainless Steel Built-in Dishwasher Logo
65 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
